Pixma iP4200 Green light flashing, but printer not responding. "Status 81"?
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same prob with my brother mfc 465cn printer while trying to print a pdf file on my mac.  I ended up going into the page setup menu and had to select my printer in the "format for"  section.  Hope that helps..
Posted on Jan 04, 2009
The middle light keeps flashing 7 times then stops then repeats. the other button to change the paper type. i dont think its a ink issue possibly a paper one.
This mean multiple ink tanks of the same color installed or Ink tank in a wrong position.Check your ink tanks.This ink tanks has a memory chip.Sometimes this chip fails.
If the green light blinks with a orange 7 times this mean the waste ink tank is full.Follow this:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip4300 ink absorber is full
You need to reset the waste ink counter. The printer doesn't know that you have replaced or cleaned the pads you need to tell it.
1. Turn off printer
Hope that helps, if it does please rate my solution.
Thanks
Nov 03, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
PixmaiP6700D:error#300. "The printer does not respond. Make sure that the printer is plugged in, powered on, and properly connected to your computer." I've checked all of the connections and...
Error Code300--
1. Turn off printer
Sep 05, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Flashing Error
Hi , the printer need to reset , the factory setting are already exceed the copies of used , so the printer need to reset to obtain zero counter .try to visit the web site of canon fixma .com.
Feb 21, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon pixma ip4200 printer
1) Under printer options make sure that greyscale is NOT selected. I.E. Color Printing.
2) Make sure page layout is set to 1 (Not 2 per page)
Check margins of page are set to minimum size.
Jan 24, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma iP4200
When you plug your printer into the computer, what does the computer say?
Count how many flashes you are getting. Look in your owners manual to see what it says for that number of flashes.
Nov 27, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Flashing lights
Count the number of flashes and look the error up in your owners manual.
Oct 05, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon Pixma iP4200
have you refilled these? If so you must disable the status moniter for it to work. If they aren't refilled they are probably about to run low
Oct 05, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Lights flashing
the flashing lights is an error message, the flasshing may be a sequence of flashes, which designates an error code. speek to the tech support from the manufactur to decode the message & see if there is an easy solution
Oct 04, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
225 people viewed this question
jasbo
jasbo
