Question about Nikon D80 Digital Camera with 18-135mm Lens
Burning in white object picture alway burn how do i solve this problem
  • Barak Aviv
    Barak Aviv May 11, 2010
    can you click on the -/+ button and tell me what is the reading?
    Problem Solver:
  • 9 Answers
i assume you shooting P mode and then change to M mode since you say that "if i increase the shutter and apperture the picture became dark." you might have the wrong shutter aperture setting and also have choose the wrong whitebalance. You also might set the -/+ accidently to positive value. The -/+ is the overexposure or underexpose setting. This will tell the camera to always overespose or underexpose to certain stop you set by 1/3 stop. In your cases, you might set it to +1 or higher that it will overoxposed white color.
One more thing that can change the color is your white balance setting. White balance option is to control the amount and purenest of white in a picture by calculating the white according to setting.
if you mistakenly set the white balance set, your picture somehow will have more red of more blue.
You can spot the -/+ button on top off your camera, right to the top lcd, below the shutter button. Press the -/+ button then the top LCD panel will show you the value. 0 should be normal and +0.3 can be accepted. to change, with you press the -/+ button, turn the main comand dial to your right and the value will change. Put it to 0.
The camera normally set to A mode. That is Automatic white balance. in your cases, you might be set the wrong setting. A mode sometimes is not accurate. you can try K mode.(kelvin). Set the tempreture manually. 5000 and below it will be cool color. above is warm.
hope this helped you.
Posted on Nov 05, 2008
I do not understand -/+ button and reading tell me in the simple language.My question is in white colour bird feathers are always very bight i can not see the detail in it how i cam solve this problem if i increase the shutter and apperture the picture became dark.
Posted on Oct 31, 2008
I was copying pictures to cd drive...but instead window mssg appeared windows encountered a problem when trying to copy this file.what do you want windows to do?
Usually when this happens it is not a compatible burn extension on one or more of your photos it could be a MPEG a movie file from your camera. I personally use XPBurner it is free and never does this sort of thing for my CD burning stuff Windows Media always gives me issues like this. Basically it is a file that may be bad and will not take on the burn. Try it and see if that solves the issue. Click Here it is free software. Thanks for using FixYa! John
Apr 13, 2011 | Computers & Internet
TV turns on, but a picture from previous channel I was watching is frozen to the screen. I've unplugged cable cable card and connection to cable service and picture is still frozen on screen. Will not...
sounds like a burn-in but are you saying that you can view another picture but no clear because the previous picture is still there. A burn-in is a tv being left on a fixed object like a picture and left there so long this is what you see when you change channels the image burned on the screen, is this what you have?
Jan 06, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have a 2001 ford ranger and white smoke is coming from my tailpipe that smells like gas
your tail pipe is always going to smell like gas the white smoke is oil being burned from worn out valve guides or rings.
Dec 09, 2010 | Ford Ranger Cars & Trucks
Screen has been burned in - "DVD" shows & bottom right is dim & blotched.
try running the tv for a couple hrs on an all white picture, sometimes that helps get rid of some of the burn in. it has to be a pure white picture. snow might work... otherwise youre going to need a new panel
Mar 27, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Picture is lighter and seems to be blue. like one of the tubes is burned out.
These sets have two common problems. Problem #1) Convergence
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
Nov 22, 2009 | Philips Magnavox 9P6034C 60" Rear...
Dark burn in? at top and bottom of screen. TV is only 16m old.
PixelProtector is a tool for fixing stuck pixels, removing screen burn, correctly calibrating screens for optimal performance and gaining the best possible picture. Any large screen television is an investment. Poor set-up and calibration can degrade the quality of a television's image and severely threaten the life of the screen.
If you own a large plasma or LCD television with a DVD player and want to achieve optimum performance, PixelProtector is highly recommended.
3 ways to remove burn-in
1. PixelProtector for Removing Screen Burn.
2. downloading a free program called JScreenFix
Screen Burn Removal Using Your PC.
If you can hook your PC up to your screen burnt TV try this. Create a folder in 'My Documents' called 'Screen Burn'. I'm not joking keep reading. Now open up a picture editor like 'paint' available on all Windows PC's. When you run 'Paint' a blank white document is what you should have in front of you. That is exactly what you need. Select File – Save as and name your picture 'white'. Be sure to save it in the folder you just created.
Next you need to click on the 'black' section of the colour pallet at the bottom of the 'Paint' window. After you have selected black click on the 'Fill' icon (a tipped paint pot) on the left. Now simply click in the middle of your white picture and it should become totally black. Select File – Save as and name you picture 'black'. Again be sure to save it in the folder called 'Screen Burn'. You don't need paint any more so you can shut it down.
Now right click on the Windows desktop an select Properties – Screen Saver and using the drop down list select 'My Pictures Slide Show'. Now to configure the slide show. Click Settings and configure as follows. Slide the bar to 'More' so that pictures change frequently. Slide the next bar to 'Larger' so pictures fill the whole screen. Now click the 'browse' button and find the folder you made called 'Screen Burn'. In the next set of options:- Check 'Stretch Small Pictures', Un-check 'Show File Names', Check 'Use Screen Transitions' and finally un-check 'Allow Scrolling Through Pictures With The Keyboard'. Save the options.
Different versions of Windows might have slightly different configuration options but as long as the result is a completely filled (no borders), alternating white and black screen with no writing then it will probably help.
Now set your screen saver to 1 minute and leave the keyboard and mouse well alone.
As with the 'snow' and 'signal pattern' leave this for a while to see some results. If you use your TV for the PC then it might be a good idea to use this as your regular screen saver and run it frequently.
The only snag is the headache of connecting the PC up and the fact that removal technique will not be running at your screens native resolution.
Here are some more resources:- PixelProtector Screen Burn Removal and our old screen burn home page
Jan 16, 2009 | Insignia LCDTV26 26 in. Television
I have an HP Pavilion Model A6042-N computer, using Vista Home Premium. I would like to know if I can burn DVD's with this computer without buying any additional software?
you can always use a Nero 8 demo version, this will allow you to burn DVD's
kind regards and please don't forget to rate us
Dec 04, 2008 | Computers & Internet
Burning dvd's faster
Recommended Solution :
Use the link below and download the software for faster burning of your cd dvd's ,and always select the maximum burning speed.
Was this solution helpful? Show your Appreciation by rating it.
"FixYa!" - The solution provides great advice on how to solve the problem.
"Helpful" - The solution provides useful leads that helps solve the problem.
"Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
"Inappropriate" - The solution has absolutely nothing to do with the problem.
May 05, 2008 | Lite On (SOHW-1213SXBLACK) DVD±RW...
Nikon D80 Digital Camera with 18-135mm Lens Logo
107 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
