Question about Casio QV-R41 Digital Camera
Image not visible on monitor screen
I bought my camera new 2 months ago and it has been working well. However the last couple of days I've not been able to get an image on the monitor screen. I can see the menu options and change them, and I can view pictures from the memory card, but I cannot get an image to take a picture. When I try taking a picture anyway it comes out blank. no image on the monitor.menu option is ok.booting is ok.
  • Anonymous Dec 21, 2008
    Exactly the same problem. Blank screen when actingh as a viewfinder and no pictures can be taken.
    Menu's visible and can view stored images.
  • 849 Answers
You need to install camera drivers and application software again.
Posted on Oct 22, 2008
My camera keeps turning off and turning on, the lens open and close suddenly and nothing appears on the screen, except for a short period of time i can see the image in the screen. i have take out the...
Hi, Have you tried a different battery as it sounds like the battery may be a lemon? Also depending where you bought it you may be able to return or exchange it still.
Aug 29, 2011 | Olympus STYLUS TOUGH6020 Digital Camera
I am using this camera from last 3 years. It was working fine. Suddenly, a problem occurred. Now whenever I select the Auto mode, it is set to video option instead of still image. I have formatted...
I'm have the exact same problem. Purchased the camera 3.5 years ago. Recently needed to shoot a video, when finished I set the camera back to Auto and it stayed in video. Portrait mode shows manual, all other modes work as assigned. I've noticed at least TWO other posters having the same problem within the last couple of months. It's as though this camera (mfg. 2007) has a Trojan program from the factory to make us buy newer models.
Other than resetting, is there a way to flush and reload the firmware?
May 06, 2011 | Canon PowerShot A570 IS Digital Camera
Hi I am Nithya form Bangalore, India. I bought an Acer CRT monitor (14" inches) 4 years ago. I am facing a problem with it since the last 2 days. I am unable to view the picture clearly, only part of...
Hi Nithya
Try this Turn off the monitor then unplug all the cables , press and hold down the power button for 15 sec , see whether there is any magnetic device near by the monitor , eg Anything which is made of Iron, or any metal, keep them away from the monitor , if this is not fixing the issue , i Guess the monitor need to be serviced !
Nov 09, 2010 | Acer Computers & Internet
Camera does not react
I quote: "A couple of days ago after using it when trying to see the pictures on the camera the LCD did not show anything. The lens reacted and even take pictures but nothing was visible on the LCD screen."
That means that there was a problem either with a LCD display or with ribbon cable.
Now:"I tried charging the battery and removing it from the camera, now the camera only does a bit sound when switching on but nothing else, the lens does not even come out."
That means that the ribbon cable had probably shorted, now the camera may be furtherly damaged.
The camera must be disassembled to access the LCD and fix the problem.
The repair must be done by an experienced technician, as to access the LCD you need to remove both covers.
Jan 07, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Cracked Screen for a Panasonic DMC-TZ4
Not worth replacing screen, due to labor cost so if camera works, it can still be used for snapping up shots if set on automatic and can be connected to monitor source e.g. gps monitor, portable TV,etc to view pics or change settings. Can try selling cheaply online and use money for new camera.
Nov 14, 2008 | Panasonic Lumix DMC-FZ8 Digital Camera
Thrutech 20' tv/dvd
A common problems is the backplane lamps and or the backplane power supply. Sometimes the main supply or one of the processor boards can have a fault condition where there is no picture.
You can verify if only the backplane lamps are not working by shining a flashlight in to the screen at an off angle, and look carefully to see if there is any image on the plane of the screen.
Jerry G.
Apr 16, 2008 | Televison & Video
Monitor went black
Same with mine a couple days ago. I've been told the contacts have oxidized and need to be cleaned. It was going to cost about $80 to fix and no guarantee how long it would last so I just bought a new monitor.
Jan 04, 2008 | Dell E173FP 17" LCD Monitor
My viewing screen is black. I had successfully taken a picture, viewed it, and turned the camera off. When I turned it back on about 30 seconds later, the viewing sceen was black. I can 'take' a picure, but it comes out black. Help!
Nov 12, 2007 | Casio Exilim EX-V7 Digital Camera
Casio QV-R41 Digital Camera Logo
158 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
