Question about Olympus EZ 14-45mm f/3.5-5.6 for SLR
Cannot auto focus?
Hello everybody I have a olympus 14-45 lens which accidently fell down and now cannot autofocus or manual focus? any ideas....
This happened to me as well. Fixed it easily, once I balled up and took apart the lens.
bike guy is right on the money. The linkage between the autofocus motor and the lens assembly has popped out.
Luckily, this repair does not require and parts. The linkage just slides back together.
Take apart the lens starting from the back. After removing enough parts you should be able to see down into the lens and at the lens assembly that moves when you zoom. There should also be a ring that, has 5 contacts facing up, and if you move it turn the AF motor.
You should see the linkage coming off this ring and should see where it should sit. If the problem is this linkage (which looks like a bar extending towards the front of the lens), it won't be seated properly. Use a small screwdriver to pop it back in.
This repair requires a bit of handiness, but mostly it's just taking out small screws, being patient, and putting it back together. I'm not going to put instructions, because if you're going to take apart a lens, you should know your way around electronics.
Posted on Aug 21, 2008
  • mcalva Oct 04, 2010
    Thank you very much. I don't know how but i did.
  • 75 Answers
Nokinnikon has some good things to say, but the lens is repairable. What usually happens is the link between the focus motor and focus ring is dislodged. A competent repair shop can remedy this.
Posted on Mar 25, 2007
This happened to me today, my lens fell out of the lens pouch and bounced across a concrete sidewalk!! Thank goodness I found this thread. With Alienshards suggestions I opened up the lens and after much fear and trepidation indeed found the linkage was unseated. Popped it back in, put it all together (took longer than getting it apart) and Bob'sYerUncle! Works great again!!
Thank goodness for this thread and Alienshards
Posted on Oct 15, 2008
I had the same thing happen to me an I ws able to take the lens apart from the back and snap the linkage back in.
galen
Posted on Nov 09, 2009
    New Friend:
Excellent advice! Took me 30 mins to fix it... After I had to unscrew-it again because I missed the last cable inside!
Posted on Jul 21, 2013
    New Friend:
Thank you so so so very much! I read the thread and I dared to try to fix my lens which had the same problem and...success!
Posted on May 06, 2013
I've taken out the main four screws and then some, but I'm not sure what the "linkage" y'all are talkin' about? i can't even seem to get the main metal part to come off because it seems to be attached to the lens by this orangey plastic strip...?
Posted on Apr 20, 2010
    Problem Solver:
  • 6 Answers
Without being smart, you could buy a new one or get it repaired or dry your hand of grease next time you touch it or start juggling this saves a lot of grief!!!! or you could check the lens mount to see if you have dislodged the coupling on the lens mount.# jason
Posted on Oct 10, 2006
SOURCE:
Autofocus problem on canon 135mm f2
If it focuses OK on manual focus and won't focus on auto focus the problem may be down to a broken ribbon cable in the lens.
May 06, 2017 | Canon EF 135mm f/2.0L USM Telephoto Lens...
I have a weird problem. When i put the 50mm 1.8 on my D90 it continues to autofocus even when I switch the camera body to M mode instead of AF with the switch. I would like to be able to manually focus...
You probably have a problem with the A/M switch on the body-- flipping that switch should extend or contract the autofocus pin that drives the lens. This particular lens doesn't have its own focus motor, so there's no way that it could be focusing on its own without the pin from the body driving it.
Try taking the lens off of the camera and looking at the autofocus pin as you flip the switch from auto to manual focus.
Mar 10, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikon auto focus lens not working, only in manual
What camera body? This lens doesn't have an internal focusing motor and thus will not autofocus on the D40/D40x/D60/D5000/D3000.
Sep 10, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Nikkor 70-300 f/4-5.6g lenses will ont auto focus on my D70
The focus motor gear assembly likely has a damaged gear. It will need parts replaced.
May 20, 2009 | Nikon 70-300/4-5.6 G AFD Nikkor Zoom Lens
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Nikon d40 autofocus
Look on the left side of the lens. Make sure the button is on A for auto focus and not M for manual. OR not stuck in the middle. Hopefully that will solve the problem.
Jul 11, 2008 | Nikon D40x Digital Camera
Auto focus not working properly
I have the same problem with my camera. What did you do about your autofocus mess?
Oct 27, 2007 | Olympus Camedia C-2040 Zoom Digital Camera
Olympus camedia c-300 zoom auto focus
hi, really surprising, how could you fix the problem, it will be fixed only by replacing the lens assy. so just go to olympus shop. good luck....
Jul 28, 2006 | Olympus Camedia C-300 Zoom Digital Camera
Olympus EZ 14-45mm f/3.5-5.6 for SLR Logo
647 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
