Question about Roper RAX4233PQ Top Load Washer
Washer won't drain
Roper AX6245 fills and agitates fine, but when it gets to the spin cycle, it just quits. There is no moter running or other sound. I tried all the washing cycles, but no luck.
  • 1 more comment
  • David Lavery Jul 30, 2006
    To Catriver-My switch is burnt out! Button would not come up and there was a little hole in the back, which I opened wider and some burnt spring and other stuff fell out. This part on the parts sites has two prongs on one side and one on the other. Mine only has one on each side, and I only see one lead for each side. what should I do? I appreciate your advice.
  • Anonymous Mar 15, 2014
    roper washing machine stuck in agitate cycle
  • Anonymous Mar 23, 2014
    washer making a grinding clicking sound and won't spin, takes a long time to drain, get stuck on lock lid and sometimes skips was cycle
    President:
  • 878 Answers
Mustache, sounds like you have a broken lid switch. No spin, no drain usually a sign of this. Check to see if the actuator is making the lid switch, or the switch itself is bad. Part number for the switch is 8318084. Catriver, post back.
Posted on Jul 30, 2006
Still not working whats next
Posted on Apr 26, 2008
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
I have a Roper ras7133kq1, top load washer. About 3 months ago I replaced the lid switch because it wouldn't drain or spin. Now it will ONLY spin, it won't fill with water or agitate, the only way...
If it won't fill you will need to replace the "water inlet valve" on the back of the unit. The unit will only agitate if it gets the signal from the water level pressure switch.
Here is the valve to order.
Nov 22, 2012 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Won't go to spin cycle-water still in
sounds like your lid switch is defective. if it will fill and agitate but not drain/spin, the most common problem is the lid switch....your machine thinks the lid is open
Dec 29, 2008 | Roper RAX4232KQ Top Load Washer
Roper RAL6245AW0 Washer Won't Drain or Spin
We have a Kelvinator Washing Machine that just won't drain , but fills , agitates , & spins just fine. What shall we do?
Oct 13, 2008 | Washing Machines
Roper(whirlpool) washer will not spin
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
518 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
