Sata DVD burner
Hi. I want to use a sata DVD Burner while using a IDE hard drive. when I connect the DVd drive and start the computer I get a message say [Boot disk failure] insert system disk andpress enter. my Gigabyte motherboard GA-8EANXP-D has four silicom 3114 connectors.& 4 SB sata connectors I have gone into the device manager and the Sata Image Sil3114 controller is there and working fine, I went into the cmos setup Utility and have these settings. Onchip primaryPCI/IDE enabled. Sata raid/AHCI mode [Raid] shut down and restarted same problem, went back in again and set onchip sata mode [ Auto] would not start up. went into the raid configuration Utility. in the Phyical and logical drive it shows the HL-DT-ST-DVD Ram GH-20 CD-Rom. I hope you ca assist me with this problem. Many Thanks. Terry.
  • Terry Horton Oct 22, 2008
    Hello Pablocsa. Thank you for the quick reply. I went back into the [standard Cmos Feartures]. The setup is like this. IDE Channel 0 master St 3160812A. IDE Channel 0 slave DVD RAM. I discoonnected the DVD Ram on the slave to see if there was a conflict still would not start. I changed the hard drive pin select to cable select still no start. [The intergrated peripherals] serup is like this. on chip primary PCI/IDE [enabled]. Sata Raid/ACHI mode [Raid] H/W Sata Function {Raid] I went back into the raid configuration Utility and there is nothing to setup as it is asking for the raid set. Raid 0 Raid 1 RAID IO. I want to know why it will not load and work the Sata DVd burner. Many Thanks. Terry.
    Genius:
  • 1,124 Answers
This is happening because the DVD SATA is booting like a first drive instead of the IDE Drive.
Be sure that your SATA drive is connected to a right port on your motherboard.
Go to your bios and into the boot options be sure that the IDE drive boot first than the SATA DVD.
Another way is connecting an adaptor SATA to IDE and connect your SATA DVD Drive as second IDE on your motherboard.
This will be fixing your problem.
Have a great day
Pablo :-)
Posted on Oct 22, 2008
LG dvd external drive not recognized by computer
ERROR 43? Check your SATA connection.
HERE'S HOW I FIXED MINE.
(IE. Computer tries to install driver for BD burner, but ultimately fails, and gives the message. "Unsuccessful" and/or "Microsoft Windows stopped device. Error 43") The SATA CONNECTION on my BD burner's EXTERNAL CASE had gone bad.
TO TEST IT. I used a SATA/IDE to USB Adapter Cable I bought for about $10 on amazon.
  • I unscrewed the external case to get at the internal drive, and plugged the SATA adapter cable directly into the internal BD burner drive (bypassing the case assembly), and plugged the other end into my computer USB port.
    • PS My BD burner POWER was working OK, so I left the big white 4pin power adapter connected to the original external case.
VOILA! Both my laptop and my desktop PC recognized the LG BD burner again and assigned it a drive letter (like it used to do).
  • Now I either need to (1) Buy a NEW EXTERNAL case ($10 - $30), (2) install it as an internal drive (could get problematic if "ANYDVD" is installed) or (3) just leave it connected via the cheap adapter cable.
It's super EASY (& inexpensive) to TEST this before spending $$$$ on a new equipment.
Hope this helps someone. It had me miffed for a while there.
Jan 02, 2014 | LG GSA-2166D DVD RW Dual Layer Burner
D945gtp how to connect cd-rom hardware
1) IDE {PATA} DVD burner drive:
For an IDE { PATA } DVD burner, connect to the 40-pin IDE header on the motherboard. This is located to the right side of the Ram Memory slots.
It is the longer header that has 40 contact pins. {39 actually}
( The shorter connector on the motherboard is for a Floppy Drive.
{34 pins} It is above the IDE 40-pin connector )
NOTE*
The IDE connector on the motherboard should be keyed. Should have a cutout on one side. This is so the Number 1 pin in the flat IDE ribbon cable, will line up with Number 1 pin in the motherboard connector.
Some flat IDE ribbon cables, do not have a Locating Lug on the connector. (Small rectangular 'bump')
Number 1 pin on the IDE ribbon cable will be on the side that has a faint RED stripe on it.
Number 1 pin in the motherboard connector is at the Bottom, with the motherboard installed.
The side of the flat ribbon IDE cable that has the faint red stripe on it, goes DOWN, when installed in the motherboard connector.
If the DVD drive does not have a cutout for it's circuit board, the faint red stripe of the flat ribbon IDE cable, goes towards the power cable connection.
2) SATA DVD burner drive:
You have 4 Serial ATA headers (Connectors) on the motherboard.
Your SATA harddrive should be plugged into the SATA1 header.
You can choose any open available SATA header, to plug your SATA DVD burner drive into.
BIOS will see it once you turn the computer on.
3) If you somehow have been using an IDE {PATA} harddrive, and have it connected to your IDE connector on the motherboard, you SHOULD not use a DVD drive on that flat IDE ribbon cable, also.
BIOS has to find which device has the Operating System on it, (Windows), and then hand the computer over to the Operating System.
To state again, BIOS will look at both devices connected to that flat ribbon cable. The Harddrive, and the DVD drive.
It will then determine that the Harddrive, is the device that has Windows on it, not the DVD drive.
This slows the computer down, and could result in a blue screen.
If you have an IDE harddrive plugged into the motherboard, it would be best to use a SATA DVD drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
May 28, 2012 | Intel D945GTP Motherboard
Will an IDE DVD Burner work on my Acer Aspire E380 desktop. The hard drive is a SATA but the burner looks like an IDE and has belt cables. I need to replace my DVD burner and not sure what type of burner...
Yes, all you need is a IDE (Pata) to IDE (Sata) converter.
If you're replacing it, just make sure you get one with the correct interface, judging by what you sat SATA.
Mar 13, 2010 | Acer Aspire E380-ED422A PC Desktop
Will a SATA DVD Burner work in my Acer aspire 380 Desktop?
Hi
Thank you for your query
The answer is yes and no
No in the sense that you only have one IDE controller which is currently feeding your CD/DVD drive and the other is 1 SATA controller that is going to your hard drive HOWEVER yes in the sense if you purchase a sata splitter for the drive and a sata splitter for the power you could power both the SATA burner and Hard drive off the main cable.
This is not recommended and you do so at your own risk
I hope this has been useful
Mar 09, 2010 | Acer Aspire E380-ED422A PC Desktop
I want to install a 2nd dvd burner. But I don't know how to hook it up. My new pc does not have the ribbons like my old one does.
If your 2nd DVD burner is on IDE interface, you may need to get an IDE to SATA cable. Please refer to the picture below as to how it looks like:
Oct 29, 2009 | Compaq Presario 5000 PC Desktop
Gear Head Lightscribe 24x DVD+/-R Triple Format SATA
Your original CDROM drive is likely an IDE interface (large rectangular connector), where as the new one is a SATA interface (small narrow connector). If your original is an IDE, the simplest solution is to return the SATA and purchase an IDE DVD.
Oct 26, 2009 | Gear Head 8XDVDEXT DVD External Slim...
What is this system ide or ?? looking to purchase a hard drive (500gb) and a new CD & DVD burner.. Just don't want to buy the wrong item.
What mother board is it? you have sata and ide drives.. new technology is sata which is connected with sata cable to *********** board and appropriate pover coard, the older teconlogy is ide, which is connected with ide (master slave) cable frm you motehr board to you drive... just post what mother board and i could be more specific...
Jun 28, 2009 | HP Pavilion a705w PC Desktop
How do I connect Burner to IDE cable?
Yeah its a SATA and you need a SaTa controller to put into your computer you cannot connect this via ide
May 23, 2009 | ASUS DRW-2014L1T DVD-RAM Burner
Computer won't recognize sata dvd burner
is jumpers on corect cant u just use ide cable instaed u said your going from ide to sata cable ?
Jan 19, 2008 | EliteGroup P4VXMS (P4VXMS-R) Motherboard
Computers & Internet Logo
457 people viewed this question
David Payne
David Payne
