Question about Electrical Supplies
Sears 4000W 8HP doesn't idle up under load
I bought this unit about 1992 from Sears and worked fine until recently. Now it will idle but only puts out proper voltage under load when it is manually adjusted for engine speed. The linkage to the carb is ok and throtle on carb works fine.
  • 169 Answers
I posted an answer to a similar question here. You probably have a broken current transformer or a bad idle control board.
Rate me?
Posted on Dec 03, 2008
My 1992 toyota celica has a lower (about 800 rpm) and rougher idle. I recently have had issues with sputtering while driving, not stalling, but feels like it will. I recently bought gas while the gas...
If you feel that before getting the fuel car was fine, and something has suddenly happened after re- fueling the car, it may be due to the contaminated fuel or the clogged fuel filter.
Nov 29, 2012 | 1992 Toyota Celica
1992 Lexus S300 Automatic. Car drive perfectly fine. Problem is sometime when I start the car, it should idle and shut off within 5 seconds. Doesn't happen all the time, just sometimes. Sometimes it d
Without any other symptoms it is hard to diagnose; could be water in the fuel or a plugged up air filter, that effects idle first, take it out and see if it idles fine, if so get a new one. Take out fuel filter and dump in a glass bowl and analyse for water... get a new one... Is it different when the engine i hot or cold?
Dec 05, 2011 | Lexus SC 300 Cars & Trucks
1992 16V - idles fine, drives fine. Only when foot of the gas jer
idle air speed control valve(iac),too low idle or driveline problem like play in the drive shafts. if you put it in park and give it to say2500 rpm and let go of the throttle,does it return to 900rpm?if it dips down to 5 or 600 then to 900 the iac is bad.
Jul 13, 2009 | 1992 Volkswagen GTI
1992 subaru legacy wagon overheating
Sounds like a small leak at head gasket or Water pump going. Small leak on head gasket under idle will leak slow, But when under load will leak faster. Have a compresion check done on the cylinder to locate. Also you might want to try a presure test on the coolant system. Good luck and hope this helps to get you going again.
Mar 25, 2009 | 1992 Subaru Legacy
My 1992 3.2 petrol trooper starts an idles fine
check for spark at the coils under load. May have to change some ignition coils.
Feb 23, 2009 | 1992 Isuzu Trooper
Electrical Supplies Logo
142 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
