Question about Nokia 3230 Cellular Phone
Restores setting for nokia 3230 i forgot my code help me
My nokia 3230 in menu my themes option folder not opening
    Sergeant:
  • 208 Answers
The default master code for nokia is 12345. If you have changed this default one, then go to the following website, enter your IMEI number, and get the unlock code.
www.lur.nu/nokia_mastercode/security_code.php
Hope my info helps you,
Thanx for using fixya,
Cheers.
Posted on Oct 22, 2008
Forgot password for my nokia3230
If you have forgot your password, You can do a master reset to your mobile. this would restore your phone with default factory settings. You can get the master reset code from any Nokia priority dealer.
Oct 27, 2012 | Nokia 3230 Cellular Phone
Dear sir, i forgot my wallet code so plese help me my hendset nokia 3230
If you forgot wallet code for Nokia 3230 phone,please use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Thank You
Aug 11, 2010 | Nokia 3230
Nokia 6300 has stopped ringing anyone any ideas?
o.k. does it vibrate?
have you dropped it?
You may have accidentally put it on silent mode:
HERE IS HOW TO CHECK YOUR TONES OR PROFILE:
10. Settings
Profiles
Your phone has various setting groups called profiles, which you can customize with
ringing tones for different events and environments.
Select Menu > Settings > Profiles, the desired profile, and from the following
options:
● Activate — to activate the selected profile
● Personalise — to change the profile settings
● Timed — to set the profile to be active until an end time. When the time set for the
profile expires, the previous profile that was not timed becomes active.
Themes
A theme contains elements for personalizing your phone.
Select Menu > Settings > Themes and from the following options:
● Select theme — Open the Themes folder, and select a theme.
● Theme downloads — Open a list of links to download more themes.
Tones
You can change the tone settings of the selected active profile.
Select Menu > Settings > Tones. You can find the same settings in the Profiles menu.
If you select the highest ringing
all this can be found in your manual:
here is a link to the manual for: nokia 6300
please remember to rate my help if it was of assistance it helps me too.
Mar 26, 2010 | Nokia 6300 Cellular Phone
How to restore my folder option? please help me to restore my folder option
Go start, control panel, and then to the appearance and themes settings. Click on that and the menu below opens. If yours looks a bit different, it is just a matter of themes or Windows version.
After you click appearance and themes, go to folder options listed at the bottom where there is a folder with checks on it.
You can help me to help others by letting me know if this answer helped solve this problem. If you have a few minutes, please rate this answer, thanks.
Dec 23, 2009 | Microsoft Computers & Internet
How can format the phone memmory of NOKIA 3230
Download user guide from:
http://nds1.nokia.com/phones/files/guides/Nokia_3230_UG_en.pdf
Page 163
Formatting the memory card
When a memory card is formatted, all data on the card are permanently lost.
Some memory cards are supplied pre-formatted and others require formatting.
Consult your retailer to find out if you must format the memory card before you
can use it.
• Select Options→ Format mem. card.
Select Yes to confirm. When formatting is complete, enter a name for the
memory card (max. 11 letters or numbers).
Backing up and restoring information
To back up information from your phone’s memory to the memory card, select
Options→ Backup phone mem.
To restore information from the memory card to the phone’s memory, select
Options→ Restore from card.
You can only back up the phone memory and restore it to the same phone.
Locking the memory card
To set a password to lock your memory card to help prevent unauthorised use,
select Options→ Set password.
You are asked to enter and confirm your password. The password can be up to
eight characters long.
Your rating would be most appreciated.
Feb 20, 2009 | Nokia 3230
Tell me formate code of nokia 3110c
my phone is nokia 3110c i don't know my restore factory code help me now
Dec 21, 2008 | Nokia 3110 Cellular Phone
Nokia 3230 started then open menu then select setting option then select phone then select general then select orignal phone setting then display a code box that is i forgot help me
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
www.mytrendyphone.com
This is your solution! Please vote!
Oct 22, 2008 | Nokia 3230 Cellular Phone
HELP THEME CORRUPT
There is a battery recall that you may have and the only phone number for them is in Texas and it is not toll free.
This is their contact information:
Nokia Siemens Networks
6000 Connection Drive
Irving, TX 75039
+1 972 894 5000
Their website doesn't offer much help although there is a user guide there that may include a reset key sequence.
https://www.nokiausa.com/A4462181
This is from their user guide:
Select theme — to set a theme. A list of folders in Gallery opens. Open the Themes
Theme downloads — to open a list of links to download more themes
Note the part where theme downloads is found. You probably need to download the themes again. The free themes.
Regards,
Worldvet
May 30, 2008 | Nokia 7373 Cellular Phone
Font changed
ok , i see that you must search for "restoring factory mode" in tools . u may also to change all the software there will not be any problems
Aug 31, 2007 | Nokia 3230 Cellular Phone
Nokia 3230 Cellular Phone Logo
129 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
