Question about Insignia IS-LCDTV32 32 in. Television
Insignia tv lcd 32inch menu display keeps flashing
It is a32inch insignia lcd model #NS-LCD32FS. When it's turned on it comes on normal but the next instant MENU comes on and keeps flashing (on....,off.....on....off...)
  • 2 more comments
  • tattooaddict Nov 21, 2008
    i have the same problem
  • ioubig68 Nov 25, 2008
    My problem is exactly the same - the flashing menu comes on every time the TV is turned on. the menu appears no matter what input is selected. Pressing menu or exit on the remote only makes the problem go away very briefly and then the menu continues to appear.
  • jevertsen Dec 20, 2008
    I Have the sort of the same problem. When I turn it on it flashes for 2 mins and then its fine. so We left our tv on for a couple of days figuring this would but now it is falshing and like half the tv is darker than the other half what is going on???????
  • Anonymous Feb 24, 2009
    Same problem here with my ns-ltdvd19 model. It's annoying as heck. I want my money back!
5 Suggested Answers
SOURCE: Insignia NS LCD32 standby light blinking off and on. No Power
I had this problem as well. Actually best buy just left my hosue to fix it. This is the second time they were here to fix it. The first time they said a part was loose. This time they had to replace a part.
Posted on Apr 01, 2008
  • 2270 Answers
SOURCE: Insignia NS-LCD37-09 turns on but no image
If your TV is less then a year old, still under manufacturers warranty. If not under warranty the defective parts could be the power supply or the back light inverter board. Both boards can be replace easily.
The way to know if you have a defective backlight inverter is by shinning a light from a flash light near the screen with the TV on and check in a 45 degrees angle if you have a dark video in the background, if the video is present then you have a backlight board failure. If no video, then is a power supply failure.
I have both boards if you want to buy them.
Let me know if you require further assistance.
Posted on Jan 08, 2009
SOURCE: Can't program my DirectTV remote to control my Insignia TV (no Insignia remote code on DirectTV's remote programming menu)
I have an insignia TV 32" and I used common code 10463 to program my direct tv remote. hope it works for you.
Posted on Aug 28, 2009
SOURCE: Insignia 22'' LED HDTV screen resolution problem with VGA
I think this stems from the fact there is no VGA mode designation (not plug and play) however there are VGA H&V settings that may be overidden from autodect mode under ADVANCED in teh menu. What sux is that it isnt stored and must e reset when input changes. FIRMWARE UPDATE PLEASE INSIGNIA!
Posted on May 22, 2010
  • 22 Answers
SOURCE: I would like to download a manuel for my Insignia
http://insigniaproducts.com/cms/documents/manuals/NS-42_46_55L780A12_11-0043_MAN_V1_EN_Final_lr.pdf
The URL above contains the user manual in PDF format. Your browser probably has the appropriate add-ons to view the manual from within the browser. Near the top should be a save button along with a print button. You can either save it to your computer or print for later reference.
Posted on May 05, 2011
I have a Insignia 32 inch LCD TV Model number NS-LCD32. It recently started displaying no inputs. The backlight comes on but no inputs/ no sound. Green lines display if you press the menu,input, channel...
The first troubleshooting step would be to measure all the voltages from the power supply to the other circuits boards specially the 5 volts going to the main board. If you have the following: Insignia 6HA0112010 Power Supply, check FU502 for open conditions.
If all the voltages appear normal, then the main board should be replace since is hard to find individual components for a component level repair.
Let me know if you need further assistance.
Aug 21, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
The tv screne picture on my insignia tv is off centered and is split in two
I suppose your TV has a PIP function.
  • check if u have a PIP function on your remote control or
  • Go to the Menu n in the display see if u can see the PIP function or the Aspect Ratio function like 4:3 or 16:9.
  • You have to switch it to standard or normal view to change to one full picture.
Jun 04, 2009 | Insignia NS-LCD19 19 in. LCD TV
INSIGNIA 32 IN FLATSCREEN MODEL NS 32LCD
check for capacitors on the power supply that are puffed up. Also the mai board can cause this but the power supply is where i would start.
Jan 08, 2009 | Televison & Video
Accidentally locked out of my TV
Unfortunately with this model of Insignia you MUST have the remote that comes with that model number in order to unlock it. Other Insignia remotes won't work. So I have ordered another remote from an online company. Hopefully that will work. I'll probably have to call Insignia to have them walk me through it once the remote arrives.
May 24, 2008 | Insignia LCDTV26 26 in. Television
Insignia NS-LCD32FS strange behaviour
Sometimes this can be fixed by removing the power plug from the wall and either allowing it to sit or grounding the power leads together (UNPLUGGED) to remove and residual charge. I know it sounds nuts but it has worked for me on three separate electronic devices
Mar 29, 2008 | Insignia IS-LCDTV32 32 in. Television
Insignia IS-LCDTV32 32 in. Television Logo
629 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
