Question about Black & Decker CBM1 Grinder
How to replace the broken blade on a b&d coffee grinder.
3 Suggested Answers
  • 4 Answers
SOURCE: blade replacemen braun grinder
Insert a small standard screwdriver in the slot in the center of the bottom. Turn the blade slowly until you feel the screwdriver catch in the slot. This holds the motor still so you can simply unscrew the blade counter-clockwise. Do the same to hold the motor from turning while you screw the new blade on clockwise.
Posted on Jan 12, 2008
SOURCE: Source for replacement blade for CBG5 B&D Coffee Grinder
Unable to find any parts supplier who offered a replacement blade for the CBG5 SmartGrind Coffee grinder, the broken plastic center spindle was reconstructed around the attachment nut, and an epoxy cement was poured around the nut and over the center of the blade.
This solution has worked in testing the blade on the grinder, but how long it will hold up has not yet been determined.
T.B.
Posted on Oct 08, 2009
Need replacement part for Starbucks Barista Blade Grinder! Please help? Went to grind as I usually do but there is apparently a plastic circular part under the blades (I imagine that keeps the blades in...
your best bet is probably to search ebay for a dead one you can strip, cheaper grinders tend not to be supported with parts, personally id recommended throwing it away and getting a better grinder, blade grinders do not give a consistent grind, they are just about acceptable for grinding for a french press but anything else youll be far better off with a burr grinder
May 10, 2011 | Starbucks Barista® Blade Grinder
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
The tip on one side of the grinder blade has broken off...the machine runs well and has not had a lot of use. Can the blade be replaced; if so, how, and how much? SmartGrind CBG5.
I have two different coffee grinders and if it is just the tip of one side of the blades you can continue using it, if there is a large portion that is broken I'm not sure of that model. Hint: check to see if the part is still in the grinder set the grinder for the most coarse grind, don't turn it on, shake it upside down to see if the broken potion is still in the grinder. If you find nothing use the grinder unless the performance is less than you like.
Feb 10, 2011 | Black & Decker Black and Decker CBG5...
I am looking for a new blade for this product. Do you have them and what is the cost?
Compare the price of a new blade versus a new BURR grinder.
BURR grinders are more consistent for grinding coffee, blade grinders, you have to guess and some grounds will be finer than others.
This is the reason you don't see a BLADE coffee grinder for commercial applications.
There are some good home burr grinders (some with a timer) and not that expensive.
Jan 14, 2011 | Bosch MKM 6000 Electric Blades Grinder
Does not grind beans
This can be caused from a broken by a brken grinder motor or even broken grinder sensor.
However this can be cased by a stuck grinder from grinded coffee to the grinder bledes. So you try from the last posible problem by removing all the coffee beans from the machine and by the use of a vacum cleaner try to **** all the remainings both beans and grinded coffee. If you can remove the top panel then you will have access more direct to the grinder and by the use of painting brush and vacum cleaner you will be able to clean the grinding blades mere intesive. Try to rotate the blade manualy to be sure that they can run after the cleaning.
So now you will be able to add some beans and try the machine again. If the probelm remains then you will need a new motor.
Good luck.
Please emeber to vote for this answer
Mar 13, 2010 | Saeco Easy Espresso Machine
T.B.
Oct 07, 2009 | Black & Decker Black and Decker CBG5...
Need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Mar 08, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Blade replacemen braun grinder
Dec 16, 2007 | Braun KSM 2 Electric Blades Grinder
Black & Decker CBM1 Grinder Logo
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
Greg Cann
Greg Cann
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
