HI,my name is Monica and unfortunatelly i can't get in my computer,it is not recognizing my password,says that Group Security failed the log on...and any time i try to get in i can't ..it says about reset your password ,but i don't have a reset password disk...what can i do ?please help me ..
  • juravleamoni Oct 22, 2008
    HI,THANK YOU VERY MUCH FOR YOUR HELP..I WILL TRY THIS TODAY HOPE IT WILL WORK ,BUT JUST IN CASE CAN WE WRITE E-MAILS?I WILL GIVE YOU MY E-MAIL ADRESS...juravleamonica@hotmail.co.uk..hope to speak later on .....thank you ..bye
  • IT aid
    IT aid May 11, 2010
    hi monica what OS are you using ??
    President:
  • 1,257 Answers
Start your computer and keep pressing f8 key ,then you will get  "Windowsg Advanced Options Menu " screen,Choose "safe mode" now you willl see some black n white lines coming up after which your system will start.Now when the login screen comes choose "Administrator" as the login name and you will come to desktop ,Now click on start > then "Run" type user "userpasswords2" wihtout quotes ,Now you willl get the User accounts where you can reset the password...
Regards
D I L I P
Posted on Oct 22, 2008
Computer will not recognize bios password.
Unfortunately, this is a security problem. I would advise you to take it to a competent Toshiba Tech and with proof of ownership get him to remove the password for you.
Feb 24, 2014 | Computers & Internet
I keep entering my password under my user name and it wont let me in
Hi John,
What operating system does your computer have, assuming you are having trouble logging into a version of Windows (XP, Vista, Win7, other)? The following will be applicable to most but may be slightly different between versions.
Have you tried logging in with the Administrator account?
Try logging in with the Username 'Administrator' and an empty password. If you are able to log in, go into the control panel under Users & Accounts and reset the password for your user account to nothing or set a new password.
If you are not able to log into the Administrator's account or another user who has administrative privileges you will need to try a Rainbow crack (very technical) or log into another account on your machine that has administrative security privileges.
If all else fails you can run the Master Restore CD or System Recovery tools that came with your computer.
Oct 20, 2013 | Gateway LT4008u Atom N2600 Netbook
Lost password for my dlink and trying t add the i pad
Hi
You can login to the router setup by typing http://192.168.0.1on the address bar of Internet Explorer
Make sure you do it on a computer that is connected to the router with a Cable
Then enter the default password (admin) lo log in to router settings
On the left side Click Wireless Settings
Here you can see
Wi Fi Protected Setup Also known as WCN in Windows Vista
Disable it
The Next section Will be Wireless Settings , you can find the name of your wireless network here
Change it to a different name
Make Sure the Visibility Status is set to VISIBLE
On the next section you can find the Wireless Security Mode
Make it as WPA - Personal
Then Choose the WPA Mode As WPA Only
The Cipher Type should be TKIP and AES
and the Group Key Update interval should be 3600 Seconds
Then in the Pre Shared Key box ,
Type A Password
It Should be Minimum 8 Characters
Make Sure you remember the New Name and the Password
Click Save Settings at the top
Now the Network is ready
Try to lookup this network on the Ipad
Connect
When prompts for password
enter the new Password
Let Me Know if it works
Regards
TOM
Aug 17, 2011 | D-Link (R) DIR601 WirelessN 150 Router
HI..\r\nHOW TO SET DEFAULT USER NAME AND PASSWORD TO A CLIENT RUNNING WINDOWS XP SERVICE PACK 2 PROFESSION VERSION IN A NETWORK ? I TRIED TO EDIT REGISTERY KEY BUT I WAS UNABLE IT SHOWS A MSG THAT THE...
In case of using this computer on a work-group, you can use the "control userpasswords2" command to specify the auto log-on at a user. If you use this computer connected at a domain, there is no way to specify the auto log-on at a specific user. You can clarify the type of the network you use (domain or workgroup) with this simple way: if you see a field just bellow the password area with the name of the domain, this computer is logging in at this domain. This type of networking is a common rule for the companies and not available for home users.
I hope I've answered your problem, although the solution isn't existing due to network type security reasons. In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Jun 18, 2011 | Computers & Internet
Lost paperwork to my berklin wireless router, need to know how to put a security password to log on. i live in an complex and there are some people i believe are hacking in. my computer is new and running...
Hi here is the answer if you want to setup wpa/wpa2 security then follow the below seps
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Sep 26, 2010 | Computers & Internet
It keeps resetting the security zone
You might not be logged in with Administrator user id. To make sure you are part of admin group. Go to Start->Run-> type "control userpasswords2" and hit enter. Check you user name and on the right side check your group it should be administrators.
If not login with administrator user id and password and add your user to administrators group.
Follow the link to add user to admin group
http://blogs.howtogeek.com/mysticgeek/2008/02/08/add-a-user-to-administrator-group-on-a-domain/
Hope this helps
May 19, 2010 | HP Computers & Internet
Hi, im trying to find out the password to my
HI,
If you have any computer hardwired to the router than click on start >> go to run >> type cmd and press enter >> type ipconfig and press enter >> this will show you an ip address, subnet mask and default gateway >> note down youe default gateway >> open an internet explorer and type the default gateway in address bar for example : 192.168.1.1 and press enter >> it will ask you for user name and password >> by default user name should be admin and password should be admin/password. >> after logging in to the router page go to wireless security and check your wireless network key.
If you fail to do this than you might have to reset your router and have to re-configure it again.
May 15, 2010 | Computers & Internet
Passworded user from old pc to new pc
How to take ownership of a file loadTOCNode(3, 'moreinformation'); You must have ownership of a protected file in order to access it. If another user has restricted access and you are the computer administrator, you can access the file by taking ownership.
To take ownership of a file, follow these steps:
  1. Right-click the file that you want to take ownership of, and then click Properties.
  2. Click the Security tab, and then click OK on the Security message (if one appears).
  3. Click Advanced, and then click the Owner tab.
  4. In the Name list, click Administrator, or click the Administrators group, and then click OK.
    The administrator or the administrators group now owns the file.
To change the permissions on the file that you now own, follow these steps:
  1. Click Add.
  2. In the Enter the object names to select (examples) list, type the user or group account that you want to have access to the file. For example, type Administrator.
  3. Click OK.
  4. In the Group or user names list, click the account that you want, and then select the check boxes of the permissions that you want to assign that user.
  5. When you are finished assigning permissions, click OK.
  6. You can now access the file.
How to take ownership of a folder loadTOCNode(3, 'moreinformation'); You must have ownership of a protected folder in order to access it. If another user has restricted access and you are the computer administrator, you can access the folder by taking ownership.
To take ownership of a folder, follow these steps:
  1. Right-click the folder that you want to take ownership of, and then click Properties.
  4. In the Name list, click your user name, or click Administrator if you are logged in as Administrator, or click the Administrators group. If you want to take ownership of the contents of the folder, select the Replace owner on subcontainers and objects check box.
  5. Click OK, and then click Yes when you receive the following message: You do not have permission to read the contents of directory folder name. Do you want to replace the directory permissions with permissions granting you Full Control?All permissions will be replaced if you click Yes.
    Note folder name is the name of the folder that you want to take ownership of.
  6. Click OK, and then reapply the permissions and security settings that you want for the folder and its contents.
Source: Microsoft
Jan 21, 2010 | Microsoft Windows XP Home Edition
Cannot log on to laptop
What is your OS ?? If it is windows xp and you didnt setup admin password when your sysrem was instaled you can try restart your laptop, When will start rebooting wait till you see second boot screen and start pressing F8 when you will see emergancy menu click to save mode, Log on as Admin (not your name) and when system willl started go to: control panel,user accounts,logon as admin,go to your profile(account with your name) and press remove password. then restart your computer. Your password will be gone.
Dec 27, 2008 | Computers & Internet
Cisco asa5505 problem
You seem to have the last resort (o.o.o.o) set to VLAN1 which is set as an inside interface.
Is VLAN1 connected to the outside router or internet backbone?
If not, change the last resort to the outside Ethernet port.
Apr 16, 2008 | Cisco ASA 5500 Firewall
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
