Question about RCA D52W19 52" Rear Projection Television
Rca 56" rear projection hdtv will not come on
I try to turn it on and the power button blinks two times pauses a sec. and then repeats.
  • RCA Master
  • 5,138 Answers
Ck capacitor cp150 2200uf 16v. there is 2 other caps also if this one is bad,(2) 220uf 35v.(3) caps all together.
Posted on Dec 19, 2008
Panasonic tc p50g15 tv will not turn on tried 1 minute unplug reset and 20 sec power button hold in. Did not work now no led lights
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 17, 2016 | Panasonic Televison & Video
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Tv truns on then turns off
if model indicated do the self check it has:
On front of set when green light for power goes out press and hold both the menu and input (source) buttons at the same time for at least 5 seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
If set has been unplugged you must plug it back and try to get set to turn on--unplugging clears the errors.
Let me know what error you find and I will tell you what it means.
Apr 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
My TV does not turn on the green light steadily blinks. Can you please let me know what I can do without calling service
When the power light comes on and then goes out, on the front of the set press both the MENU and INPUT buttons at the same time and hold them both in for at least 5 seconds and then release both buttons.
The power light will blink a 2 digit error code and repeat it at least 5 times.
The most common error will be 2 blinks, 2 blinks- a pause and then it will repeat it for a total of at least 5 times.
To get it to repeat this--you have to unplug the set, try to turn it on again and repeat the process.
The error codes are to try to narrow down where the problem is.
Let me know what error code you find and I will tell you what it means.
Dec 28, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Power turns on but within seconds turns back off
Let me know what error code you find, I will tell you what it means.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 18, 2010 | Mitsubishi WT-42311 42" Rear Projection...
I do not use this TV that often, I only turned on once a month or so. Yesterday, I tried to turn it on, by pressing the power on button, nothing shows and within 3 sec it turned off by itself, regardless...
when set comes on and then goes off: on the front of the set press and hold both the menu and input buttons at the same time for longer than 5 seconds.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
This is the self check feature this set has.
SD TECH
Sep 17, 2010 | Mitsubishi WS-55511 55" Rear Projection...
TV won't turn on.
Do the self check this set has:
when the power light goes off---on the front of the set press and hold both the MENU and INPUT (or Device) buttons for 5 seconds and then release both.
Power light will blink a two digit error code--most common is 2 blinks a pause and 2 blinks--it will repeat the code several times.
Let me know what the error code is and I will tell you what it means.
2,2 is most common and the most easy to fix.
If this information helped you rate this solution as I do this here for free.
Dec 28, 2009 | Mitsubishi WS-65712 65" Rear Projection...
Sony Trinitron Wega Standby blinks & the TV won't turn on
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Apr 12, 2017 | Sony FD Trinitron WEGA KV-32FS120 32" TV
KDS-R60XBR1 Sony Projection SXRD Power Issue?
how many times does it blink pause then blink again?
Dec 01, 2007 | Sony KP-41T65 41" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
55 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
