Question about AEG Dishwashers
Aeg dishwasher, smelled hot and stopped pumping water
Powere to machine and water connected fine but there was a hot electrical smell then no pump. is it motor or pump?
  • 750 Answers
Hello mmhmmd
Welcome
What is the MODEL Number and year of your dishwasher. Model can be found on sticker inside.
Did you turn off the power at the breaker for 5 minutes to see if it resets the system?
If you do not have this equipment mentioned below you may want to call a pro!
Here are four things to check for this problem!
Water source turned off
Check to ensure the water source is turned on and water is getting to the water inlet valve.
Float switch
The float switch allows water to enter into the machine to a point where the float will rise up off of the switch and disconnect power to the water inlet valve. If the switch is defective or the float is stuck in the up position, the water will not enter into the machine
Defective water inlet valve
If there is 110v across the two wires on the water inlet valve when the machine is set to fill, the valve should open and the water should enter into the machine. If the water does not enter, the valve is defective.
Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a vol/ohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician.
Let me know how it goes?
Thank You , Huuum
Please remember to leave a rating!
Posted on Oct 22, 2008
I have an AEG F55002ViOP dishwasher. It's making a strange grinding sound and showing error code 30. Can anyone advise how to solve this please.
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
The noise what you heard during operation indicates that something is blocking the drain pump.
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage then check why the drain pump makes noise.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Good luck.
Dado
Oct 11, 2014 | AEG Dishwashers
TOP LOAD KEEPS WATER IN FROM RINSE CCLE, ALL OTHER FUNCTIONS WORK FINE, SMELLING BURNING ELERICAL SMELL.
Your pump is not working because it is not extracting the water. You are right with the smell of burning electrical. Depending on the age of the washer it might cost more to repair than purchase a new one. There could be a leak somewhere because water got to the wires and maybe shorted the pump. Good Luck
Jan 07, 2011 | Washing Machines
Washing machine water doesn't drain and the machine smells bad
machine most likely has something caught in either the pump or one of the lines and you should clean out the pump with the smell s it a mold type smell or like a wet clothes type smell or a stagnant water smell that your smelling for the smell after you clean out the pump the drain line and the hoses at home depot they sell a product for washermachines that takes the smell out it is called AFFRESH this is one of the best products to use in washer machine they also make a type for dishwashers as well if you have anyfurther questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
p.s your pump could also be bad from debris sitting in the line
Dec 20, 2010 | LG Washing Machines
Washing machine stopped spinning after several loads, and I smell a slight burning smell, won;t drain either.
it sounds like u might have some electrical problem in the controls however it may be the pump itsself has gone out but if u r getting an electrical smell could be causing the pump not to get power or the pump has burnt up causing the wires to get hot and start to melt myy bet is that the pump has gone out its not horribly bad to change out but kind of difficult for someone who isnt used to doing this kind of stuff
Feb 25, 2010 | Washing Machines
Acrid electric smelling smoke pouring out of machine when pumping down wash water. motor feels hot to touch.
If you are not overloading the machine, and the front of the motor is pretty hot, then it is going bad. If it smells like rubber, it is the belt.
Jan 14, 2010 | Amana DLW330RA Top Load Washer
DISHWASHER AEG 80860
Just fixed a similar problem on an AEG F3A by following other advice on this site. Simply tip the machine forwards on to its door (best empty it of crockery first!!!).and then put it upright again when water has stopped dripping out of it. You wil get quite a bit of water on your floor which I reduced by pumping the water out of the salt resevoir first - but if you don't have a pump just have several towels handy
Aug 23, 2008 | AEG 24 in. Favorit 40850 Free-standing...
AEG Oko Lavamat 86700
check the carbon brushes on the motor as when they are worn arcing occurs and this could trip the electric and the smell could be the plastic brush holders getting hot due to the arcing
Jul 15, 2008 | Washing Machines
Bosch Dishwasher Classix
Had similar problem on my Siemens which is the same as Bosh. I started to take it apart to see what had gone wrong. Eventually I had to disconnect the cable going into the washer - its in a small box at the front at the bottom. The wire nut connectors had melted and shorted out. Unfortunately now it won't fill with water. The smell was not like wood so maybe a different problem.
Mar 21, 2008 | Dishwashers
Dishwasher fix
something has gotten passed the screen and is jamming your pump impeller pull lower spray arm pull screen and see if you can find what is jamming the impeller and remove it drain pump is separate
Dec 30, 2007 | Maytag MDB7100AWB Dishwasher
Water smelling
Although it might not be the most ecological solution, you might add a small amount of bleach to the container, once a week (let it act for some hours before you use the washing machine again - at night for example). I'm pretty sure it will help! Good luck!
Dec 06, 2006 | AEG Lavamat W1050 Front Load Washer
Dishwashers Logo
227 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
