Question about RCA M100256 256 MB MP3 Player
Cuts off on me
When i charge my mp3 it says that its fully charged but when i start listening to my music it will just turn off.
SOURCE: My RCA LYRA mp3 player isn't working!!!!!
keep turning it on everytime it turns worked for mine.afterwards plug it back in and let it fully charge
Posted on Oct 26, 2007
SOURCE: shutdown
Turn the hold button on th side to off. Worked for me
Posted on Mar 13, 2008
  • 44 Answers
SOURCE: rca opal mp3 player
leave it on till the battery runs out or push the reset button on the back of the player with a pin, or a paperclip
Posted on Apr 01, 2008
  • 3 Answers
SOURCE: it will not play music
I was having trouble with my daughter's MP3. The RCA website said to download Pearl Firmware (Version 2.) ( I did, several times, but it would not work. Finally, I cheked the box "Format Data Area" under Download options. Once I did this my computer immedialty saw the Pearl and I was able to re-load all my daughter's songs in Media Player.
I hope this helps. I was so worried that I was going to have to buy her a new player.
Posted on Feb 28, 2009
  • 7 Answers
SOURCE: mp3 player was charged and being used, tried to
If you was trying to listen to it and charge it at the same time, then your mp3 will not work after that. The mp3 was designed for it to onyl charge. Its not a multitasking device.
Posted on Dec 28, 2009
  • 17129 Answers
SOURCE: mp3 player dies after one or two songs even fully
If even affer charging for a long time the battery is draining off you will need to change the battery. Remove cover carefully test and confirm before you replace. attempt only if familiar and to do it carefully.Good day
Posted on Jul 04, 2010
0 characters
1 Points
I listen to the music for 1 hour. I turn the lock switch off. The next day the Go gear MP3 has completely discharged. I re charge it on the pc. The screen reads 'Fully charged'. The same thing...
There are two things possible.
1) You have defective re chargeable batteries in your GoGear.
2) There is some short circuit because of which the re chargeable cells are discharging.
Either way you should get the system changed. If you want to confirm if its the battery defect or GoGear. Charge the system fully and play music continuously. If the Go Gear plays for about 4 hours with out break---- its not the battery but the charging system.
Mar 14, 2011 | Philips GoGear SA3020/37 MP3 Player
Can you keep player plugged into usb charger while playing music files indefinatly or will it over charge and possibly cause damage? im shopping around and am not even shure it will play while pluged in to...
You can keep the Sansa plugged in without fear of overcharging. The Sansa will play while it is connected to a USB port that is supplying only power, such as a USB charger operating off a car cigarette lighter. It will not play while connected to a computer.
Mar 09, 2011 | SanDisk Sansa Clip MP3 Player
Does a sylvania 8gb mp3 have to be fully charged
No it doesn't have to be fully charged as long as there is enough battery to turn on and play music it'll turn on it'll also remind you if the battery is low
May 30, 2010 | Sylvania SMPK8858 MP3 Player
Wont turn on unless plugged into computer
Hi it very much sounds like the on board batttery is not charged up, (not charging) hence when you plug into the PC it gets it supply from the USB 5Volts and plays as normal
Apr 15, 2010 | SanDisk Sansa Clip MP3 Player
My green Apple Nano Chromatic iPod's batter life & other problems
turn the backlight down or maybe let it charge even when the battery says its fully charged!
Dec 15, 2009 | Apple iPod nano MP3 Player
Charging the Sansa Clip player
If you leave your Sansa plugged into your charging source (wall charger, computer, car etc.), your player might still remain fully charged and just on. If you can, you may want to just leave it plugged into your charging source until you want to use it, so it stays fully charged.When its done, it will say fully should take a couple hours to charge the device....
Also, does your player have an auto power off or idle sleep setting? You can use this setting to set the amount of time you want your Sansa to automatically turn off after you don't use or listen to music on it.
Jan 01, 2008 | SanDisk Sansa e250 MP3 Player
Oct 19, 2007 | RCA Lyra RD1072 MP3 Player
I cannot charge it (USB car charger) and listen to the music at the same time
don't think it's possible. -when you charge and play via your laptop, the player is acting as a USB key and the laptop is doing the playing. -when you charge it via your in-car port you do not have a 2nd device on which to play tunes. it's either charge or play i'm afraid
May 22, 2007 | Samsung YP-U2X Digital Media Player
Sansa MP3 player charges, plays while plugged into wall, but not unplugged.
When you plug it into the wall make sure you turn it off and let it charge all the way before you start using it again. see if that helps
Apr 25, 2007 | SanDisk Sansa e250 MP3 Player
RCA M100256 256 MB MP3 Player Logo
16 people viewed this question
Top RCA MP3 & Digital Media Players Experts
Gyula Lacz
Are you a RCA MP3 and Digital Media Player Expert? Answer questions, earn points and help others
