Question about Lite On SOHW-1653S (SOHW1653S09C) DVD±RW Dual Layer Burner
NEVER detects a CD. Help me!
My drive is detected without errors by windows and says here its fully functioning. No drivers are damaged, no system files missing. But somehow everytime i pop a cd or dvd in it detects it as a blank disc and allow burning on it. Obviously i cant burn any CD either. Any disc no matter empty or written, audio or data, in short, all cd or dvd's cant be read or written. Disabling and re-enabling the drive doesn't work, cant roll back the driver whatsoever. Could it be a dirty lens? Or a system error? Please help me, im desperate.
    Scholar:
  • 72 Answers
Try searching the internet for that model. and look for a firmware upgrade. Download it and intall carefully folling the instructions that came with the download. If this does not work start looking for your reciept.
Posted on Aug 03, 2006
SOURCE:
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
My acer aspire one d150 netbook webcam is missing . went to device manager and imaging display is missing . can anyone help with this problem?
Camera is not detected, there are several possibilities:
The first possibility
There was an error installing the driver. AOD150, manufactured by three types of cameras, chicony, liteon, suyin. Example: I installed the camera driver, suyin to AOD150. At the time of installation, a message appears, hardware not found / not detected / not recognize. This means, suyin not the right driver.
Solution
1. Open link driver AOD150
2. Operating System = Microsoft Windows XP Home Edition x32
3. Download software = Hardware Vendor Detection Utility
4. Double-click = HWVendorDetection.exe. We will find the right camera hardware.
5.
Download and install the Liteon driver
The second possibility
If the hardware vendor detection utility, does not detect camera
Solution 1
(assuming, normal hardware)
1. Possible corrupt operating system.
2. Reinstall the operating system, by doing format drive C.
3. Move all data from drive C to D/E/F.
4. Download drivers AOD150, and other applications, save it on drive D/E/F
5. Insert the Windows CD bootable. Perform boot from CD.
6. Press enter - F8 - New Installation - format the C drive, etc.
7. After the OS install is complete, install all drivers (chipset, LAN, VGA, sound, camera, etc)
Solution 2 (assuming, damage hardware)
Contact Acer Support
I hope this information useful, thank you.
Nov 24, 2011 | Acer Computers & Internet
Every tym i insert my pendrive it says insert disk into the drive...???removable disk appears..but it doesnt opns...is there any solution...plz do help me
Assumption 1
Flash drive is damaged, the normal operating system.
Solution
If the flash drive is detected (eg; detected the flash drive in drive G), but it says "insert the disk into the drive ..."
1. Download software JetFlash Online Recovery (open link - select type software - select OS Windows - select language English - select product JetFlash All Series - Download).
2. Insert the flash drive
3. Open file OnLineRecovery.exe - Select the volume of the device - Repair the drive & keep data existed - START. If it fails, select Repair the drive & erase all data - START.
If the flash drive is not detected (not detected as drive G),
the above solution can not be used.
Assumption 2
Normal flash drive, the operating sytem is corrupt
Solution
Flash drives do not require drivers (plug and play). Because flash drives plug and play, it should be, when the flash drive inserted detects the operating system without installing drivers. But, if the operating system does not detect, the possibility of operating systems corupt. The cause is a virus corrupt your operating system.
1. Download and install anti-virus Avira or AVG (free).
2. Update anti-virus
3. Scan your computer.
4. Repair the operating system.
5. If no virus is detected, the possibility of operating system is corrupt.
I hope this information helps.
Oct 07, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Laptop is not detecting the CDs or DVDs
check your CD/DVD driver is properly installed. you can check it by going in control panel, Clean your CD/DVD drive by any Cd/DVD cleaner.
Jul 06, 2011 | Compaq Computers & Internet
A disk read error occured and keep on re-start
Please check that the hard disk is connected properly. If you know that the hard disk is working, check whether it is detected or not. If it's not detected, you'll need to recheck it again with the power supply. If possible, try it to another Laptop so that you can make sure that Hdd isn't the culprit. In case it's detected and the problem still persists, repair the operating system installation, this will definitely solve your problem. Good luck.
May 26, 2010 | Dell Latitude D600 Notebook
I cant play a disc or DVD
Please try to reboot your laptop then go to CMOS Settings and detect the CD/DVD Rom and try to see if it is detected by your system. If it is detect ted then exit CMOS Settings and then load the Operating system you have and ope the DVD/CD Rom you have. But if it does not detect the DVD/CD Rom then i advice you to find a computer technician to help you fix the problem cause hardware problem is the main reason why it does not detect the disk drive you have, its either the connection bus is not properly plug or the Disk drive is damage or not functioning well.
Thanks
Aug 04, 2009 | IBM ThinkPad T30 2366 Notebook
Cd rom not detecting cd
Try to uninstall then reinstall cd driver. Or update its driver.
Apr 11, 2009 | NEC CD-2800D (cd2800d) 24x CD-ROM Drive
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Loading Windows 2000 on a formated hard drive
Try detecting cd rom in bios and boot from Cd rom. and then istall windows.
If not you should have drivers in floppy during installation it will ask for drivers F6 [function key]
Best Regards
rafique
Feb 18, 2008 | Fujitsu Stylistic LT C-500 Tablet PC
Lite On SOHW-1653S (SOHW1653S09C) DVD±RW Dual Layer Burner Logo
105 people viewed this question
Top Lite On Computers & Internet Experts
Pierre Laplante
Damen Wong
Damen Wong
paul shaw
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
