Crt tv model RC-4120PS dead high pitch whine
Ok..... tv dead high pitch whine coming from the chopper transformer. There are output voltages of 135(B+), 10v and another 10v. Horizontal output transistor fine.
Voltages on lopt not present this a +25v, +15v, +180v, abl, afc, no scr aswell as high voltage but the is present at the input terminal of lopt.
Power led is on, however when bringing the tv out of standby these voltages above drop, the 135vdc drops to 95vdc.
Not sure if its the lopt or something else
Plz help
Regards
4 Suggested Answers
  • 2334 Answers
SOURCE: directv h20 receiver has low volyage to the lnb.
Check inside the receiver for a defective LM317 IC or a TIP42C transistor, but before that you should check for proper voltage from the power supply to that IC.
LM317/TIP42C control the switching of voltages that power up the LNB, you should be getting 14 volts for vertical channels and 18 volts for horizontal.
Good Luck.
Posted on Mar 08, 2008
CAYPIANAN
  • 227 Answers
SOURCE: RECOR COLOR TV dead high pitch whining noise
you have a short in the horizontal ckt,look for diodes,horizontal output it might be damage or a bad cap, if not the fly-back transformer is gone.
good luck
caypianan@yahoo.com
Posted on Oct 27, 2008
SOURCE: Digital Stream HD 3150 OTA HDTV tuner does not operate
Disclaimer: The answer provided is entended for you to have some basic electronic knowledge and soldering skills.
Troubleshooting switching power supplies just sucks, but there are ways of finding the fautly componets. In my case, a visual inspection found 2 bad capitors, the tops bulging open and oosing goo. If you look at the tops of any other caps they should be flat. You can also note faulty caps by discoloration of the circiut board itself. I had one other faulty cap on my supply that, by visual inspection had been running hot. After replacing the defective caps (Nichicon 105c) I went with an ohm meter, and checked the smaller transistors for faults. Q1 a very common transistor was bad (2N3906) with a base emitter short. In conclusion, it's the cheap caps that are at fault, sometimes taking the silicon with them as they short out. The unit is now working.
As an added note, I understand that there is a Radio Shack branded version of the HD3150 as well.
Posted on Jun 12, 2010
I have a Hitachi Ultra Vison 57S700 2004 model, the TV has had a slight high piched whine for a couple of weeks and today the screen went green then black and the sound was gone. When it is turned on the...
This tv is under five years old?Yes,it is worth fixing.Over five,i would compare the prices for a new LCD tv and the quote priced from the Tv Tech.for the old tv.This tv have high voltage problems around the Deflection circuitries area.Could be any things burn in this area.The high pitched whine sound,i'm sure it is from the FBT-the high voltages flyback transformer,high voltages current have no where to go.Must hire a tv tech. to troubleshoots and replace parts on the Deflection circuitries area.Also the FBT could be dead too,because HV Current bounces back forth and have no where else to go.The prices to troubleshoot unknown problems is about $400 bucks and plus cost of replacement of parts.
Dec 04, 2010 | Hitachi 57S700 57" Rear Projection HDTV
High pitch sound coming from circuit board, cannot
First, you will want to isolate the problem. Is it feedback from an AC outlet you have it plugged into? Is it a recent noise that just started with no changes to Tv or its environment, then you may want to consider that a circuit is going and decide if it is worth repairing, You should find that type of fix at a shop for under $100
Sep 27, 2009 | RCA F35317 35" TV
High pitch whining,
Ur flyback transformer it have cold soldier or is dead.U also could have prob. with ur power ic inverter board too.
Aug 16, 2009 | Sony KV-32S45 32" TV
High pitched noise from inside the TV when picture comes on
Hello randapaint,
This might be from the IHVT (Integrated High Voltage Transformer), or more specifically a short in the IHVT causing it to arc, producing the high pitched whine, you are hearing. Take the back off of the TV and try to detect where the sound is coming from, more then likely you will notice it coming from the section that contains a large component with a large red cable coming from it, to the top of the CRT (picture tube). Replace the IHVT (with the exact same model) if it is bad.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 07, 2009 | Televison & Video
good luck
caypianan@yahoo.com
Oct 20, 2008 | RCA F32650 32" TV
Dead KONKA 21 inch TV
try Check first all the output voltage in the secondary of the chopper transformer if regular voltage acquire. check secondary switching circuit feedback towards the opto isolator and syscon.
Assuming that HOT is OK.
Nov 01, 2007 | Televison & Video
RCA 35V432T Dead Set
Check for a high voltage power supply section of your TV set...
Especially in flyback transformer.Be careful to do so because the output voltage of the flyback transformer is almost thousand volts.
Oct 17, 2007 | RCA 35V432T 35" TV
Will not power up
your problem is in flyback or high voltage section failure.
  • check horizontal output transistor
  • check fly back transformer.
  • check for supply to horizontal section as high voltage from power supply may create such problem
  • as this failure is due high voltage section so it is better to take skilled technician help.
  • good luck.
Oct 15, 2007 | Toshiba 27A51 27" TV
27 inch tube tv won't stay on
You have a problem is in your horizontal section which also is part of your power supply. The high pitched whine is from the Intergrated High voltage transformer (also called the flyback transformer). This sound occurs when the freuency of the transformer changes and or the voltage gets too high. The click occurs as a result of the drawing of excessive current by the HOT Horizontal output transistor. This is repairable, but requires the correct equipment and a schematic.
Sep 19, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
