Question about Samsung HCL4715W 47" Rear Projection Television
Convergence problem???/ is this a pretty cheap fix, again the picture is my profile picture, it looks pretty bad, i would need a technician to fix it because i really dont know anything about tv's, thanks again
    President:
  • 3,130 Answers
Between the convergence IC's and the labor , your looking at between between 250 to 400.00 bucks
Posted on Jul 30, 2006
When I first turn on the TV the picture is messed up sometimes it shows a double picture.If I turn it on then off and back on again the picture is fine.Whats wrong? My second problem is that when I turn on...
Ur tv covergence board it is dying.Tv are developing a convergence picture problems.Tv have colors R,G,B lines mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it dying must require replacement like 2 STK convergence ICS and some or all of it resistors too.Fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 30, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Powers on but no picture
convergence ics need replaced suggest going to local tv repair guy and getting it fixed pretty cheap
Jul 01, 2010 | Toshiba TN50X81 50" Rear Projection...
The picture just changed & the convergence is off with the picture bowing inward on top & bottom of screen & you see the image in red,blue & green. The auto convergence feature in the setup...
U have a soldering iron,solder wick or a desoldering pump,and solders?U know how to do soldering?U can fix this problems like about 20 mins.The convergence fuse part (FL231) is dead.Very common on this model of RCA tvs.U can buy this convergence fuse (FL231) at Ebay.com pretty cheap like $3+ shipping.There 3 small brown or pinkisk sqaure look like caps.The one in the middle is dead.But they're fuses located right side of the Flyback transformer,call a FBT(a big black block of transformer).Resolders the FBT too.
Jun 18, 2010 | RCA HD52W59 HDTV Projection Television
Hitachi 53uwx10ba turns on & off when off red flashing light/clic
Same problem. Replaced both convergence ICs about 5 months ago. Worked fince since then and just recently no sound, no video, blinking red on front panel and clicking sound. I suspect that the ICs went bad again and blew a resistor or two. I used cheap Chinese ICs instead of the Sanyo ones and thing this is why. I'll be looking at it again and post solution.
Jan 21, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Bad picture
Bad convergence chip. A tech will need to fix or replace. No easy fixes are available.
Nov 14, 2008 | Hitachi 57F500 57" Rear Projection...
Convergence
The two convergence ICs labeled STK392-110 are bad . Likely the resistors that go with them one or more are bad too.
If you have patience can use a ohm meter, solder properly and have good vision. You can fix this problem .
Parts can be found at www.eletronix.com . Good luck, maicomasher
Aug 15, 2008 | JVC AV-56WP30 56" Rear Projection...
Canon's misaligned and bad lines thru lower-center of picture
sounds like convergance amp ic's see links below
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
· http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
· http://www.hdtvoice.com/voice/index.php?s=
Dec 29, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Problem
Hi three months ago my kp-61hs30 tv looks like 3d picture and technician man replaced the two convergence Ic's but last night my tv looks like 3d picture and it look like is the picture goes down
i don't know why happened again
Oct 30, 2007 | Sony KP-61HS30 TV
Picture Problem
it's very easy to fix convergence manually from the menu, unless it's really really off. there is a button on the front that is an auto focus, that should be used first, then try to manually dial it in. it should be very close after the autofocus (called touchfocus) I got mine for $400 used, and it's great!
Aug 18, 2006 | Toshiba 57H83 TV
Convergence and wavey picture problem
Actually you have 3 problems. The two that you listed and the third which is: Apex does not support their units. Ask anyone who has tried to get any service. Your problem sounds like a bad digital convergence box. I fix this problem several times a week but on name brand sets. Cost is usually less than $100 for the part. Some problems with Apex equipment can be fixed if the part is a common off the shelf part. That is not the case with your problem. Apex equipment is cheap for a reason. All posts that I have read say that they do not last long and you can't get parts. That has also been my experience as a technician. We don't even accept Apex units for repair anymore. Next time spend the extra money to buy a name brand unit and it will more than likely be repairable.
Jun 01, 2006 | Apex Digital GB5108 51" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
