Cannot access internet
Ip address installer not installed...
where can i find the solution...
where to download the software...
    Sergeant:
    Champion:
  • 322 Answers
Put into your web search ip address finder and you should find it there
Posted on Oct 22, 2008
Problems big problems
Verify that TCP/IP (or other appropriate protocol) is properly installed.
  1. Open Control Panel and open Network Connections or Network and Sharing Center, then click Change adapter settings. The wireless card should be present as Wireless Network Connection.
  2. Right-click the appropriate Wireless Network Connection and select Properties. In the Properties window, make sure that the Internet Protocol (TCP/IP) or Internet Protocol Version (TCP/IPv4) is installed.
  3. If TCP/IP is not installed, click Install, click Protocol, and then click TCP/IP.
  4. Once installed make sure that Obtain an IP address automatically, and Obtain DNS server address automatically are checked (if using DHCP). To verify this, highlight the TCP/IP protocol, and select Properties.
Note: Only use a Static IP Address if your network/Service Provider requires one.
8.Verify the TCP/IP address.
  1. Click Startwindows%20start%20button.png, select All Programs, select Accessories, and then click Command Prompt.
  2. Type the command, ipconfig. This will list the IP address for the local machine.
  3. If this returns a 169.x.x.x or 0.0.0.0 address, then type the following commands;
    ipconfig /release and then
    ipconfig /renew.
    You should then receive a TCP/IP address appropriate to your network, along with a Default Gateway address.
  4. Try to communicate with it by typing this command ping x.x.x.x where x.x.x.x is the IP address of the Default Gateway. (i.e. ping 192.168.1.1)
  5. If this does not give a reply (see the example in step 9) or you did not receive a TCP/IP address, go to the next step.
  6. If you are connecting wirelessly, but receiving an IP address, your wireless router/Access Point might need to be reset (unplug power for a minute, then plug back in), or maybe defective. Please consult your wireless router/Access Point manufacturer for further assistance.
9. Ping the loopback address.
  • Click Startwindows%20start%20button.png, select All Programs, select Accessories, and then click Command Prompt.
  • Type the command, ping 127.0.0.1. This will send a message to the internal network stack on the machine. You should see a response like this:
    Pinging 127.0.0.1 with 32 bytes of data:
    Reply from 127.0.0.1: bytes=32 time<10ms TTL=128
    Ping statistics for 127.0.0.1:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
    Approximate round trip times in milliseconds:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
  • If instead, you receive errors, then there maybe system corruption or malware installed preventing networking from functioning properly.
  • 10. Verify that the hardware is functioning using diagnostics.
    • Check the web site, http://support.lenovo.com. Choose Download Drivers and Software and enter your particular system. Then under Diagnostic choose the download for your system. If diagnostics fail, please contact warranty support for resolution.
    • Run diagnostics for third party wireless card.
      Note: If using another manufacturer's product, then consult it's documentation on how to run the diagnostics for the wireless card.
Mar 10, 2014 | Lenovo ThinkPad R60 with Wireless Wide...
How to change IP address, my player will not allow me to change it so it can access my wireless internet.
Hotspot Shield free VPN is the best solution to Hide IP Address. It is available for Windows, Mac, iPhone and Android. Also it is very easy to install and use.
Sep 22, 2012 | Vizio VBR120 Player
I have an Australian hotmail address and i am in Holland and can not access my account from holland. Why?
Is the PC/Laptop you are using install with any "Security Programs" eg . PeerGuardian or other Internet security (firewall) that might be blocking the IP addresses you wish to access?
Apr 01, 2011 | Computers & Internet
No picture when using IP address on Internet Explorer
After you log in their should be a config screen.
Suppert can be found in Panasonics FTP server.
1000's of apps and manual for this camera and more.
ftp://ftp.panasonic.com/pub/Panasonic/cctv/downloads/
Aug 28, 2008 | Panasonic BL-C1 Network Camera
Internet Exporer
"Obtain ip address automatically" indicates that it will use DHCP. DHCP will also provide the Internet Gateway address, which is required to access anything outside your local subnet (like the internet). You can set your IP address manually, but you also have to enter the Internet Gateway and DNS server addresses ( and you have to know what those addresses should be for your pc ).
Feb 17, 2008 | Computers & Internet
F5d7230-4 router
The driver software that you are installing is probably not for vista
Try to download an updated version for vista
Dec 02, 2007 | Belkin (F5D7230-4) Router (587009)
Static IP on machine, no outside access
Double check that the Default Gateway in TCP/IP properties is the routers LAN IP address (By default this is 192.168.1.1) Without a gateway installed, there will be no Internet access. After verifying this go to Start>Run and when the "Run" window appears type command into the "Open" Field, then click OK Once the Command prompt appears type in: ping 207.69.188.185. If you don't get a reply, the gateway is not installed. If there is a gateway already installed, check for any third party firewalls that may be installed on your computer. These can sometimes block Internet access. For more information please see the related article on assigning a static IP address behind the router. If still having problems, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL and Voice...
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Computers & Internet Logo
303 people viewed this question
David Payne
David Payne
