Question about Seagate 20PK 500GB BARRACUDA-7200.9 16MB SATA N (ST3500641AS20TP) Hard Drive
Hard Disk not formatting
On starting my computer a message showed "Error loading O.S."
So I tried to format my hard drive.But during installation of Windows XP an error cropped that "the sectors of the hard disk where table is stored is corrupted".After this the installation stopped. I tried it many times but same problem is shown. Please help.
  • MiiiT Oct 22, 2008
    I told that the Operating System is not loading and neither the formatting is taking place.
    So,I can't go to my computer........
    Please suggest something else.
    Master:
  • 538 Answers
Ok..you may want to do a chkdsk..open my computer..then highlight the main drive..right click go to properties. then you will see some options..tools is what you want..click on that tab, and them there will be an error checking option..follow that through, and it will run on restart..
Posted on Oct 22, 2008
Recovery disk for SX2855-UB10P
At what stage of the installation process do you get the message ?
Which operating system are you trying to load ?
Is there an operating system on your hard drive ?
You have to format your hard drive using a third party disc to erase everything on your hard drive
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Hope this helps.
Jan 24, 2013 | Gateway SX2855-UB10P Desktop - 2GB Memory...
I was using a 500mb conner hard disk but now 4.5gb seagate hard disk but can't format it
you have to format your hard drive using a third party disc to erase everything on your hard drive
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating systemor if you are trying to format a usb drive
insert your pen drive
click start click on my computer you should see your pen drive
right click then select format
another way is to control panel administrive tools,computer management disk management right click on your drive select format
hope this helps
Mar 27, 2012 | Computers & Internet
My laptop lenovo ideapad y450 shows blue screen error.i tried to format with windows xp also,but it appears once format was completed also.advice me pls
Dear! Delete your C drive and create again with the help of windows and then format and install Windows. Your problem will be fixed.
Jul 27, 2011 | Computers & Internet
I have compaq nx6310, i had issues with the os.once you touch a button it starts open other buttons and pages automatically. i tried restoring the system to earlier dates and the issue reduced. later on it...
Hi das4real! These are the things to consider.
  • Operating system disk - Try to test your Installation CD to other computer. If it doesn't work then you need to replace the disk
  • Optical Drive (CD/DVD Drive) - If Installation disk works then try to clean your Optical drive lens as it may be having a hard time reading the disk. Your Optical drive is working since you're able to format and able to start the installation. Cleaning the drive lens may do the trick.
  • Hard Drive - If Installation CD and Optical drive is clean. Then the last thing you need is to replace the Hard Drive. You Hard Drive might need replacement due to some bad sectors and the installation couldn't write anything on the drive that causes to freeze during installation.
I hope this helps you.
Mar 15, 2011 | Computers & Internet
I wanted to wipe my entire hard drive on my old Dimension 8400 that contained windows xp on it and reinstall it with windows vista, which i have the cd for. however, when i did so, each time i try loading...
1. you will need to know 1st that the hard drive you are installing is compatible with the desktop.
2. Is the hard drive compatible with the new Operating system (VISTA).
3. Check to see if you have the hard drive properly inserted that is properly cabled and connected.This will render error in installation.
4. Make sure you are installing the Operating system correctly.
5. Some boot sectors become corrupt during a change in Operating system if the hard drive is not properly formatted.
6. Try formatting the hard drive again and re-installing.
Feb 12, 2011 | Dell Dimension 8400 PC Desktop
Sir/madam My toshiba HDD2189 si damage. I cannot check the HDD. I was see error message in computer. When I format now, computer error message was said "your HDD is damage". so, I not format yet...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
also
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
if this fails to fix the problem and you still want to format your hard drive
During the boot process you will see on the screen to press a certain key to enter setup
cmos to restart
(note after you have loaded the operating system you must go back and change the first boot device to your hard drive)
???????????????????? hope this helps
dont forget to vote
Feb 08, 2011 | Toshiba (HDD2189) 60 GB Hard Drive
My PS3 display's the following message when i turn it on..."The hard disk's database will be rebuilt" - When i click 'ok' it displays "Rebuilding the database, do not turn off the system." - Immediately...
s_kounou
If the hard drive is hanging on the format the drive table may have just gottten corrupted. This can happen with a computer but the operating system can fix this usually. The link below will take you through connecting the hard drive to your computer and using it to format the drive. If the computer hangs on the format and/or you still have trouble with the drive then there is something wrong with the drive and you will have to replace it.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Hard disk formetting
hi,
I think low level formatting should do the trick. you can download it and its free. In your case try to download the DOS based version. This type of formatting erases the entire disk clean.
Jun 07, 2009 | Microsoft Windows XP Professional
PEN Drive error
right click on my computer after inserting the pen drive in usb, click on manage and select disk managment from left pan, you can format your pen drive by right clicking on it
Oct 24, 2008 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Seagate harddrive diskread error
go to bios and see there whether it is showing showing your hard disk or not if it is showing then re-install your XP again format your hard disk with the slow formating option,while re-installing it.
Nov 23, 2007 | Asrock GE PRO-M2 Motherboard
Computers & Internet Logo
101 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
