Question about Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light
LS 1013 chopsaw
Will not lock to non factory set angles
  • 2,176 Answers
If I am not mistaken there is a srping steel plate in front of the table and if this is worn or bent it will not lock. Also look at the end of the handle to ensure that is fully engaging the stop.
Posted on Dec 19, 2008
  • 4 Answers
There should be two knobs on the saw where you adjust the miter of the saw. One of these knobs if turned clockwise tightens the swivel. I have the same saw except it is a 13 amp.
Posted on Nov 13, 2008
How do l lift the handle on my challenger mmss805 chopsaw safety catch or pin
To release the head for operation, apply downward pressure and pull out the lock pin.
hope this helps
Dec 31, 2017 | Cars & Trucks
Ho acquistato un gc 1013 lafayette ma non riesco ad utilizzarlo, quando lo accendo continua a suonare e la lancetta si sposta sul lato destro. qualcuno mi puo aiutare... grazie pier
google translated
I bought a
1013 gc lafayette but I can not use it, when I switch it continues to play and the needle moves to the right side. someone can help me ... thanks pier
not sure what a 1013 gc lafayette is post a reply with details of device
Dec 28, 2012 | Computers & Internet
I have a Makita LS 1013 compound miter saw. The locking knob that locks the saw from sliding back and forth no longer works. I downloaded the owners manual and parts list but I can't seem to correctly...
check position 79 the spring that pushes against the table and also the end of the locking knob to make sure not rounded over/worn not applying pressure to the locking spring.
Dec 19, 2010 | Makita 10" Miter Saw LS1030N
2006 f 150 axle code b6 what ratio is that
This was current for the 2004 MY, so should work for at least the 04-08 MY range,
Axle Codes (LS=Limited Slip / Traction Lok):
19 - 3.55 Non-LS
18 - 3.08 Non-LS
H9 - 3.55 LS
B6 - 3.73 LS
27 - 3.31 Non-LS
26 - 3.73 Non-LS
84 - 3.45 Non-LS
86 - 3.73 Non-LS
87 - 4.10 Non-LS
89 - 4.56 Non-LS
F6 - 3.73 LS
F7 - 4.10 LS
92 - 3.08 Non-LS
R5 - 3.55 LS
91 - 3.27 Non-LS
96 - 3.73 Non-LS
R6 - 3.73 LS
Nov 10, 2010 | 2006 Ford F-150
Have new hitachi chopsaw, need blade for laminate flooring
The blade that you need is carbide-tipped, many-toothed with the proper center-bore diameter. A chopsaw is usually used for cutting steel parts and not particularly precise for flooring. Good luck!
Nov 05, 2010 | Garden
I need to know what a dropsaw is - why use one - what purpose does it have etc is there a website on using one many thanks! your assistance greatly apreciated
I assume you mean a compound miter saw. The best purpose is for finish carpentry where you need exact angles and very straight cuts. They also come in handy when you are cutting multiple items the exact same length, because you can set up a template or mark a certain length and use it over and over again.
Jul 19, 2009 | Makita 10" Miter Saw LS1030N
Makita chopsaw when cutting angles blade is cutting table
You can adjust the location where the blade drops into the groove in the table. Look on page 24 of this manual and you will see exactly how to adjust the table:
Apr 15, 2009 | Makita 10" Miter Saw LS1030N
1994 Lexus LS 400 Valet Lock Stuck - Can't Open Trunk
you have to have a main key. you may be able to remove the panel and release that way. under dash. pull cable.
Mar 29, 2009 | 1994 Lexus LS 400
hi hope to help you!
firstly see if the blade is going the correct way if so
you should replace the spindle shaft and also fit a now bolt only use makita parts though!!
the problem is the thread in the spindle and bolt are worn.
Hope that helps. Sean.
Mar 03, 2008 | Washing Machines
Makita LS1013FL 15 Amp 10 Inch Dual Bevel Compound Sliding Miter Saw With Laser And Fluorescent Light Logo
173 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
