Question about Vehicle Parts & Accessories
Renault Megan Key.
Immobilizer wont work, dropped key, have taken it to garage, but they say capacitor has broken, and I need a new key. Can it be fixed?
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
alicantecoli
  • 22306 Answers
SOURCE: Renault Megane key will not open doors
work it manually and it should work ...ie put the key in the door and open and lock the door 3 times slowly then jump in and try to start within 15 secs .if it doesnt work then be prepared to be fleeced and lay the golden egg at the dealers
Posted on Nov 23, 2008
SOURCE: renault megane key fob wont work
I had the same problem with mine
your key fob is now out of sync with the ECU to sync them just follow this link (renault will charge up to £180 for new key and to sync it)
http://renaulthelp.110mb.com/ImmBypass.html
Posted on Jan 09, 2009
bitchn65cuda
  • 70 Answers
SOURCE: owners manual for renault megan required
here is an online free workshop manual....GOOD LUCK!   http://www.scribd.com/doc/7814761/Renault-Workshop-Repair-Manual-Manual-Gearboxes
Posted on Apr 26, 2009
Mr BrokRench
  • 1623 Answers
SOURCE: immobilizer
If there is a blinking car icon with an "X" over it. This icon means the Immobilizer has been activated and hence won't allow the car to start. It could be due to a bad SCU, Start Control Unit. The SCU is actually the ignition switch on these cars.
Most of the time it's triggered by the anti-theft system..You can try this trick i learned that the dealers won't tell you...try locking and unlocking of the doors five times with the remote to reset the immobilizer and see if this helps.
Good luck..i hope this helps...please take a minute to rate me a fixya.
Posted on Jul 15, 2009
MECP Guy
  • 344 Answers
SOURCE: how to disable honda accord 1997 Immobilizer
I show immobilizers where only started in the 1998 accords, if you have a remote starter and they used a key in the box bypass all you need to do is find the box under the dash open it up and use the key
Posted on Jan 31, 2010
Renault Kangoo 1.9d immobilizer light not swichting off/non start fault codes indicate df014 and df004 A second hand motor was fitted
The code in the key could be the problem. Sometimes they get weak.
try taking of the plastic cover around the key barrel and you should see a plastic ring around the key barrel, try sliding it close to the key if it then works it means it's the key needing replacement
Jan 04, 2017 | Renault Kangoo Cars & Trucks
How do I get into a Renault Senic with flat battery and broken key
Can you get another key cut at a Renault garage!
Oct 14, 2014 | Cars & Trucks
Renault Twingo with a key that activates the central locking and engine immobilizer, today I flattened the battery by leaving the lights on, I used jump leads to charge the battery, all works apart from...
yes i know what these cars are like ,a right pain in the you know where and the only solution is to calkl a truck and have it taken to the dealer ,its a europeon vehicle and uses encrypted software ,Now on earlier models you still get a spark and the immobilisor only shuts of the fuel pump so if you try running a hot wire direct to the fuel pump it should start anyway ,check for polarity on the sender unit where the fuel pump is ,access can be gained from under teh back seat on this vehicle ,if you do have to have it re-programmed then once its running with teh key cut the thrid wire on the immobilisor reader in the drivers side footwell with teh engine running and then it thinks it still has the key in the ignition .I HATE RENAULTS
Feb 15, 2011 | Renault Le Car Cars & Trucks
Renault megan card not detected :(
Hi ,This is a common renault problem,If you have a spare card you need to try this first other wise its a trip to renault and lots of money to replace your cards and reprogram the system,sorry there are no other options when the card fails or the card reader fails only Renault have the security software to re-program the system.
Jul 10, 2009 | 2003 Renault 181
My renault laguna 1999 rt remote key fob wont work?
IF YOU TYPE 1999 RENAULT LAGUNA REPROGRAMME KEY INTO A GOOGLE SEARCH, YOU WILL BE ABLE TO PRINTOFF INSTRUCTIONS TO REPROGRAMME THE KEY TO THE KEY READER.THE IGNITION NEEDS TO BE OFF TO DO THIS
Jul 09, 2009 | 2004 Renault 181
I need to put new baterys in my key fob for my renault megan coupe 1998 can i just swap the baterys at home thank you
go to any auto or batteries stores and they will replace the batteries for u.....or u can do it yourself....
Mar 07, 2009 | 1986 Renault Sport
Renault Megane sport 1.6 2000
gearbox needs changed or clutch release bearing
Oct 03, 2008 | 2000 Renault 181
Renault megane dynaique 2003 cutting out and wont start
the carb needs cleaning, thats what it was on mine, i thought it was spark plugs but took it back to main dealer and they fixed it but cost £££
Oct 03, 2008 | 2003 Renault 181
Vehicle Parts & Accessories Logo
53 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
