Question about HP PSC 2410 All-In-One InkJet Printer
HP PSC 2510
Having same problem after power failure w/ psc 2510 running xp sp2. tried uninstall an reinstall of driver. did not work. tried to install on another computer via usb...failed. Powers up, hourglass infinite loops, unless press power up button. Then device "recognizes" (but it really doesnt).
2 Suggested Answers
SOURCE: Unit wont start up after power failure
Answer on fixyourownprinter.com. Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Posted on Apr 30, 2007
HP director has been uninstalled from my system, but now I cannot use my printer to scan a document. HP doesn't offer a driver to reinstall this software and the CD which came with my printer will not...
Here is the link to the software for your HP with Windows XP, when you click the link, look below the HP sign in the middle of the screen and you will see an orange download button...that is the button to download your software. It is over 360 mb, so give a few seconds to load up and give you the run or save window, if it doesn't, there are small buttons that say "click here" if download doesn't start...but it should.
http://www.downloadsource.net/12802/HP-PSC-2510-2510xi-2550-Photosmart-All-in-One-Full-Driver-Windows-98-ME-2000-XP/
Sep 16, 2009 | HP PSC 2510 All-In-One InkJet Printer
I have the hp psc 1210 printer but when I tried to install the software on my HP Pavilion I was told it was incompatible
You should not connect the unit until after you load the disk. Look under the add/remove programs and see if there is a program you can uninstall, then reinstall. Try the HP website for a driver too. What are you using, Windows XP?
Aug 02, 2009 | HP PSC 1210 All-In-One InkJet Printer
Need a new power cord, how much ?
Here you go:
Compatible Part No:
  • HP 0957-2094
  • HP 0950-4466
Compatible Printers:
  • HP OfficeJet PSC 1350
  • HP OfficeJet PSC 1355
  • HP OfficeJet PSC 2410
  • HP OfficeJet PSC 2410xi
  • HP OfficeJet PSC 2450
  • HP OfficeJet PSC 2510
  • HP OfficeJet PSC 2600
  • HP OfficeJet PSC 2610
  • HP OfficeJet PSC 5510
  • HP OfficeJet PSC 5510 all in one
  • HP OfficeJet PSC 5850
  • HP PhotoSmart 1315 all in one
  • HP PhotoSmart 2510
  • HP PhotoSmart 7960
  • HP PhotoSmart 7960w
  • HP PhotoSmart 7969
  • HP PhotoSmart PSC 2510
  • HP model numbers Q3435AR, Q3435A, Q3501A, Q3087A, Q3090A, Q3094A, Q3020AR, Q3020A, Q3023A, Q3024A, Q3021A, Q3022A
  • HP Bundle PSC1315+M307 Q5776A
  • HP OfficeJet 5500 Series All-in-One Q3434A, Q3435AR, Q3435A, Q3435P, Q3436A, Q3437A, Q3438A, Q3440A
  • HPPSC 1300 Series All-in-One Q3492A, Q3493A, Q3495A, Q3500A, Q3501AR,Q3501A, Q3502A, Q3503A, Q5532A, Q5534A, Q5763A, Q5765A, Q5766A, Q5767A,Q5768A, Q5769A, Q5770A, Q5771A, Q5772A
  • HP PSC 2410 PhotoSmart All-in-One Q3087A, Q3088A, Q3089A
  • HP PSC 2500 Series PhotoSmart All-in-One Q3094AR, Q3094A, Q3095A
  • HP PhotoSmart 7900 Series Printer Q3020AR, Q3020A, Q3021A, Q3022A, Q3023A, Q3024A Q3090A
For HP 0957-2094 PhotoSmart 2410, 2510, 5510 Printers and much more.Come with power cord. Power Rating: 32V 940mA and 16V 625mA
Note: Amps and Watts are maximum load tolerance. Devices only draw as many Amperes or Watts as they needed
For purchasing you might also contact this link below:
http://cgi.ebay.com/Adapter-For-HP-0957-2094-0950-4466-32V-940mA-16V-625mA_W0QQitemZ250414311173QQcmdZViewItemQQimsxZ20090427?IMSfp=TL090427149005r21586
Hope you like my info
May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
Using multiple HP printer models with same Windows XP laptop
I doubt there is a universal driver , however you could connect directly to your pc or via a router and share it over your home /business network, and access it them that way
Feb 13, 2009 | HP Office Equipment & Supplies
Printer prints everything very small
Make sure to load the Vista driver for your printer. Try to uninstall and reinstall the driver first. Now on the printer, set it factory defaults again. You can try to unplug the power cable for few minutes.
Jan 12, 2009 | HP PSC 1315 All-In-One InkJet Printer
We have a HP printer series 1310 and have recently purchased an ASUS notebook. We have attempted to install this printer to the laptop with difficulty as we continually rec've an error msg stating it is...
Hello
The printer should be compatible with both vista and XP
your printer is a serie 1310 but if you look closer you should find a more exakt nr like
» HP PSC 1311 All-in-One Printer
» HP PSC 1312 All-in-One Printer
» HP PSC 1315 All-in-One Printer
» HP PSC 1315v All-in-One Printer
» HP PSC 1315xi All-in-One Printer
» HP PSC 1317 All-in-One Printer
» HP PSC 1318 All-in-One Printer
or something like it. check for the serie nr or a mark somewere on the printer and you should find the right printer model.
you can download the drivers here when you find the right model.
good luck.
hope I helped.
Sep 04, 2008 | Miscellaneous
HP PSC 2210xi all-in-one won't print....Please HELP!
I had a problem downloading HP psc 2210 software from the internet after a reinstall of winxp. One of the device drivers was not completing its installation. HP support provide a troubleshoot process to fix the problem. This process is manual but did complete the installation of the device driver. The printer is working.
Feb 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Psc 1315 driver install in vista error
try to uninstall, then reinstall the printer. Be sure that you have a driver for vista.
Jan 01, 2008 | HP PSC 1315 All-In-One InkJet Printer
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
HP PSC 2410 All-In-One InkJet Printer Logo
119 people viewed this question
Clive
Clive
