Question about Samsung LN-S2641D 26 in. LCD HDTV
Losing Picture I have just purchased a new HDTV LCD but after only 1 hour, the picture began to disappear from the top working it's way down. I still have sound but no picture. If I switch it off and leave it a while, it's ok to begin with, then again after some time, the picture starts to disappear.
  • Anonymous Nov 29, 2008
    SAME PROBLEM. PICTURE STARTS OFF FINE THEN STARTS TO DISAPPEAR FROM THE TOP DOWN. EVENTUALLY, NO PICTURE BUTY DO HAVE SOUND. TURN IT OFF FOR A FEW HOURS AND ON AGAIN AND PICTURE IS FINE. IT THEN STARTS DISAPPEARING AGAIN. UPSHOT - NEVER BUYT SAMSUNG. USELESS.
  • 63 Answers
Bring it back IMMEDIATELY!~
Posted on Dec 23, 2008
Samsung ln22a450 no picture just audio in the back
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
May 03, 2014 | Samsung LN22A450 22 in. LCD HDTV
Losing TV picture, screen goes blank,
- Flickering screen
- Dim screen
- Slow start
Apr 21, 2014 | Televison & Video
I have several lines on the top of the screen
- Flickering screen
- Dim screen
- Slow start
Apr 05, 2014 | Sharp LC-60LE550U Aquos 60" Class 1080p...
RCA L32WD22 32" HDTV LCD TV turns on, blue light on front is on but there is no sound and no picture. I left it unplugged for an hour and turned it on again. As soon as I plugged it in, an orange light on...
kkl,
these tvs have a power supply defects. Follow these instructions and get yourself a free tv.
Take your unit to a service center. Since they have no service manual they wii not be able to repair it.
With the Work Order or a copy of it call 1-877-297-8391 and you will get a tv no questions asks
Jun 05, 2010 | RCA L32WD22 32 in. LCD HDTV
My LN-S4095D (3 years old), only works for about 30 to 60 min, and then the picture disappears and the sound stays. If I turn it off for several hours or till the next day, it turns on back with picture,...
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
May 25, 2017 | Samsung LN-S4095D 40 in. LCD HDTV
Permanent blue haze on screen; looks like
The fact that you continue to have sound while the picture disappears points to one of three potential issues.
Issue 1: the LCD Panel.
Issue 2: The Inverter Power Boards (though these tend to cause power/shutdown/no video at startup than video distortion)
Issue 3: the Time Control Board - a small board at the top of the LCD panel on the back that relays data to the rest of the screen.
Any one of these three repairs, you should call Sony if the unit is outside of manufacturer's warranty. They are expensive to perform, and the parts are not cheap. Hopefully you have an extended warranty to help with the issue.
Jan 24, 2010 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Black frame around picture
Toggle through the "Picture Format" settings from your tv remote.
Flip through cinema mode, too standard....etc
Jun 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sony KDL-40S2000 Picure Disappearing
hello, Check for trapped wires under earth of G2 board (top right).
Jan 27, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Samsung LN-S2641D 26 in. LCD HDTV Logo
127 people viewed this question
Henry  Thomas
Henry Thomas
