Question about Hitachi 43UWX10B 43" Rear Projection Television
Hi Def from dvd player
Hi I need to know how to get an upconvert dvd player to work with this TV. The dvd player has an HDMI connector - but the TV does not, so I can't get Hi Def signal. Thank You Tony
    President:
  • 3,130 Answers
Tony, Let me ask you a silly ? as Im sure you can answer your own ?. Is your TV Hi def?? NO?? Ok Is your DVD player HI def campadable? Yes. Does your DVD player have RCA outputs for video or s video Output?? Yes. Ok Tony if your TVs not HI def how do you expect to get HI def out of it??? Use rca outputs as it is compadable. if the DVD player has no s video or RCA jacks and I've not seen one yet that didnt then your going to have to get one that does. Good Luck
Posted on Jul 30, 2006
OH. I have a DVD player/VCR Recorder. I have Cable TV. How do I connect DVD player/VCR recorder to Samsung Smart TV?
Unless your DVD/VCR is Upconverted to use HDMI, then you would use either the RED/GREEN/BLUE + Red /White leads to your TV and then use the TV remote to select whichever your TV names that input. If it is Upconverted, then simply plug the HDMI cable into a spare HDMI input.
Oct 06, 2016 | Panasonic Original Pansonic Tv Vcr Dvd...
I am considering purchasing a Funai Full HD UpConvert DVD Recorder/VCR Combo. I have a HD Phillips TV with HDMI connections. I do not have cable - just use over the air TV. How do I connect the Fun
Purchase a DVD recorder/player that has a HDMI cable connection and use the connections on the TV so you'll get a hi def picture. RF will NOT give you a Hi Definition picture even if it's up converted.
Jan 01, 2015 | Funai Magnavox DV225MG9 DVD/VCR Combo...
Our pitchure is not bright or clear as was in store
This actually common I worked in electronics for 13 years. Did they tell you that it has to be hooked up to an High Definition source. A digital cable or Sattelite reciever does not mean its HD also using Coaxle cableor composite(yellow,red,white) will not produce a good picture. You need HDMI or Component(RED,Blue,Green for video and red white for audio) to get a high def pic. Also not all station are broadcast in high def. One other thing is even if you have a High Def reciever you need to go into the menu of the reciever where it says display and and make sure its set for 1080i or maybe 1080p(most dont have this option yet) If you are using a normal DVD player and use the yellow red and white once again picture will be poor. Need to use Component or hdmi and again with component you need to set DVD to either 480p and if its upconvert to 1080p
Dec 14, 2010 | Vizio VO47L 47 in. LCD TV
Plasma tv showing "Mode not supported" message
YOU HDMI SWITCHER IS DEFECT OR YOUR TV IS NOT COMPATIBLE
Apr 24, 2010 | Samsung PN58B860 58 in. HDTV Plasma TV
We have cable T.V. should we run the cable though T.V. when we use s-video cables or use cable though vcr then T.V.
I would hope that you would use a HDMI cable to connect your cable box to your LCD TV - why not display the highest resolution to your screen that you can. HDMI will transmit the 1080P high def signal to your screen. These cables can be found at Wallmart and Target or even Best Buy. Don't need the most expensive and or a 6' length or short will work just fine.
Then use your S-Video cable to connect your VCR/DVD to your LCD TV - This is not a High Def signal - only 480i if that. The P means Progressive or 1080 lines from top to bottom. the I means Interlaced to which means 240 lines once for field one then 240 lines for field two.
You may want to think of a blue ray player to which upconverts your older DVD's to 4x3 High Def resolution.
Happy Thanksgiving and God Bless,
Blessings,
A/V Media Tech Guy
Nov 23, 2009 | Vizio L32 32 in. LCD HDTV
Upconversion to 1080i playback
Hey smittybd,
According to information provided by the manufacturer, this specific model DVD player is only able to provide upconverted 1080i images via its HDMI output and a maximum 480p resolution using its component connectors. Please keep in mind that while component cables are able to support 1080i and 1080p resolutions, not all hardware (TV's and DVD players) will support these resolutions through component connections.
If you're having difficulty locating a model that specifically supports 1080i resolution images through its component connections, you may wish to try visiting individual manufacturers' websites for more information. Some companies (such as Sony) will provide detailed information regarding what each type of connection is capable of in their owner's manual documentation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 15, 2008 | Sony 36IN TV Stand Designed for Model...
Ps3 hookup to panasonic plasma viera
Actually if you do have a ps2 you don`t really need a Dvd upconverter because Ps3 is a full Dvd player +blu Ray Hi Definition.I suggest to take the dvd out and just use the ps3 as a Dvd player
Good Luck
Jun 19, 2008 | Sony Playstation 3 (PS3) Console
UPCONVERT DVD PLAYER HDMI PROBLEM
I have the same issue with this player hooked up to a Samsung 58 inch 1080p plasma.
Jun 06, 2008 | Televison & Video
Zenith Z42P3 "Invalid Format" message from upconverter DVD
Ran into the same problem with this DVD player and my LG tv. Try this:
Open the DVD tray, with the DVD tray open press the HDMI select button until the proper resolution for your tv is illuminated, put the DVD back in, close the tray and try again. Simple fix -- worked beautifully for me.
Good luck
May 01, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Pink screen or scambled picture when turning on tv to watch dvd
I have seen several LG plasma that have a pink picture and everytime it has been a failed control pwb. This bd is located under the assembly that houses the main digital bd. The main dig. bd is the one with all of the inputs.
Feb 08, 2008 | LG 42PC3DV 42 in. Plasma EDTV
Hitachi 43UWX10B 43" Rear Projection Television Logo
133 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
