Question about Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
CD ROM is openning automatically.
I have a small problem which recently generated. My COMBO Drive tray of the laptop is opening automatically. this is happening when I am using some CD or DVD in i.
please help.
thanks in advace.
Thanks
    Master:
  • 538 Answers
Hmm..maybe the lens needs to be cleaned..
Posted on Oct 22, 2008
Epic 1314 notebook how to open CD tray or does it have a CD/ROM at all
Hi
this model has cd tray
and to open in has 2 ways
1st go to my computer and select the cd rom drive and select the drive then right click on that drive ,select option eject
the tray would be ejected
2nd you will see a small hole next to the button of cd tray just put a small pin inside the hole you will listen a click sound and the tray would be ejected
Aug 15, 2016 | Computers & Internet
Need to remove a CD from DVD drive when computer won't reboot
In a laptop drive, there is a small hole in the door near the "open" button. Gently push a straightened-out paper clip into the hole and the drive will open.
In full-size drives used in desktops, the hole is usually under the tray. Again, push a straightened-out paper clip into the hole to open the tray. Once the tray slides out you can open it the rest of the way by hand.
Mar 12, 2010 | Teac (DW-224EA-AM6) CD-RW/DVD-ROM (Combo)...
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
My cd rom tray does not open
hit it on top of it or the casing and it will open. but this is not the good way but i have the same problem i use this
May 20, 2009 | LG (GCC4522BK) CD-RW/DVD-ROM Combo Drive
Cd/dvd drive
You can see a hole located on the tray of the cd rom drive. Commonly seen beside the button to eject the cd out. Grab a small pin and push the hole and this should eject the tray. Close the tray again by pressing the button. Eject it using the button. If everything still failed, call up Dell to have the CD Rom Drive replaced.
Sep 19, 2008 | Dell Inspiron 710m Notebook
Failure opening the tray
do 1 thing,take a pin and insert it in the small hole below the tray
and then press the eject button
Jun 04, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
The cd-rom door not open
Sir,
You have encountered a problem often seeen in LG models. It could have spontaneously generated or as a sideeffect of recent servicing. It is difficult to correct. so an alternative way is use a pin to force open the door.
On the front panel there will be a small mm hole through which insert a straightened paper slip to force eject the door. once door is out a little. pull it or use button to fully take out the tray.
For future, always keep a cd rom inside. that will probably let you eject the tray automatically. Problem occurs usually only withthe empty tray. good luck
Dec 04, 2007 | LG (CRD-8400CB) CD-ROM Drive
Combo drive opens and closes automatically
Arav you will have to open this unit up, sounds as thought the units slider has passed the spring sensor. with the unit open manually open the tray, there should be a spring lock release on the right with it upside down facing you. slide the tray all the way back in until you hear it click and lock. You may want to do this several times to make sure no plastic pieces have broken off. If you see or find a piece come out then achances are the spring lock mechanism has snapped, not uncommon on this drive. The screws are easily located on the bottom.
Sep 12, 2007 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Dvd-r/cd-rom automatically ejects
My Dvd-r/cd-rom automatically ejects. Please help!
Justis
Feb 07, 2007 | Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner
Dell (Y4081) CD-RW/DVD-ROM (Combo) Burner Logo
152 people viewed this question
Alun Cox
