Question about GE JGBS07PEAWW Gas Kitchen Range
My range pilots work fine but my oven pilot will not light. Do pilots wear out after 4 years? Is it easy to replace a pilot?
Please assist - I have followed the GE owner's manual and used a match and even tried a Scripto igniter to light the pilot and it never appeared to be lit. Do I need to replace the pilot mechanism and if so how difficult is that to do? I do not want to get ripped off by some repairman that sees me as an easy target due to my ignorance about oven repair. Does anyone have an opinion regarding home warranties -- does it make sense to get one? I have a feeling that parts of our other appliances may be sputtering out soon. Any advice would be appreciated.
  • Anonymous Feb 02, 2009
    I do not smell gas ..nor will the pilot ignite with matches..etc... not sure why not.. no clicking when turning the oven on as well... will not lite at all..Is this something I can repair myself?..thanks for your help....Hotpoint.. that came w/ the house..I have had it for nearly three years.. not sure of the age..
    President:
  • 878 Answers
Trey, this is not a hard fix. More than likley your ignitor for the oven has gone bad. It has to draw a certain amount of amps to open the gas valve. If you remove the bottom panel in the oven, should be 2 screws in the back and lift it out, you will see the flame spreader. Remove this, should be a couple 1/4 inch screws. Now you will be looking at the burner and ignitor. The part number for the ignitor is wb13k0021. The ignitor is held on to the burner with 2 1/4 inch screws. It is not uncommon for these ignitors to fail within 4 years....Catriver...post back.
Posted on Jul 29, 2006
The world today and gas prices.....people are even charging people to answer simple question as well in this world today.
long story short....i have a kenmore gas range and thought my pilot would not light, so in such for answer and a 300 hundred dollar extra protection ran out. nobody could answer a question without a buck in there hand.
solution. i give up.....as i give up after three hours. i decide to put everything back together that i ripped apart. i figured let me put the burner plates back on that my wife decided to take off to clean in which thats when hell broke loose. i thought she broke it trying to over clean the stove. anyways....problem solved.
the buner plates needed to be ON has a safety feature to the free standing gas range. in which everything ignited all well. so i hope this will help someone in the future... good luck to your problems cause i did not have any. well, i kind of did, did not cost me a thing but a night in the dog house.
kenmore freestanding gas range.
model 790.
visit www.center50.net
Posted on May 08, 2008
Where is the pilot light on a GE profile gas stove? The burners suddenly would not light except with igniter.
Please add the make and model number of the stove. Modern gas stoves and ranges do not have a pilot light. They light the gas with an electric spark. On these models, there is a knob setting for "Light" which triggers the spark. If there is no A/C voltage to the stove, you can use a match or butane lighter to light the stove with care.
I've found that the ignition system can fail if the burner caps are not seated properly. Debris in the burner area can also lead to the ignition spark problems. If you take off the burner cap and head (for some models), the electrode will be visible. Clean off any carbon build up on the electrodes for better sparks.
Jan 22, 2017 | GE Kitchen Ranges
How do I get the pilot light to light? Are there replacement parts I should consider?
On lots of cookers fitted with pilot lights there was an option of turning off the gas with a small screwdriver turn tap located under the splash tray. This is because a pilot light should never be used if the gas supply is via a prepayment meter, though to some extent modern safety designs have altered this situation.
As the cost of gas rose the pilot light was soon costing a significant amount of money each year and many owners turned them off and used matches instead.
If your pilot light isn't working and you have followed the instructions exactly and it won't even light with a match it is either turned off, blocked or the safety thermocouple, if it has one, has failed.
Most of the parts for such appliances are replaceable and available but some checks that can only be performed by experienced people must be made before any faulty part(s) are indentified.
Jun 26, 2015 | Kitchen Ranges
Need to purge air from gas line for water heater
It could be that the gap for the igniter is too big Try lighting it manually There should not be that much air in the line .
Jun 14, 2017 | Rheem Water Heaters
Error Code E-08 on Samsung Gas Range. Oven will not heat but range top works.
Is there a gas pilot light that stays lit all the time or does it have an electric pilot light that glows red to start the oven.Either way if it's a gas pilot the thermocouple is bad, if electric the igniter is bad.
Jan 03, 2014 | Samsung Kitchen Ranges
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven...
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Oct 17, 2013 | Wolf Range CHR-10-229-FT11 Kitchen Range
Oven pilot light won't light. Stove burners work fine.
if you have a pilot flame oven replace your thermocouple
if you have a newer oven you will have an ignitor
please advise me on whitch type of oven you have
Feb 05, 2013 | General Electric ge JGBS04BPW wb1k5 Oven...
GE (Rheem) SmartShield Water Heater. it rained on the hot water heater and now the pilot won't light. Any ideas?
Does it have an electric ignition? If so, remove the pilot light access panel, blow inside the chamber with a hair dryer. Do this until there is no more moisture inside. Then follow the lighting instructions. Try this even if it's a match start. Thanks and please rate.
Sep 05, 2011 | General Electric Water Heaters
I just got my (new to me) pre-1990 Wolf 36'' range connected (by a certified pro). 4 burners, 12'' fry top/charbroiler/cheesemelter thingie on left, 4 burners on right, 29'' oven - propane. It has not been...
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Feb 02, 2010 | Wolf Range CHR-0-29-FT34 Gas Kitchen Range
I have a Frigidaire gas range, model #FGF316BSA. When I attempt to operate the oven it won't light. The glow bar comes on but nothing happens after that.
Hi
Thanks for using FixYa. From what you have described it seems that possible oven control is not sending gas for the pilot light. The pilot light works but no main burner ignition - possible pilot assembly is dirty and the pilot flame is too small, safety valve and thermocouple is faulty, the bulb from the safety valve is out of position and the pilot flame is not touching the thermocouple bulb. Some ranges use a standing pilot light ( small flame is on all the time ) while others use an spark ignition to light the pilot light flame and the pilot light flame heats up the thermocouple bulb to allow the main gas to flow through the oven burner.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 15, 2010 | Kitchen Ranges
GE JGBS07PEAWW Gas Kitchen Range Logo
1,400 people viewed this question
Top Kitchen Ranges Experts
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
