Question about Rinnai Heating & Cooling
How many kw has my rinnai energy saver 556ftr used when it has used 8170 mj per year
  • 417 Answers
Hi
The answer is 2269 kilowatt hours.
1 kilwatt hour = 3.6 mj
Don't forget to give this solution a rating.
Posted on Oct 22, 2008
Can a Rinnai 556FTR (2010) flue be converted from straight out the wall - to out a chimney?
No, Rinnai manufacture other models with a conventional flue.
Most models these days are balanced flue for ease of installation.
Jan 07, 2014 | Rinnai Heating & Cooling
How do i clean the filter in a rinnai energy saver 1004F
Here is a link to the users manual
http://www.rinnai.us/documentation/downloads/ES38_1004RFA_Manual.pdf
Check out page 10. As it shows the filter slide up from the top rear. Use a brush or vacuum cleaner.
Sep 16, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Fault 14 on rinnai energysaver 556ftr
Hi.
Error code 14 is Overheating error.
The error can be caused by the high limit sensing overheating and cutting off. In that case the thermal fuse may not blow. The high limit can be reset tripping circuit breaker and allowing the unit to cool down with power off.
If that does not work , then the thermo fuse has blown
In fact tis unit has a thermo fuse. (refer to manual).The thermal fuse can be tested reading continuity. If thermal fuse has blown, then replace the the thermo fuse. If the thermo fuse blows again, then there is a condition causing overheating. b260351.gif
Here Full service manual.
Unless you are a trained technician call Rinnai support ringing the number in the manual. Some of testing and repair operations described are not suitable for the home user.
Regards.
Ginko.
May 31, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a rinnai heater 1004F. Since I began using it last month my electric usage is up llKWH per day. I have it set for 60 degrees as I'm using it to take some of the load off my infloor heating system....
The question is, what was you Kw usage same time last year and is the weather warmer or colder than last year? Put an Amp meter on the black wire going to the control board and start the heater. Then check the rating plate on the side of the unit to see if it is within rating.
Mar 08, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai energysaver 556FTR filter light flashing
You need to remove the filter and vacuum it. Recommended cleaning once per week.
Aug 29, 2008 | Rinnai Heating & Cooling
Heating & Cooling Logo
73 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
