I've got a USB desktop microphone, and the manual says that in order to record something, I need to go to Start, then Programmes, and on from there. Programmes is not an option when I click on Start. Any clues?
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    sure..it is under control panel, which is xp..if that is what you are using..
    Genius:
  • 1,269 Answers
For Win XP:
Start > Programs or All Programs > Accessories > Entertainment > Sound Recorder
For Win Vista:
Start > All Programs > Accessories > Sound Recorder
Posted on Oct 22, 2008
Blaupunkt 40/148 tv. how do i record programmes to usb ?
I could not find an owners manual for this TV but if it is like most TV's usb is for playing media, Not recording. I found a site that talks about your TV. The first reviewer explains the usb is for watching (not recording). I have a different TV and same holds true. IF you really want to record TV and have a computer with Windows 7 or Windows 8 you have capability to record to the computer and then move it to a usb to watch it elsewhere.
Customer reviews for Blaupunkt BLAUPUNKT 40 148
I hope this helps.
Jan 29, 2015 | Televison & Video
I have a HP laptop, and the internal mic has never worked? is there an upgrade i need? also, is the sound card automatically in the computer or is that something extra? i thought since it had the internal...
Changes in software, settings, or drivers can cause a microphone to stop working. Before performing any of the solutions in this document, test the equipment. After testing the equipment, select the document section that applies to the issue and follow the instructions. If the microphone recently stopped working, it may be necessary to use the Microsoft System Restore feature to correct the problem. Windows Troubleshooting Windows troubleshooting can automatically fix common problems with your computer, such as audio recording. Although it may not fix every problem, it is useful to run Windows Troubleshooting first before you manually correct problems. To run Windows Troubleshooting, follow these steps.
  1. Click Start , enter troubleshooting in the search field and select Troubleshooting from the list.
  2. Under Hardware and Sound, click Troubleshoot audio recording and then click Next when the Recording Audio window opens.
  3. Select the device you would like to troubleshoot and then click Next .
If a recommended action displays, select Apply this fix or Skip this step to continue to search for other problems. If your problem has not been resolved, continue to manually troubleshoot using the rest of this document.Test the equipment Verify that the microphone port and the microphone are working properly.
  1. Test the microphone on a known, working portable tape recorder, another computer, or a device that accepts the microphone connector.
  2. Click Start , enter sound in the search field and select Sound Recorder from the list.
  3. Click Record and speak into the microphone. Save the file to an easily-accessible location, such as the desktop.
  4. To play back the recorded sound, open the file using Windows Media Player.
  5. If the recorded sound does not play back, continue to the next section of this document.
  6. If the microphone successfully records the voice, test the record function on the computer. If the microphone does not work properly on another computer or on a tape recorder, try using a different microphone.
Dec 01, 2010 | HP Pavilion dv2000t Notebook
My brand new MXL Studio 1 USB microphone will not work in my Macbook. In System Preferences, under sound, the microphone does not show up.
There is a known problem with the signal ground of the usb chip on some computers. To resolve this error a hardware modification (additional GND connection) must be carried out inside the microphone. This should be done by qualified MXL service personel only.
Nov 19, 2010 | MXL Studio 1 USB USB Microphone Desktop...
Art Tube MP Project Series preamp how to set up comp to record
USB option does not work at all q as they said....Their use manual only makes marketing...It is not nice.
if I ask simple step by step. What is problem with it?
I fed up to use USB option ( no rec signal ) on this unit cause I have been told, better to use Yamaha mix device....
best.
V.
Sep 29, 2009 | Dual ART DPS II Preamp System with Tube...
I need to record something with Dictaphone 3750 - I have no manual and there is just a Tel. Rec button. Help
If you press and hold the 'Conf' button, the machine will record using it's built-in mic (located on the right-hand side of the machine, closer to the front). It is probably recommended to get a microphone that plugs into the machine for better recording quality. Depending on what you're recording, you could get a handheld microphone or a telephone record adapter that plugs into your phone and the back of the 3750 (press and hold 'Tel Rec' to use that).
Aug 08, 2009 | Dictaphone 3740 Desktop Cassette...
Microphone
Inspect your computer to see if has a hole somewhere that might look like a microphone. If you want to find out for sure open up your windows sound recorder from Start - Program - Accesories - Entertainment. Hit the record button and talk or yell something if you would like. You should see recorded sound wave in the middle of your sound recorder. If you do not see the recorded waves this might mean that your microphone is turned off. To turn it on just Double click on the little speaker icon on your taskbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure the microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder and try to record again. If this does not work you probably do not have a built in microphone. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
My Logitech Microphone needs software.
try here
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=us,en?selectedcrid=408&selectedcid=221#
Sep 06, 2008 | Logitech USB Desktop Consumer Microphone
Dimension E310 Microphone
its on the back on mine but if you dont have one you could get a usb mic
Jun 12, 2008 | Logitech USB Desktop Consumer Microphone
SimpleTech 250GB USB, 3.5" external hard drive. They say in manual "USING ARCSOFT® TOTALMEDIA BACKUP & RECORD. Go to the root directory on your SimpleDrive external disk drive, and...
With the usb drive connected to the pc,
Open my computer, there will be a new drive listed there (ie: f: ) or something like that.. This is your usb driver.. double click on that, and in there, there should be a setup.exe file, double click that to install Arcsoft.
Mar 29, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
