Question about Epson Stylus CX7800 All-In-One InkJet Printer
Error code E-90
1. Printer head goes through start up sequence and stops all the way to the right. Then the error code E-90 shows on viewer. Then nothing on the printer works.
2. Plus when you open the printer top to change printer cartidge the cartidge does not center so you can replace the cartidge.
When turning on the power, the Carriage
Unit collides to the Change Lever
located to the front side of the printer. CAUSE
PF Motor
Ink System
CR Scale
CR Encoder Board
Holder Shaft Unit
OR IT S SAMPLE JUST WHEN YOU OPEN THE SCANNER TRY TO MOVE THE CARRIAGE BY THE GEAR OR SOME PAPER JAME IT DO THIS PROBLEM.
Posted on Nov 06, 2008
    Problem Solver:
  • 5 Answers
MECANISM
Epson printer error codes
The error code E-90 appears when the print head is not able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the printer
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the printer back on.
- or, If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  4. Close the scanner.
  5. Turn the printer back on
epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-0.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-2.jpg epson-printer-error-codes-quwd4e0otlw35mvdaq3xmige-2-5.jpg
Sep 01, 2014 | Epson Stylus DX6050 All-In-One InkJet...
Adobe air installer not working
Right click on the program select run as administrator.
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem if you need more help with this post a reply with the error message details Hope it helps.
Dec 28, 2012 | Adobe Systems Adobe AIR
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Error 90 call for help
Your printer needs the attention of a service technician. Before then, you may try reinstalling your operating system or the printer driver or both.
Jun 18, 2009 | Epson Stylus CX7800 All-In-One InkJet...
Canon Pixma 210 series has an error code 6000, won't print or scan
Hope this helps
With thanks to a canon tech
Ok Well again I will repeat this answer with a titch more detail.
The 6A00 is a Canon generic code for paper path jam. Some where in the paper path a sensor is activated indicating paper jam so the printer will give off a 6A00 code. As a Canon tech, I usually find the code, almost 90% of the time, is related to the purge unit being jammed with something and not being able to move. Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like. And yes I have found all those things in a purge unit. The offending item needs to be removed or the purge unit needs replacement. A Pixma MP830 would still be under Canon warranty, get it into a shop and save yourself the hassel.
Incidently, the 6A00 error pertains to all Canon printers made in the last several years, its not just used in one model. And its always a paper path error or purge unit.
I forget myself so here goes, the purge unit, called a spittoon assembly in an HP, lexmark, and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing. That is why you'll find the print head assembly parked on top of it. It also has a an electrical pump to milk the print heads and test for ink flow.
Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
May 22, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have the picture mate personal photo lab and the error code 0x2 comes up when I turn it on and I am not able to do anything else
I had the same error and I could find no information on what it was or how to fix it so I decided to go trial and error. What I found is that this relates to the print head not being able to completely pass from the left to right side during startup. I had a plastic carriage on the one side that was stuck in a position that stop the carriage from make the complete run from side to side. When I forced the plastic carriage down and it clicked into place the error stopped and the printer started up normally with no codes. If anything is causing the print head to not travel completely from left to right during startup, this will probable cause the code. It will be hard to see if the print head is being obstructed if you don't remove the sides. I hope this helps.
May 17, 2009 | Epson PictureMate Photo Printer
Error code 5010 and 5C20
on't know this error code, but this info might help
With thanks to a canon tech Ok Well again I will repeat this answer with a titch more detail.
button pressing
Error Code :
E3-3 = Paper jam
E4 = No ink
E29 = EEPROM error
May 14, 2009 | Canon PIXMA MP610 InkJet Printer
My HP Pavillion desktop had given me a "serious error" screen and then a "blue screen" and stopped working. It would not reboot. I had to use my recovery disc to get it to boot up. It...
you need to make a note of that blue screen you say you get when the computer stops working.. those are know as the infamous blue screen of death (no kidding) or as ms call it stop error screens..
make a note of the stop error code you get on the screen.. it's way to fast for you to see it.. you may be able to see what the stop error code is by going into the event viewer (as long as you have checked to have this events reported to event viewer in system properties> advance tab and start up and recovery area.).. look inthe event viewer (start>right click my computer>manage>event viewer) and look for system events.. you should see a white x inside a a red circle.. look for those error events and look for the error code.. it should give you something like 0x????????? post that error here.. or google it, it may give you an idea of what may be wrong. at this stage it could be software related or hardware related?
did you install a device recently? the driver is very comun problem that may give you a bsod if it's critical.
Sep 21, 2008 | HP Computers & Internet
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Jan 19, 2008 | Xerox Phaser 8400 Laser Printer
Epson Stylus CX7800 All-In-One InkJet Printer Logo
453 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
