Question about Minolta EP1083 CS/PRO Copier
Minolta ep1083 Hej jqsababa967. Just to tell you that I bought new cleaning blades and removed the old ones. Thanks to your advice everything now works OK - but - a smal white stripe, app. 5mm wide, appear on the middle of the paper and all the way over..... I can´t find the reason why. Do you??? Best regards
  • 145 Answers
Sound like somthing in the developer unit take out and see if developer is even across mag roller.
make sure t/s charge unit are clean
hope that help you
Posted on Oct 22, 2008
Service manual
Clean or change the drum cleaning blade,check the fuser unit rollers abd the transport belts.Clean the image transfer/separator coronas unit,check ,clean or change the drum antisplit bade,located under drum cleaning blade.
Apr 30, 2013 | Minolta EP1083 CS/PRO Copier
Minolta bizhub 164 black and white, change drum
Remove the imaging unit from the copier. Unscrew the sides. Remove the old drum. Replace with the new one. Clean the blade and everything of imaging unit including the waste or recycle part.
Jan 23, 2012 | Minolta bizhub 350 Black and White Copier
I have a Minolta CSPRO EP1083, it stopped making copies, the paper comes out blank. I put a new toner bottle in and the paper still comes out blank.
Problem on lower charger.Some times wire was broken .It has 2 wire one saparation wire and other high voltage wire may any one broken.Assemble new wire may be it fix problem.Other lower charger was damaged ,need new one .If you try clean all socket and dry.I hope your copier good working.
Aug 02, 2011 | Minolta EP1083 CS/PRO Copier
I am working on minolta ep 1080 copier and the drum is bad, how do l replace it, or how do l replace the cleaning blade
if you dont have any idea about how to change drum and C.blade please dont touch it because maybe you break it again or scratch drum
Aug 23, 2010 | Minolta EP1083 CS/PRO Copier
How do I install developer into my Minolta CS Pro 1083 copier?
Sir for developer will require you to remove the image unit then clean out the old developer and add new. Then run the service mode F8. Be careful of the drum keep it dark /covered. Recommened a technician for this
Apr 24, 2010 | Minolta EP1083 CS/PRO Copier
1/3 OF RIGHT SIDE OF PAGE DARK OR LINED TOP TO BOTTOM
Drum Cleaning Blade failure. Open up the top half of the machine as if you were removing a paper jam. Now look under the top half and about in the center from left to right. You should see a burgundy colored cylinder running from the front of the machine to the back. If you can see the toner streaks on the surface....expecially on the 1/3rd like on the copy then this will be proof that the drum cleaning blade is the cause. Simple repair for a tech that knows copier basics. A good estimated cost would be about $25.00 for the blade and whatever the going rate is for a service call in your area.
Jan 28, 2010 | Minolta EP1083 CS/PRO Copier
Copying only half copies
Sounds like the charge corona wire may be out of place, or the scortron grid is shorting. It is NOT the HV unit.
Jun 16, 2009 | Minolta EP1083 CS/PRO Copier
Minolta Copier EP1083, copies are coming out mostly black
What you mostly need to do is to clean the optics under the copyboard glass the mirrors are mostly dusty... I would use a soft dry cloth to wipe the mirrors off. There is a mirror under the "Black Box" I would also, use a lightly damp rag with rubbing alcoh. to wipe OFF the scanning lamp & reflector. Cleaning the optics should get read of the dark back ground, but the drums are only good for 80k... You may need a new OPC drum & blade. Good Luck
Mar 02, 2009 | Minolta EP1083 CS/PRO Copier
Minolta ep 1083
i still think its your developer unit is causing this problem,do this take out the drum unit remove the developer unit and rotate the develper unit gears clock wise and look for void areas on the magnet roller where develpoer adhear .
hope that help
and check your fuser rollers ?
Nov 02, 2008 | Minolta EP1083 CS/PRO Copier
Minolta ep 1083
you do need to ajust anything...just look for some sort of dirt ,in the developer unit..transfer separation unit is the unit.sets under the drum..its has 2 very thin wires.
the wires should be cleaned very gently.with pencil eraser.is good
hope that help
Oct 26, 2008 | Minolta EP1083 CS/PRO Copier
53 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
