Question about HP DesignJet 500ps (42 in.) InkJet Printer
Designjet 800 thinks paper is too far to right, makes bumping sound
Howdy,
I have an recent model low usage HP Designjet 42" 800ps. I recently cleaned it from inside the front window but did not disassemble it, and after printing beautifully for a few sheets it does not want to load paper. It says when checking paper that the paper is too far to the right. Then when it attempts to return the carriage to the right over the printheads, I can hear it bumping as though it thinks it has a few more inches to travel. It seems the carriage thinks it is further left than it is. I cannot find a service manual and HP email support only wants me to hire a technician. Help please!
  • 8 Answers
SOURCE: Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
Posted on Dec 15, 2008
  • 54 Answers
SOURCE: HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Posted on Sep 04, 2009
  • 96 Answers
SOURCE: HP Designjet 800PS
you're right it is the carriage assembly. also make sure you check for damage of the trailing cables. i haven't seen anybody wire the cover shut. if you plan on keeping this product for some time than i suggest you spend the money and have it repaired. if the tech knows his **** from a hole in the wall, than he should be able to do this repair in less than two hours plus the cost of the part. hope this helps!
Posted on Sep 24, 2009
BaronVonNuke
  • 1915 Answers
SOURCE: hi hp designjet t1100ps plotter showing
This error can be caused if there is anything blocking the movement of the carriage. I just had a client with this problem on Tuesday and it turned out that they had opened the print head cover and had not closed it properly. This caused the metal latch to block the movement of the carriage. I would check that first, as well as look for any small bits of paper that may be blocking the complete movement of the carriage.
Posted on Apr 02, 2011
BaronVonNuke
  • 1915 Answers
SOURCE: HP Designjet 800ps 24". How
Instructions are usually supplied with the belt, however if you are looking for the manual, you can find it here!
Posted on Jul 06, 2011
HP DesignJet 1050c plus InkJet Printer hangs up on axis test and ink droptest also paper axis test
Take print out of configure page, check the usage of paper axis, spit on,carriage,service station, and others includes FW.. identify which was crossed beyond 100%,replace them..update FW..confirm once be fore replacing the spares...
Oct 05, 2011 | HP DesignJet 1050c plus InkJet Printer
86:01 error in designjet 500 plus Paper jam...
System Error: 86:01
Problem Description: Carriage-Axis shutdown.
Corrective Action:
If this error code appeared but was NOT caused by a paper jam, then try the following:
  • Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
  • The Carriage is bumping into the Service Station. If the carriage is stuck at the right hand side of the Printer and cannot be moved out to the center of the Print Platen it is because the Service Station cannot uncap the Printheads. In this case replace the Service Station/Aerosol Fan Assembly
  • Perform the Carriage Movement test
Aug 26, 2011 | HP DESIGNJET 500 InkJet Plotter Printer
I have HP designjet t 1200 series printer ..Today while feeding the paper inthe roller it says remove the roller and feed the paper inthe roller 1 .what is the problem????/
For Tech Gus only:Error message: Remove paper from sheet path:
Resong: Dut dust formed on paper sensing IR sensor.. Remidy.. check the snap shots to clean paper sensor, contains how to remove, clean.. Remove right door then start follow the snap shots...11_19_2011_12_44_55_pm.jpg11_19_2011_12_45_17_pm.jpg11_19_2011_12_45_56_pm.jpg11_19_2011_12_46_48_pm.jpg11_19_2011_12_47_35_pm.jpg
Fix all carefully.. Best of luck..
Jul 12, 2011 | HP Designjet T1100ps Printer
08:11 error in hp designjet t1100
I had this code recently, and solved it cleaning the contacts pins in the formatter whit 2000 sand paper (could be pencil rubber) and reseating it.
Oct 01, 2010 | HP Designjet T1100ps Printer
HP 500ps showing error is System error 86:01
System Error: 86:01
* Too much friction in the Slider Rod. lubricate the Slider Rod.
* The Carriage is bumping into the Service Station. If the carriage
Apr 16, 2010 | HP DesignJet 500ps InkJet Printer
I need to unclog a print head on an ink jet printer HP designjet 800
Try putting the print heads in a ziplock bag with a wet paper towel for a couple of days and then run head recovery.
Feb 22, 2010 | HP DesignJet 800 Printer
Hp designjet 500 plus
Problem Description: Carriage-Axis shutdown. Corrective Action: If this error code appeared but was NOT caused by a paper jam, then try the following:
1) Too much friction in the Slider Rod. Enter the Printer Information utility and check the Scan-Axis usage. If the percentage is close to 100%, then lubricate the Slider Rod.
2) The Carriage is bumping into the Service Station. If the carriage
3) Perform the Carriage Movement test
Aug 19, 2009 | HP DesignJet 500 InkJet Printer
Printer head contact error.
no. sorry Rick but i think you really need to replace the carriage assembly, if you can find one. these printers are aged. hope this helped you.
Apr 26, 2009 | HP DesignJet 2500cp InkJet Printer
Trying to find a schematic assistance to an error reported "system error 86:01" for my hp designjet 800.
System Error: 86:01
Problem
Description:
try the following:
utility (→ Page 4-26) and check the Scan-Axis usage. If the
Service Station/Aerosol Fan Assembly → Page 8-52.
 Perform the Carriage Movement test → Page 4-8. Okay this is the error code direct from the service manual. if lubricating the slider rod does not resolve this issue then you have other problems. more than likely the carriage belt is in need of replacement. check inside of printer for debris. check under the carriage assembly. see if you are able to move the carriage assembly smoothly from side to side. hope this helps.
Mar 12, 2009 | HP DesignJet 800 Printer
HP DesignJet 500ps (42 in.) InkJet Printer Logo
Seeker5211
Seeker5211
