Question about IBM ThinkPad T20 2647 Notebook
PC CHIP Motherboard
Good day, I have 2 PC Chips and MSI motherboard which colud power but no post screen nor beep, every thing remain dead but all light indicators will be on. checked all other component with another board, they working. I'm suspecting that the BIOS ROM is dead. how do I solve this problem? if it requires changing of ROM BIOS where do I get it from? Help Pls
    An expert who has written 3 tips or uploaded 2 video tips.
  • 86 Answers
Now by PC chips do u mean CPUs? because if so then yes your motherboard is dead but im not sure if it would be BIOS related. There should be a battery somewhere, one like a wristwatch but bigger and flatter on the motherboard, look for it and replace it and test if it works, otherwise it is most likely your motherboard is dead and you need a new one. There is a way of fixing the BIOS if that is the problem. Its called Force Flashing BIOS. I Don't know too much about this but apparently its not hard. Google It and see what you come up with
Hope This Helps
Posted on Nov 21, 2008
How to recover Motherboard Bios?
Bios updates are dangerous because losing power can result in a dead mo bo. All U can do now is try to get another loaded bios chip for your motherboard.
Oct 17, 2015 | MSI FM2-A55M-E33 Socket FM2 mATX...
3 Short beep and 1 long beep and blank screen. My
That means there is s problem with the RAM on the motherboard (Problem lies with the Memory Chip). This could be a result of a Memory chip that has not been inserted properly or it has moved away from its contacts on the motherboard. This will be fixed by opening up the RAM compartment and remove the memory chips and replace them back carefully. Try to switch on your laptop again. Make sure that when you are doing all this, the computer is off and the charger is not connected to it. This I hope will solve your problem.
Aug 29, 2013 | Lenovo Computers & Internet
Hi My computer won't Boot up it has a msi km2m motherboard I heard 1 beep itb does not display anything on screen not even the Bios does not appear the ddr is seatedv and tight I already changered the...
Hi Sue.
Remove the power cord from the back and then take out the motherboard battery for half an hour (you need to remove the side panel from the case to access the motherboard) after the half hour is up pop the battery back in and connect the power cord, see if that resolves the problem.
The fact that you can hear 1 beep indicates that all is fine so I doubt you have fried the BIOS chip.
Also, if you have a stand alone graphics card installed remove that and clean the contacts, then reinsert it.
Plesae post back if you have more problems.
Good luck.
Aug 12, 2011 | MSI KM2MCOMBOL-6738-010 Motherboard
Got a problem with my pc. It suddenly intermittently doesn't POST. It boots 1 out of 15 times. When not booting, it turns on, no beep, after 2 seconds, turns off. Then I have to wait around a minute before...
It may be that your motherboard is dead. I have had this problem before. Here are some things you can do to troubleshoot:
Remove video card then plug back in or try alternative video card if you have one.
Isolate each memory stick in your RAM. This may identify RAM problems.
Try a different power supply in your PC or at least reconnect every connection for your current power supply.
Try clearing the CMOS by switching the CMOS clear jumper
Mar 13, 2011 | MSI AM3 890GXMG65 Motherboard (7642010R)
Pc keeps beeping 3 times and nothing on the moniter
remove the RAM(MEMORY CHIPS) from *********** board and reinsert.if the problem is same replace the chips,get new chips.mostly cleaning the golden lines on the chip with pencil/school rubber solves the problem.
No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
One beep is a normal POST. That means everything is fine. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. Six, seven and eight beeps. Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard. Nine beeps mean the BIOS is bad. Replace the motherboard. Ten beeps means the problem is in the CMOS. All chips need to be replaced.
Jul 11, 2009 | Asrock 775i65G Motherboard
MSI K8N NEO2 Platinum NOT Posting + No beep + No display
try to test the CPU on another machine ...
or at least remove it and reinsert it.
But if u say that u reseted the BIOS an it still not doing the post, it just could be that the motherboard is out !
It can also be the PSU as u say, but i doubd it ! Try to remove all hard drives, cdroms, etc... to limit the power usage... and see if it passes the post.
U can also try to remove the motherboard from the computer case and put it on an insolating surface and than try to boot (sometimes shorts appeare betwen the motherbord- case - psu)
Jan 08, 2009 | MSI K8N NEO2-Platinum (MS7025) Motherboard
PC Chips M848A dead, no screen output or blips
I had the same problem. I bought the M848A from Newegg in an attempt to save my trusty Athlon 2600+ CPU and a fancy Raedon 512mb AGP card which I salvaged out of my old broken down system. I thought it would be a good time to update the RAM so I bought 2 gigs of OCZ 3200 DDR400 to go with.
(1) First the damn thing wouldn't boot past the post screen. It would simply cycle thru post over and over. Fixed: The microsoft XPpro operating system was corrupt. The new board hated the old configs from the previous system. After trying (and failing) a os repair, I ended up simply doing a clean intall with great results. Board was stable worked great for a week. Only had one glitch...
(2) The board would only recognize and post ONE of the 2 gigs of ram I bought. I raided all the CMOS settings, and downloaded all the user manuals I could get a hold of and found no answers to this curious problem. On a whim, I opened the case and switched their locations back and forth which led me to...
(3) Lights on, no one home. All the lights came on... power, HDD, cd drives... all the fans worked: case, CPU, graphics card... but the screen would remain blank/unpowered and no post menu would come up. Seemed like it wanted to work, but simply stopped short of booting up. THIS WAS YOUR PROBLEM?!?? On a hunch, (more an angry impulse) I reached over and popped an old Mushkin Technologies (PC 3200 400DDR) 512mb out of my old dead mobo and slammed it solo in the primary memory slot. Bingo. Fired right up.
The board appears to be testy with its RAM... If it fails its initial memory test, it will not post. The screen will not come on. I'm not 100% certain this is the final solution to the problem... I'm still playing with it. My questions now are.... do I have dead RAM? Chip compatibility issues? Perhaps the PC Chips support techs on their website have some practical advice on this issue. I'll keep you posted if you like.
Dec 26, 2008 | PC Chips M848ALU Motherboard
Bios problem
Standard Original IBM POST Error Codes1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
PCHELL.COM Newsletter
If you would have read my E-book on Internet Security, you may not have ended up in PCHELL. Join the mailing list and receive your free E-book now.
Tools for Removing Spyware, Adware, and Malware
Other Pages
Spyware/Adware Removal Help
MSBlast.exe Worm Removal
Welchia (Dllhost.exe and SVCHost.exe) Worm Removal
Uninstall McAfee Instructions
Uninstall Norton Instructions
Uninstall Avast Instructions
Uninstall AVG Instructions
Uninstall Antivir Instructions
How to Manually Run the Microsoft Malicious Software Removal Tool
Bloodhound.Exploit.6 Virus Removal
MyDoom Virus Removal
MiMail.C Virus Removal
Swen Worm Virus Removal
SoBig.F Worm Removal
Dumaru Virus Removal
BugBear.B Worm Removal
SoBig.E Worm Removal
Pop Up Ad Removal Info
KAK Worm Removal
MiMail.A Worm Removal
W95.MTX Virus Removal
Snow White Virus Removal
BadTrans Trojan Removal
Wininit Virus (Bymer Trojan)
Happy99 Worm Removal
VBS Netlog Worm Removal
Pretty Park Worm Removal
Sasser Worm Virus Removal
Backdoor SDBot.H Trojan Removal
VBS.Loveletter Help
Computer Security Information
Back Orifice Information
PC HELL Main Page
IBM POST Diagnostic Code Descriptions
100 - 199 System Board
200 - 299 Memory
300 - 399 Keyboard
400 - 499 Monochrome Display
500 - 599 Color/Graphics Display
600 - 699 Floppy-disk drive and/or Adapter
700 - 799 Math Coprocessor
900 - 999 Parallel Printer Port
1000 - 1099 Alternate Printer Adapter
1100 - 1299 Asynchronous Communication Device, Adapter, or Port
1300 - 1399 Game Port
1400 - 1499 Color/Graphics Printer
1500 - 1599 Synchronous Communication Device, Adapter, or Port
1700 - 1799 Hard Drive and/or Adapter
1800 - 1899 Expansion Unit (XT)
2000 - 2199 Bisynchronous Communication Adapter
2400 - 2599 EGA system-board Video (MCA)
3000 - 3199 LAN Adapter
4800 - 4999 Internal Modem
7000 - 7099 Phoenix BIOS Chips
7300 - 7399 3.5" Disk Drive
8900 - 8999 MIDI Adapter
11200 - 11299 SCSI Adapter
21000 - 21099 SCSI Fixed Disk and Controller
21500 - 21599 SCSI CD-ROM System
AMI BIOS Beep Codes
 1 Short Beep One beep is good! Everything is ok, that is if you see things on the screen. If you don't see anything, check your monitor and video card first. Is everything connected? If they seem fine, your motherboard has some bad chips on it. First reset the SIMM's and reboot. If it does the same thing, one of the memory chips on the motherboard are bad, and you most likely need to get another motherboard since these chips are soldered on.
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard.
3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above.
4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
5 Short Beeps Your motherboard is complaining. Try reseating the memory and rebooting. If that doesn't help, you should consider another motherboard. You could probably get away with just replacing the CPU, but that's not too cost-effective. Its just time to upgrade!
6 Short Beeps The chip on your motherboard that controls your keyboard (A20 gate) isn't working. First try another keyboard. If it doesn't help, reseat the chip that controls the keyboard, if it isn't soldered in. If it still beeps, replace the chip if possible. Replace the motherboard if it is soldered in.
7 Short Beeps Your CPU broke overnight. Its no good. Either replace the CPU, or buy another motherboard.
8 Short Beeps Your video card isn't working. Make sure it is seated well in the bus. If it still beeps, either the whole card is bad or the memory on it is. Best bet is to install another video card.
9 Short Beeps Your BIOS is bad. Reseat or Replace the BIOS.
10 Short Beeps Your problem lies deep inside the CMOS. All chips associated with the CMOS will likely have to be replaced. Your best bet is to get a new motherboard.
11 Short Beeps Your problem is in the Cache Memory chips on the motherboard. Reseat or Replace these chips.
1 Long, 3 Short Beeps You've probably just added memory to the motherboard since this is a conventional or extended memory failure. Generally this is caused by a memory chip that is not seated properly. Reseat the memory chips.
1 Long, 8 Short Beeps Display / retrace test failed. Reseat the video card.
Oct 18, 2008 | Computers & Internet
Pc-chip m957g
sounds like the motherboard has failed. I had those same symptoms this summer. Replaced m/b and it's good again.  Did you count the 'continuous' beeps? That's a code to say what is wrong.
Oct 14, 2007 | Pc Ware PC CHIPS: PC-Chip M957G...
Beeps along
Hi, Past experiences with different models of Asus of this type of problem indicates BIOS problem. I have not come across the same symptoms with ECS, Intel, MSI, Gigabyte or others but once in a Samsung. The beeping sound is actually up down (like old ambulance siren). I have tried some correctives measures with varying results: 1. Clean the motherboard with a strong solvent, hot air dry with particular attention to the BIOS chip; 2. Resolder the bottom side of the motherboard particularly the chip holder of the BIOS; and/or 3. Flash the BIOS chip using an identical motherboard or an EPROM programmer. If all else fails, am afraid you have to replace your motherboard. Good luck and pls post back how things turn up or if you need further information. Kind regards.
Aug 20, 2007 | ASUS Intel 815E Chipset TUSL2 (TUSL2 SWA)...
IBM ThinkPad T20 2647 Notebook Logo
119 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
