Question about Samsung 460PXn Monitor
Samsung 460PXN Virtual memory Problems
I have this monitor and would like to run schedules. I have installed the MagicNet Software onto the monitor to eliminate the cost of an additional PC. The software works fine. I have numerous graphs and report URL that I am displaying on the screen, as soon as I schedule my Report Page which is a URL page the Monitor hangs. I managed to find out that this page uses alot of Virtual Memory, and since you can add a Flash Disk to the monitor and then increase the Virtual Memory it should not be a problem, but, I cannot get the Virtual Memory to work on a flash disk, any ideas?
Fred
SOURCE: problem with samtron 56v 15" monitor
IT IS REULATION COMPLIANT PLEASE CHANGE THE 7805REGULATOR IC NEAR THE MEMORY IC
Posted on May 12, 2007
Bat1956
  • 585 Answers
SOURCE: Replaced IP board on Samsung 930B now other problems.
Try a little backtracking....Check all internal connections. Make sure you didn't leave any insulator out allowing pc contact to case where it should not be. Make sure no wiring is pinched under screw or pc card causing a short to case.
Posted on May 15, 2009
SOURCE: no Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Posted on Aug 21, 2009
  • 732 Answers
SOURCE: I have a Samsung SyncMaster 931c monitor (2.5 yrs
jcacolice, Most likely your 931c will need work done on it. When strange things start to occur with any LCD CCFL backlit display I would suspect the "switch-mode-power-supply" first thing!!! If unit is out of warranty you or someone will need to inspect and troubleshoot it. A good place to start will be to see some DIY videos on YOUTUBE. Try search of "lcd monitor disassembly" and "lcd monitor repair" and learn all you can about the TOP CAUSES of monitor failure. Then visit (FYI) www.ccl-la.com/badcaps.htm and www.badcaps.net for more info. Explore ALL your options before you do anything. Then get back to us here at fixya if you still need some asssistance. Read some of my other responses in my fixya profile and other those of other tech's on fixya.
Hope to see you back on fixya with a plan of action!! 12fixlouie
Posted on Dec 24, 2009
SOURCE: Rotation of Samsung SyncMaster 2243BWX
They are referring to the video card in your COMPUTER, not the monitor. There is a supported list of cards at http://www.samsung.com/Products/Monitors/magictune/magicrotation_06s.htm
Posted on Feb 01, 2010
Want to install Topo for XP service pack 2 onto Windows 7
install virtual box, a free virtual computer from oracle. It reserves disk space and runs a separate operating system, in a window on your desktop. Install virtual box, install windowsXP, install your software.
Hope that helps.
Apr 07, 2013 | GPS
High speed docking station does not support monitors on windows 7
You can download "Windows Virtual PC 2007"software from the following link.
http://www.microsoft.com/windows/virtual-pc/support/virtual-pc-2007.aspx
Install this software on Windows XP and you will be able to install and run Windows 7 inside this software.
Good Luck!
Jan 24, 2011 | Computers & Internet
I was on the internet the other night an a popup said that my memory was low so what should i do an its really slow...
If too many applications are running in the background memory is reduced. Verify that you let Windows manage the paging memory.
For WINXP
Rigt click My computer on desktop.
Click Properties
Advanced Tab Click on Performance Settings.
Under Visual effects you may ask OS to adjust for best performance Under Tab Advanced make sure that Processor scheduling and Memory usage are set for Programs.
Verify on same tab that virtual memory is about equal to physical memory (or just let windows manage it)
Hope it helps
Sep 13, 2009 | HP Pavilion MX70 17" CRT Monitor
Samsung 460Px monitor turns on but no vidio signal going through. Screen turns from black to a dark blue meaning the unit is powered and I get a solid green light.
I have the same problem, the monitor has power, but i can't even switch sources, the front panel is locked and i can't tell if it responds to the remote because there is no menu or picture of any kind
Apr 24, 2009 | Samsung 460PXn Monitor
Nec 17'' multisync lcd monitor not working properly
What is the problem? Did you try plugging it into another working computer?
Mar 03, 2017 | NEC AccuSync LCD71VM 17" LCD Monitor
My acer aspire 5600 warned that I am running out of memory. My "D" drive says there is 30g of free space. How do I use it?
I think the computer actually said you were running low on Virtual Memory ... memory is the physical ram installed in your machine ... virtual memory is an area of hard drive the computer uses to store data when in runs out of "real" memory .....hard drive space is nothing to do with memory.
Ok, that got that cleared up :-) .... now the quickest way to get over low virtual memory problems is to install more RAM. For XP you should really have a minimum of 512mb .... 1gb is probably optimum. For Vista you should really have a minimum of 2gb.
So if your laptop has less than 512mb(xp) or 2gb(vista), the first thing to do would be to upgrade the memory.
Virtual memory problems should only ever crop up when you are running multiple applications .... so just try and keep the amount of programs you have running to a minimum. Instead of just minimizing programs, try to close them down to save memory.
Jan 01, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
I have an IBM thinkpad T20 running windows 2000. The computer is on and booted up but the monitor is not lighting up. It is running on 256mb ram and I was getting a lot of virtual memory is low warnings...
To determine if the laptop has a problem with the inverter of low virtual memory issues, plug an external monitor in to the laptop and you can change the virtual memory by following these instructions, right click on my computer, select properties, then select advanced, click on virtual memory and change the settings to system detemined, save settings and reboot the laptop without the external monitor to see if it is virtual memory or inverter.
Please keep me informed
kind regards and please don't forget to rate us
Dec 03, 2008 | Computers & Internet
Monitor wont turn on green light blinks but makes a clicking noise
hi there, light blinks constanly means a shorted electronics parts, most of it are in the horizontal sec., and power supply. check first the power supply if you have a constant voltage output, else your prob . is in the horizontal section. do somr test and check up. ty
Feb 18, 2008 | Samsung 460PXn Monitor
Samsung 460PXn Monitor Logo
64 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
