Question about D-Link AirPlus G DWL-G710 Wireless Range Extender
DWL-G710 Tring to ct to router via LAN cable.can ping it, ok. Can´t get to the login page, it olny show Upgrade Firmware. if I have to upgrade how to I do it, please advice BR Mikael Edman
    Genius:
  • 1,268 Answers
You need to download the firmware form Dlink website. There are instructions there as well on how to update the firmware. You need to reset the router first. Press the and hold the reset button at the back of the router for 30 seconds. After that, unplug the power for 20 seconds then plug it back in.
Posted on Oct 22, 2008
TP-Link TL-WR642G recovery after failure upgrade to latest firmware
may find this page helpful. http://www.dd-wrt.com/wiki/index.php...om_a_Bad_Fl ash Its not for the TP-Link router but the same principle could be applied to you with the correct firmware. Its worked for me on more than a few occasions. Providing you can ping the router via a lan cable then the chances of recovering it are very high.
Apr 19, 2012 | TP-LINK TL-WR642G Router
I tried to upgrade the firmware of my router(WRT54GL) but during the upgrade process I got a message upgrade interrupted but with a continue button. I pressed the continue button, but the upgrade never...
Hi just switch it off and wait for 15 second turn it should come up hope you not disconnect the LAN cable or power cable from you router during upgrade otherwise your router maybe cant be use anymore but if it is stopped by it is own it could be wrong firmware version or incompatible one you have entered should you need any help please contact me via my weblog http://computernetworksupportindubai.com/
Jul 22, 2011 | Computers & Internet
How to Change DWL-G710 IP address
in your case, you only need to change the range expander's IP address from 192.168.0.30 to 192.168.1.30
to do this, you need to connect a computer's LAN cable directly to the range expander's LAN port. when both devices are powered ON, then access the initial IP address http://192.168.0.30
when you are in the web interface, click the LAN button and enter the suggested ip under the IP text box: 192.168.1.30 see figure below.
when you already set the IP, click on APPLY. then you are good to go. You can then connect the router, then connect the range expander to one of the router's port, then computers.
Oct 22, 2009 | D-Link AirPlus G Wireless Range Extender...
DWL-G710 won't connect to 192.168.0.30
Here is a link to the manual for your DWL-G710.
D-Link manual on page 13 it lists the url entry should be
"http://192.168.0.30" This is a HTTP link not a HTTPS.
Also the address you typed in might be a typo. The IP address should be 192.168.0.30 not 192.168.0.30.
GOOD LUCK!!!!
Oct 18, 2009 | D-Link AirPlus G Wireless Range Extender...
Unable to update firmware
Your router latest Firmware I can see on D-link website is 1.02
If you are referring to German web site page showing a dwl-g700ap_fw_revB_v213b06.zip file be sure to follow the instruction to UNZIP the web_dwlg700ap_v200_r11_0408.bin file:
DWL-G700ap Firmware Update
- Browser starten
- Konfiguration des DWL-700ap aufrufen (Standard IP 192.168.0.50)
- oben auf Tools
- links auf Firmware
- auf den Knopf Durchsuchen klicken
- die Firmware Datei (web_dwlg700ap_v200_r11_0408.bin) auswählen
- auf Apply klicken
Wenn die Firmware installiert und der DWL-700ap dann neu gestartet ist klicken Sie oben auf Tools/System/Restore to Factory Default.
Danach ist die Firmware übernommen.
If you did not unzip the bin file router cannot run it as firmware update
More over be sure to run the update via LAN cable connection (no WLAN)
Jan 24, 2009 | D-Link DWL-G700AP 802.11g/b Wireless...
WAP54G bricked power led blinking LAN connection shows as not connected
you did not specify where the wap is connected when you pinged it. Try this, connect the wap54g to your pc. Assign static ip 192.168.1.5 on the lan of the pc, then ping 192.168.1.245. if you can ping you should be able to access the configuration page. if the power is still blinking you can upgrade the firmware
Mar 10, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
LAN problems with the router
Are you using the correct cable type. If it is a CAT5 type cable it could be you are using a patch cable rather than a straight through type or vise versa.
May 23, 2007 | D-Link AirPlus G DWL-G710 Wireless Range...
How to Upgrade the Firmware on a Linksys Router
Linksys is very smart and intelligent router .and firmware can be update by clicking on update firmware option on router or you may can reset the router by using 192.168.1.1 and for more details contact Linksys Tech support and you can reset the the hole router by pressing the reset botton at the back.hope this may help you ....or there will
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Charter High-Speed Cable and the BEFW11S4 Version 4
To resolve this problem, you will need to upgrade your router's firmware. Click ftp://ftp.linksys.com/pub/network/befw11s4_v4_v1.50.14_code.bin and download the file to your Desktop or My Documents folder (the link is to v1.50.14 firmware code). Once the BIN file has been downloaded, follow these instructions to upgrade the router's firmware: NOTE: Before upgrading your router's firmware, please make sure that the procedure is being performed by a computer that is connected directly to the Router with an Ethernet cable and not a wirelessly connected computer. Accessing the Router's Setup Page 1. Open a web browser such as Internet Explorer or Netscape. 2. When the browser window opens, go to the Address bar and type in the router's IP Address and click on the Go button (192.168.1.1 is the default IP address of Linksys Routers). 3. A window will appear prompting for a ?User Name? and a ?Password?. Leave the ?User Name? field blank, and type in the router's password and click on the OK button to login (admin is the default password). 4. The router's web-based ?Setup? utility should then load. Upgrading the Router From the router?s ?Setup? page, locate the Linksys logo in the upper left-hand corner of the page. Follow the instructions below depending on which logo matches your specific screen: If the logo matches the image above ("Linksys - A Division of Cisco Systems, Inc."), follow these steps. If not, skip to the next logo version. 1. Click on the Administration tab. 2. When the ?Administration? page loads, click on the Firmware Upgrade sub-tab. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. If the logo matches the image above ("Linksys"), follow these steps: 1. Click on the Help tab. 2. When the "Help" page loads, click on the Upgrade Firmware link. 3. When the ?Upgrade Firmware? page loads, click on the Browse button, and browse to the location where the firmware file was downloaded (and possibly extracted) to. 4. After browsing to the correct location, select the firmware file and click on the OK button. 5. Click on the Upgrade button to upgrade the router's firmware. After completing the steps above, the router's firmware should be upgraded successfully.
Feb 16, 2006 | Linksys BEFW11S4 802.11b Wireless...
D-Link AirPlus G DWL-G710 Wireless Range Extender Logo
512 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
