Question about HP Compaq Presario F750US
Hi iam looking for high end config machine
Hi
i am looking for a hp laptop on business model with high end configuration where iam able to work on unix/linux and oracle etc we can say working from home...
  • zaher el siddik
    zaher el siddik May 11, 2010
    i cannot undertand your question,
Configure RQRD
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Mar 25, 2013 | Stairmaster 4600PT Stepper
Configure network
There are no end of problems with HP printer driver software. I've had them too. The most likely success will come from completely UNINSTALLING the present HP printer software (ALL OF IT) and reinstalling the MOST CURRENT PRINTER DRIVER for your computer operating system. You download that driver from hp.com by inserting your model number an following the screen instructions. There is a companion PRINTER DOCTOR tool from HP that you should also download just in case you continue to have a problem after you install the new driver. I can't stress to much how important it is to completely remove all traces of the HP software from your computer first before you reinstall using the latest driver. Failure to do so will cause you continued problems.
Also, if you want to minimize other software issues, after you've downloaded the most recent driver, REMOVE your Antivirus Program if you are using one. I found that there were conflicts caused by Kaspersky AV firewall settings that HP software did not over come. I reinstalled Kaspersky AV after the HP software install and everything worked fine then. The necessity of this step seems to be computer-dependent. I have 3 pcs, all running Win10 Home and only ONE of them required this extreme step in order to get the software to function completely ok.
Apr 23, 2012 | HP Business InkJet 2800 Printer
My stairmaster 4400 PT shows "config rqrd" How do
Corrective Action
Oct 14, 2011 | Stairmaster 4400 PT Stair Stepper
Hi I am having a problem with our business HP LaserKet 424n printer; when we print anything out it seems to make a noise that it normally doesnt make, and our paper ends up looking smeared to the point ink...
Take print out of configuration page(menu-information-configuration page), chech the maintenance kit interval 2,25,000 crossed?
YES... replace maintenance kit & Swing plate assm..
NO... check fuser sleeve surface arrested with toner?...Replace fuser...
Sep 04, 2011 | HP LaserJet 4240n Printer
Error Messag CONFIG REQUIRED. How do I configure?
Corrective Action
Dec 30, 2010 | Stairmaster 4400CL Stepper
My cisco 4503 keeps losing it's configuration file.. any ideas why this is happening? thx.
The case gives me hints towards the configuration register value which is not set to proper value, so the switch is not checking the the saved configuration in the config file.
Please do the below steps.
1. Log into the switch
2. Come to enable prompt
3. Typein the below commands
config t
config-register 0x2142
end
write memory
The find an example of the prompt and the commands below
Switch# config t
Enter configuration commands, one per line. End with CNTRL/Z.
Switch(config)#config-register 0x2142
Switch(config)#end
Switch#write memory
After this you can configure your switch as per your requirement and then save the config by typing write memory
Now you can reboot your switch and the switch will come up with the configuration as you set.
Best Regards
Nov 06, 2010 | Cisco Catalyst 4503 (WS-C4503) 12x1000...
DVD DRIVE OF MY HP LAPTOP
Hi there:
If you know how to boot the computer into bios look for the boot section and check to see if the cd rom is there if not change the settings to show a cd rom and than save and reboot but i think you may have damaged the cd rom when you forced it open these are pretty delicate devices , force should never be used .
best regards mike
Feb 16, 2009 | Toshiba Satellite U305-S2804 Laptop
I need to know how to configure link proof radware
Hi Nalinfrancis,
One way you can config the LP is to log on to the serial interface and then configure an IP address to the first eth port that is available. Then connect directly to the port using a crossover cable depending on the laptop or pc that you use if it can switch put your laptop/pc on the same network that you configured on the port. Then connect via your browser to the IP address assigned to the LP. Logging with you default username and password. From there you can do all the configuration via the web interface.
Regards,
Andrevz
Jan 03, 2009 | Radware LinkProof Application (904627-cl3)...
Raid config problem
download a driver over the net
Feb 21, 2008 | HP NetRAID-2M SCSI Controller
HP Compaq Presario F750US Logo
19 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
