Question about Linksys Wireless-G Broadband Router
Linksys WRT00N Xbox360 wont connect to router
How do i change the settings on this router so that my xbox can connect but other peaple cant i dont want to open my router to the hole street but i do wanna play my xbox online
  • shizzle123 Oct 22, 2008
    there is no WPA-Personal there is PSK-Personal and PSK2-Personal and PSK-Enterprise and PSK2-Enterprise Radias/Disabled
    Encryption:TKIP OR AES
    Genius:
  • 1,268 Answers
You'll just need to enable wireless security. Do the following steps:
1. Using your main PC, open Internet Explorer. Type http://192.168.1.1 on the address bar the press enter.
2. It will prompt you for username and password. Leave it blank on username and type admin on the password box then hit Ok. Otherwise, try your own password if admin didn't work.
3. When you get to the router's Setup Page. Go to Wireless tab, then click the sub-tab Wireless Security.
4. For the Security Mode, select WPA-Personal. On the Passphrase or Shared key box, type your own password (8 letters minimum). Then click on Save Settings at the bottom. That's it, your network is secured now. Just remember your Passphrase or the Shared key, that is your wireless network password.
Posted on Oct 22, 2008
I have an older wireless g router from linksys (wrt54g) and i need to change my nat settings for my xbox360 toget a better connection to play COD black ops. how do i do this please? thank you... dean
I suggest if possible to just run an ethernet cable from your router to your Xbox, then it's up to your Internet package(i.e. slow ,fast,light whatever) especially when it comes to online multi-player games, hope it helps
Jan 15, 2011 | Linksys Wireless-G WRT54G Router...
Linksys wrt54g, need console on pc but dont have disc
Are you trying to connect the Xbox to the wireless network?
If yes then you will need to check the wireless settings of the router.
is there any computer on line using the router ?
on that computer you can open the setup page of the router. check the wireless ettings and the security settings then try to connect to the wireless network on the Xbox.
See if that works.
Click here for more information
Jun 17, 2010 | Linksys Wireless-G WRT54G Router
I have a Linksys WRT160N, and xbox live wont even connect?
If your only using this router for Xbox Live id Ditch is I had this same router had nothing but Problems heres a link with a list of compatible routers. http://support.xbox.com/support/en/us/xbox360/xboxlive/getconnected/compatiblenetworkequipment/compatiblenetworkingequipment.aspx
Sep 20, 2009 | Linksys WRT160N Wireless Router
XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
Aug 17, 2009 | Linksys Wireless-G WRT54G Router
I cannot connect to xbox live because my xbox360 cannot find my network
i had this exact problem. the reason mine wasn't working was because the security settings for my wireless router were set on wp2a and the xbox 360 can't pick this up. change your wireless router security to wpa and you should be fine...after i did this it saw my network and i was fine
Jun 02, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
NAT settings
The easiest way to fix this is to replace your router.
Here is a list of routers that are Xbox approved
http://www.xbox.com/en-US/support/connecttolive/xbox360/homenetworking/equipment.htm
The model you mentioned that you have is not on the approved list from Microsoft.
Here is the problem behind your Xbox connection
http://www.xbox.com/en-US/support/connecttolive/xbox360/connectionmethods/troubleshootliveconnection-testnat.htm
Jul 25, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Nat type
I have the same router (WRT300N) and this is what I did. I don't know if it will work for more than one Xbox360.
- Go to the Setting of the router.
- Applications & Gaming
- DMZ
. Enable the DMZ
. Choice the Mac Adress under the Destination.
. If you don't know the Mac Adress of your Xbox360 click on the tab: DHCP CLIENT TABLE
.Now from there choice your Xbox360 ( the Xbox360 won't have a Client Name but hopefully you only have your Xbox360 and your computer)
and now save your setting and restart your Xbox360 and there you go NAT open. This also help if you get any kind of  LAG while someone is on the computer using the internet, your Xbox360 will be high priorty to the router.
HOPE THAT HELP
Apr 05, 2008 | Linksys WRT300N Wireless Router
Cant connect to xbox live through router
Hey stchivo, not entirely sure what's happening.  It might help to know what type of router you have.  I know the new linksys routers have a new security feature by the name of SES or something of the sort.  Make sure that is disabled and that DHCP is enabled.  Also make sure a firewall on the router isn't blocking it.  It might help to have screenshots of your router settings to better evaluate what's happening.
Oct 15, 2007 | Microsoft Xbox 360 Console
Xbox360 Live
you will need to call tech support for linksys on this one xbox might have diff setup that may need configed
Sep 23, 2007 | Linksys Wireless-N WRT150N Router
Linksys Wireless-G Broadband Router Logo
109 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
