Question about LG WD-1080FD Front Load Washer
My washing machine door wont open
MY WASHING MACHINE DOOR IS STUCK SHUT. i'VE TRIED REWASHING, BUT IT SILL WONT OPEN. CAN YOU HELP. WITH THANKS YVONNE
  • Yvonne Bailey-Smith Jul 29, 2006
    sorry about caps lock. Didn't mean to shout. Just want some help please. This machine has cost me a fortune in repairs and its only a couple of years old, so now trying to get door open without having to pay £100 pounds.
    with the politest of thanks.
    Yvonne
  • 3 Answers
Sorry for VERY late solution. I have an LG front loader machine and it has just broken. While surfing the internet, I found your blog. LG front loaders have a weak door handle, that breaks after a few years of operation. All the LG models seem to be the same. Replacement door handles are relatively inexpensive and readily available.To open your STUCK door, I would use a thin butter knife....slide the butter knife between the door and the frame of the machine until you hit the metal latch. Push the latch towards the centre of the machine and open the door.In the interim until you can get it fixed, this workaround method will work, enabling you to continue washing.Hopefully LG will make future models door handles out of cast, or something stronger!
Posted on Jan 16, 2012
The best way to open the the if stuck is to use some wire thin and put around the doorand pull it to the hinge end (don't forget to hold both ends ) it will pull the catch back
Posted on Feb 18, 2011
Firstly, for safety reasons, unplug the machine. I had the same problem and just found a quick solution without breaking the lock. Using a then object (in my case a butter knife) jam it between the door and the machine itself creating a gap through which the water can pass through (make sure you have a bucket handy!). Once the water has been emptied out of the machine plug it back in and it should open up (the sensors realise there is no more water in the system). Good luck!
Posted on Jul 14, 2012
Hello, I have the same problem with mine. I tried the extra load - nothing. I called LG who said unplug and leave for 15min as it tends to lose its memory and needs to be reset. No luck. Did another wash and tried again, nothing. It's still under warranty, but noone can come to look at it for a week and if I get anyone else out, the warranty isn't valid... If anyone has answer, it would be great! Becca
Posted on Sep 05, 2006
Ok so this is a year too late but if you select pump and start the machine will pump out the water and then the cycle ends and the door open light comes on and it should open. cheers, Bexta
Posted on Aug 17, 2007
  • 3,230 Answers
Either clip on the door is faulty or its the door interlock in which the door locks into easily replaced by undoing the clip pullling back the door rubber and replacing ..
Posted on May 19, 2009
Door wont unlock
Some of these machines have a door lock that dose not unlock for a min. or two after wash is done. If so try the door now & it should open.
Jul 15, 2014 | Washing Machines
Lg wd 10490tp door
Is it loked, you know how you have to wait for two minutes before the lock unlocks and you hear a click, then you can open the door. Try a program like emptying the machine, or the program with the lowest temperature and as short as possible. Kolbrun
Sep 19, 2013 | Washing Machines
The door on my Bosch washing machine 1605 is stuck on shut
Hiya,
the door not opening is normally a sign that there is still water inside if you can try a spin cycle or if you have a drain option try using that & if it was the water then the switch will trip & you should be able to open the door again.
Hope this helps
Apr 21, 2010 | Washing Machines
Door stuck shut hot point wd420
It happened on our machine. The soloution to this for me was to take the lid off (two screws). Unplugged from mains. I found the connector to the door had vibrated off and was just hanging loose. Plugged it back in and it worked straight away.Door opens as normal.
Don't forget to look in the manual for how to get the door open in an emergency
Apr 04, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Door will not unlatch after wash
hi..remove the lower front panel use torx 15,reach up to the
lock and pull down on a ring that comes down below the lock
assembly and the door should open.
try this out..
thank u..
kindly rate my response..
May 09, 2009 | Frigidaire Affinity ATF7000E Front Load...
I have a Samsung J1043 front loader. The door wont unlock after washing. Help
I rewashed the clothes a couple of times and finally the door released.
Oct 02, 2008 | Washing Machines
Whirlpool duet washing machine door lock error
My front loader has the door locked and I can't open it. I have already turned off the power and that didn't solve the problem. The manual says that if you try to open the door too soon after the cycle completes, then the door locks. How do I open it now? What do I do?
Nov 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WD-1080FD Front Load Washer Logo
6,199 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
