Question about Samsung SCX-4100 All-In-One Laser Printer
Printing problem 1) poor quality printout 2) takes 4 to 5 papers at a time 3) takes long time get recharge for printing
  • 77 Answers
Quality - cartridge,charge roller,
4-5 papers - pickup presure pad, clean / replace.
long time to charge - fixing unit.- thermister.
Posted on Feb 09, 2009
Why does my 6280 separate one image into two and print it?
Poor fusing of the toner onto the paper is caused by
1. Poor quality compatible/remanufactured toner cartridges that have the wrong toner in them. - Use OEM, or better quality independent toners (and complain to your current supplier about the ones you have)
2. Damp media - high moisture content in the paper prevents correct fusing. You'll probably see the paper 'steaming' as it comes out if this is the case. - Keep your paper dry, only load as much as you need.
3. Thicker than normal media. The thicker the paper, the longer/more heat it takes to fuse the toner. - Make sure you have the correct paper type set in the printer driver at print time.
4. Faulty fuser. Normally the printer will report if the fuser is not reaching the correct temperature, but there are instances when this does not happen. Also it is possible for the fuser heat lamp to blacken partially, resulting in an area of the fuser that does not reach the correct temperature. This problem will affect an area of the page which consistently (same place, and all the way down the page) shows poor fusing. - Replace the fuser.
May 18, 2014 | Xerox Phaser 6280N Color Laser Printer
HOW TO INCREASE DARKNESS IN HP 4300
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
I'm not quite satisfied with color and black tone. What settings would you recommend.
You do not say what exact model of printer you are using so any answer will be generic rather than specific.
Poor colour and black tone can be as a result of various factors:
1. Poor paper quality that you are printing on.
2. Poor ink or toner quality being used.
3. Use of Ink / Toner saving modes or software.
4. Worn or damaged printer components such as the fuser roll on a laser printer and other similar consumables with a limited page use life.
5. Poor quality content being printed, i.e. low quality images being printed at too high a print resolution.
Dec 30, 2011 | Samsung Office Equipment & Supplies
Will not print a test page also unable to find or adjust spool settings and cannot change Priority settings. Some things will print but many items will not, even then it seems very slow.
Printing Problems
? The machine beeps while printing.
The machine may have a paper jam.
• Clear the paper jam (1 p. 13-3).
? Nothing prints.
The power cord may not be plugged in securely.
• Check that the power cord is plugged securely into the machine and into the wall outlet (1 p. 2-9). If the machine is plugged into a power strip, make sure the power strip is plugged in and turned on.
You may not have removed the plastic seal from the cartridge.
• Make sure you install the cartridge properly (1 p. 2-13).
The cartridge may need to be replaced.
• Replace the cartridge (1 p. 12-7).
? Printout does not match the print media size.
The print media may not be loaded correctly.
• Make sure the print media is loaded correctly in the multi-purpose tray (1 p. 5-4).
? Printout is skewed.
• Make sure the paper delivery slots are clear.
? Print media jams occur.
You may not be using the correct paper delivery slot.
• Select the correct paper delivery slot (1 p. 5-7).
? Printout is not clear.
You may not be using the correct print media type.
• Make sure you load print media that meets the requirements for the machine
(1 p. 5-2).
You may be printing on the wrong side of the paper.
• Some papers have a "right" side for printing. If the print quality is not as clear as you would like it to be, try turning the paper over and printing on the other side.
? Printout has vertical white streaks.
Toner may be low or unevenly distributed.
• Redistribute the toner inside the cartridge (1 p. 12-7). If the problem persists, replace the cartridge (1 p. 12-7).
Jan 03, 2011 | Canon FAXPHONE L80 Laser
MY LEXMARK 4505 LEAVES 3-4 BLACK BLOTCHES ON THE EDGE OF EACH PAPER IT PRINTS, TRIED CLEANING THE ROLLERS TO NO AVAIL, ANY SUGESTIONS
ADJUST THE COLOR AND PRINT SPEED You may need to adjust the color and print speed. CHECK THE LEVEL OF INK IN THE PRINT CARTRIDGES 1 From the Finder desktop, double-click the Lexmark X5400 Series folder. 2 Double-click the Lexmark X5400 Series Utility icon. 3 From the Maintenance tab, check the ink levels of the cartridges. If an exclamation point (!) appears on a cartridge, the ink level is low. Install a new cartridge. Improving print quality These are possible solutions. Try one or more of the following: CHECK PAPER • Use the appropriate paper for the document. If you are printing photos or other high-quality images, for best results use Lexmark Photo Paper or Lexmark PerfectFinish Photo Paper. Do not use Lexmark Premium Photo Paper. Your print cartridges are not compatible with this type of paper. • Use a paper that is a heavier weight or bright white. CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" on and "Installing print cartridges" . If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts". If print quality is still not satisfactory, replace the print cartridges. For more information, see "Ordering print cartridges". CHECK PRINT CARTRIDGES If the document still does not have the print quality you want, follow these steps: 1 Align the print cartridges. For more information, see "Aligning print cartridges" on page 124. If print quality has not improved, continue to step 2. 2 Clean the print cartridge nozzles. For more information, see "Cleaning the print cartridge nozzles" . If print quality has not improved, continue to step 3. 3 Remove and reinsert the print cartridges. For more information, see "Removing a used print cartridge" and "Installing print cartridges" If print quality has not improved, continue to step 4. 4 Wipe the print nozzles and contacts. For more information, see "Wiping the print cartridge nozzles and contacts"
Nov 10, 2010 | Lexmark X5495 All-in-One &USB...
I have downloaded the printer drivers for my HP Deskjet D2460 from the HP site but I have no printer toolbox and therefore cannot clean cartridges etc. Can you help
Hi Kimsmith99
Please do not worry. You can try the following.
1. Simple take the cartridges out from your printer.
2. Use a clean cloth and some distilled water.
3. Clean the copper connections of the print cartridge gently with the help of the clean water and a clean cloth .
4. Take a tissue paper and then try to mark a stamp from the cartridge print head on that tissue paper.e
5. Do it till you get a clear color / black parallel line on the tissue paper.
6. Once you get a clear parallel mark on the tissue paper, insert the cartridge back in to the printer and the take 2-3 printouts.
7. You will get the clear printout for sure. This is my practical experience.
Thanks & Regards
Ashish Rohilla
Aug 21, 2010 | Office Equipment & Supplies
When i try print my pictures they are coming out blurred. how can i stop this
1) Do they look good on your PC. If so its a printer issue if not, for some reason or other, you're not taking good photos
2) If they're good on the PC and print poorly then its a printer issue. Which can be many and varied.
Usually, the wrong kind of paper. If you use ordinary vice photo quality paper the ink can run.
Size, are you trying to print a small picture, say designed for 6x4 inches out on a piece of A4 at A4 size.
Printer settings, are the set to the correct type of paper and for photo printouts.
Ink, generaly, generic cartriges don't quite match the accuracy of manufacturer cartriges.
Mar 07, 2010 | Samsung Digimax A503 Digital Camera
Skipping while printing
STEP: Disconnect and Reconnect the Printer Power Supply
Additional Information
1.
Unplug the power cord from the wall socket.
2.
Disconnect the power supply from the back of the printer.
3.
Wait 15 seconds.
4.
Reconnect the power supply to the back of the printer.
5.
Plug the power cord back into the wall socket.
STEP: Perform a nozzle clean on the printer.
The following steps will guide you through running a nozzle clean on the 922 printer:
1. Press the Scan Button and the Up Button at the same time to enter diagnostic mode.
2. Use the Up Button or Down Button to navigate to Clean on the LCD and press Menu to begin the nozzle clean.
3. Check the nozzle clean printout and make sure that it is clear of defects and that all expected color bars exist on the page.
STEP: Clear NVRAM on the 922 Printer
1.
2.
Use the Up Button or the Down Button to navigate to the option for Clear NVRAM on the LCD and press Menu to confirm.
3.
Press Menu again when asked if you are sure.
4.
Press Menu again when asked if you are really sure.
Ink Cartridge and Print Quality Issues on Inkjet Printer
STEP: Verify the Paper Settings and Change the Quality Level
1. Click the Start button, point to Control Panel, and then click the Printers and Other Hardware menu item.
2. Click the Printers and Faxes menu item.
3. Right-click the Dell AIO Printer Model Number icon, where Model Number is the model of the printer to troubleshoot.
4. Click the Properties menu and the Printing Preferences menu option.
5. Click the Quality/Copies tab.
6. Click the Paper Setup button.
7. Choose the appropriate paper type based on what is being used in the printer.
STEP: Verify the Printer Ink Levels
Quality problems are most often caused by low ink levels or one or more colors in the color cartridge being completely depleted. Perform the following steps to determine the current ink levels and to check for missing colors.
1. Click the Start button, point to All Programs, and then click Dell Printers.
2. Click the model number of your Dell printer.
3. Click Dell Printer Solution Center.
4. On the main window of the solution center you will see two ink tanks in the lower right hand corner. Verify that the ink cartridges are not empty
To ensure that the quality problem is not caused by one color missing print a test page and verify that the colors in the CMYK boxes appear correct. To do so, perform the following actions from the solution center window:
1. Click the Maintenance button on the left-hand side of the window.
2. Click Print Test Page.
3. Verify that the Cyan, Magenta, Yellow, and blacK colors are printing without streaks.
Apr 22, 2009 | Dell 922 All-In-One InkJet Printer
Dell laser 300cn
is it happening always or sometime, have you check the cartridge
May 01, 2008 | Dell 3000cn Color Laser Printer
Samsung SCX-4100 All-In-One Laser Printer Logo
80 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
