Question about Brother IntelliFax-2920 Plain Paper Fax, Copier and Phone , 33.6 Kbps Modem Laser
Brother FAX-2920 sending-receiving problems
Yesterday we have moved fax machine to diferrent room reconnecting telephone line, so fax machine is on the same line but for some reason doesn't work anymore it's dialing the no. I can hear fax sound but it's not transferring anything it's seems that machine is not detecting fax tone. after while on the display apears 0 and error report is printed. when receiving fax dispalay shows mssg. receiving but nothing is printeg and on the other fax machine error report is printed.
  • yanogore Oct 22, 2008
    It is plugged to line port, I can hear dialing tone but machine is not transfering data.
    It is connected to LINE port.
  • 2,120 Answers
Make sure you are plugged into the LINE port of the fax machine.
Posted on Oct 22, 2008
  • Leroy Elliott
    Leroy Elliott Oct 22, 2008
    Sorry, have you tried taking the machine back to the original location to try it out? Very weird problem.
Brother 2920 copy problem
Have you tried going to Brother Website. You might have to down load a driver for yoy unit
Jul 07, 2012 | Brother IntelliFax-2920 Fax
Brother intellifax 2920 manual
Send me an email to and I will send the manual to you right away. Please put "Brother Fax 2920 Manual" as the subject. Lawrence Brown
Nov 28, 2011 | Brother IntelliFax-2920 Plain Paper Fax,...
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
Am trying to send a fax on brother 575. I placed the paper face down -- dialed the telephone number and pressed fax start. The receive messages comes up on my machine and the fax does not go...
My first assumption would be, since this appears to be a new fax machine for you, to ensure that the telephone line is plugged into the correct port on the fax machine. There are usually two ports, a telephone port and a line port, you want the telephone line to be plugged into the "line" port.
Let me know.
Nov 05, 2010 | Brother Office Equipment & Supplies
What does comm error 20 01 mean on my brother 2820 mean? how do I fix it?
This means that your Brother machine experienced a communications error when sending or receiving a FAX. This is generally caused by either interference on the line, phone line connection or another device on the line.
Try resending the documents and see if the message no longer appears.
If the message still appears, there may be a problem with the way the Brother machine is connected or you may have a bad telephone line. Disconnect any other equipment on the telephone line, i.e. answering machine, modem, extra telephones, switching devices, adapters, etc. Make sure the telephone line is connected directly from the jack (socket) on the Brother machine labeled "Line" to the telephone wall jack (socket).
Try resending again. If the transmission is successful, the problem was created by the connection of the Brother machine and the other devices on the line. Reconnect the other pieces of equipment one at a time to see which is causing the problem. If the error continues to appear on the report, try connecting the Brother machine to a different telephone line or have the line checked by the telephone company.
Nov 03, 2010 | Brother IntelliFax-2820 Laser Fax
How do I receive faxes with the 240c
Manual mode turns off all automatic answering functions unless you are using the Distinctive Ring feature or you are using an external answering machine on the same line as the Brother machine.
*Distinctive Ring is a function of your Brother machine that allows a person with one line to receive fax and voice calls through two different phone numbers on that one line. Brother uses the term "Distinctive Ring," but telephone companies market the service under a variety of names, such as Custom Ringing, Personalized Ring, Smart Ring, Ring Master, Ident-a-Ring, Ident-a-Call, Data Ident-A-Call, Teen Ring, SimpleBiz Fax & Alternate Number Ringing and BT Call Sign.
  1. Setting the Receive Mode
    1. Press Menu.
    2. Press the up or down arrow key to select Initial Setup.
    3. Press OK.
    4. Press the up or down arrow key to select Receive Mode.
    5. Press OK.
    6. Press the up or down arrow key to select Manual.
    7. Press OK.
    8. Press Stop/Exit.
Receiving Faxes in Manual Mode
  1. Lift the handset of a telephone that is on the same line as your Brother machine.
  2. When you hear the sending machine's fax tones (short beeps that occur at regular intervals), do one of the following:
    • If the telephone you answered is near your Brother machine or connected to its EXT jack(socket), press Black(Mono) Start or Color(Colour) Start.
    • If the telephone you answered is not connected to or near your Brother machine, press *51 (*91 for New Zealand) on its dial pad.
  3. Your Brother machine will produce receiving tones.
  4. Replace the telephone handset. Your Brother machine will begin to receive the fax.
< Easy Receive (Fax Detect) >
The Easy Receive (Fax Detect) feature allows you to receive faxes in Manual Mode by simply lifting the handset of a telephone that is on the same line as the Brother machine. Your Brother machine will automatically generate fax receiving tones, at which point you can replace the telephone handset and wait for your fax to be received and printed.
Your Brother machine's Easy Receive (Fax Detect) feature is turned ON by default. To adjust your Brother machine's Easy Receive (Fax Detect) setting, please follow these steps:
  1. Press Menu.
  2. Press the up or down arrow key to select Fax.
  3. Press OK.
  4. Press the up or down arrow key to select Setup Receive.
  5. Press OK.
  6. Press the up or down arrow key to select Easy Receive or Fax Detect.
  7. Press OK.
  8. Press the up or down arrow key to select On, Semi or Off. *In some brother machines, Semi may not be in the options.
    If you choose Semi, your Brother machine will only answer an incoming fax if you answer using its handset or by pressing the Hook, Hook/Hold, Hold, Speaker Phone or Tel/R key on its control panel.
  9. Press OK.
  10. Press Stop/Exit.
Note Here are a couple of points to keep in mind:
  • If Easy Receive (Fax Detect) is ON, but your Brother machine doesn't automatically answer the incoming fax when you lift the extension telephone's handset, press *51 (*91 for New Zealand).
  • If you send faxes from a computer that is on the same telephone line as the Brother machine and the Brother machine intercepts the calls, turn Easy Receive (Fax Detect) OFF.
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | Brother Multi-Function Center MFC-240C...
If you can send a fax and receive a fax at any point, your fax machine is running perfectly. There is a phone line problem somewhere
Jul 04, 2010 | Brother IntelliFax-2920 Fax
Can send but cannot receive
try to make its receive mode to FAX mode
Apr 16, 2010 | Brother IntelliFax-2920 Fax
Brother 2920 ~ I can not receive faxes
Call your fax machine from a regular phone to see if it rings / answers.
Mar 12, 2009 | Brother FAX-2920 Plain Paper Laser
hello! i just checked the dervice manual for the rror202 that you said that you are having did not find that code could you clarify thanks brother sr tech
Jan 22, 2009 | Brother IntelliFax-2920 Plain Paper Fax,...
Brother IntelliFax-2920 Plain Paper Fax, Copier and Phone , 33.6 Kbps Modem Laser Logo
315 people viewed this question
James Cagle
James Cagle
Jim Keysor
