Question about Cell Phones
NEED SAMSUNG F210 LCD SCREEN COMPLETE WITH BOARD TO AVOID SOLDERING ANY IDEAS
Ive been looking for a replacement screen for ages, there are some on ebay but i suggest buying a second hand handset (one sold for spare parts) and taking both your handset and the second hand one to one of those mobile phone booths found outside some corner shops and asking them if they can swap the screens over, it'll work out much cheaper than sending your phone back to samsung for repair. My sister sent her one back, it cost her £45 to get it fixed and she waited 4 months for them to send it back to her, she also had to pay for the postage.
Posted on Jan 07, 2009
Samsung SGH-F210 Cell Phone sim unlock
To unlock the samsung SGH-F210 from Sim lock,You can use the Unlock code,You can get the Unlock code from here
Simpleunlocking.com
and Unlock it...
Sep 27, 2011 | Samsung SGH-F210 Cell Phone
I have a cut ribbon cable that goes from the chassis mounted LCD driver board to the LCD interface board. I think that I can handle the fine pitch soldering (or have it done for me) but I cannot find the...
Hmmm. You have picked a hard one. If you mean the flex cable that is ultrasonically welded to the glass LCD screen, you will be out of luck.
Best to call Samsung service centers to see if you can round up a broken screen.
Mar 29, 2010 | Samsung LN-S4051D 40 in. LCD Television
Need unlocking code for samsung f210 its an orange fone
you can get the unlock code for your Samsung model mobile, through this site http://www.mobile-unlocker.com/samsung/rs2wp8/
It has the best instructions and easy methods for unlocking mobile phones.......
Mar 06, 2010 | Samsung SGH-F210 Cell Phone
Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Dec 30, 2009 | Samsung LN-T4665F 46 in. LCD Television
My Samsung 46'' LCD TV has the same issue. Plays audio but no video, and I even tried hard restart with no luck. :(
This is for a different model # but same manufacturer I was able to fix mine with this. I was able to get the fuse from digikey.com
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Oct 18, 2009 | Televison & Video
How do you get the media player off the front screen on samsung f210
how do i get the media player off the front of my screen
Aug 03, 2009 | Samsung F210 Cellular Phone
CANT RECIVE CALLS ON MY SAMSUNG F210,BUT ABLE TO TEXT
Your phone may be locked out, you can check this by going to your security lock menu.
Mar 08, 2009 | Samsung F210 Cellular Phone
Unlock code for samsung f210
Recently I unlock my samsundf210 from the site http://www.theunlockarena.com/unlock-your-phone/rs13wp2/
It has the best unlocking solutions.
Try this site and gain solutions..............
Feb 17, 2009 | Samsung F210 Cellular Phone
Television won't turn on at all
if you can look on the boards at capacitors ( do a Google of "blown capacitors" ) and then you will be able to see if there are any blown one's on the boards inside, if so some soldering will be needed to replacce the blown one if you can then the issue should go away. if you can not do this a service center can help complete the repair.
May 27, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung LN-R408D - No Picture
Steve C
Feb 26, 2008 | Samsung LN-R408D 40 in. LCD HDTV
Cell Phones Logo
70 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
