Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
Put detergent in a dishlex
By jack Spar on Oct 22, 2008
Put detergent in a dishlex dishwasher now the pump stays on a& the dishwasher does not work, just displays a flashing red eco light
Best Solution
posted on Oct 22, 2008
Very Helpful)
huuum
Rank: Wiz
Rating: 85%, 660 votes
Hello jack SparWelcome,
You said, Put detergent in a dishlex dishwasher now the pump stays on a& the dishwasher does not work, just displays a flashing red eco light
What is the BRAND and MODEL Number and year of your dishwasher. Model can be found on sticker inside.
Did you turn off the power at the breaker for 5 minutes to see if it resets the system?
If this is not the case, Please explain!
What do you mean the pump stays on?????????????????????????
If it is not getting water and not working then these may be the problem
Water source turned off
Check to ensure the water source is turned on and water is getting to the water inlet valve.
Float switch
The float switch allows water to enter into the machine to a point where the float will rise up off of the switch and disconnect power to the water inlet valve. If the switch is defective or the float is stuck in the up position, the water will not enter into the machine
Defective water inlet valve
If there is 110v across the two wires on the water inlet valve when the machine is set to fill, the valve should open and the water should enter into the machine. If the water does not enter, the valve is defective.
Defective Timer
The timer is a series of switches that controls all machine functions. If one of the contacts in the timer is defective, the machine will lose that function. knowledge of the the use of a vol/ohmmeter is essential to testing the timer as well as the ability to read the timer sequence chart that is supplied with the machine. In most cases this requires a professional technician.
Huuum
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
hi my fridge freezer has stopped working, the fridge light is still on but it will not freeze or... (More)
Answer
Siemens SL34A006UC Dishwasher not cleaning top rack
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in New York, NY
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
