Hi; I Have a Dell XPS 1530 which is dull if I do not have it plugged in. I have three Targus power cords and cannot use any of them. The one that has the S35 tip fits, but only engaged intermittently. Is there a tip that works that I can purchase independent of all the other stuff? Best, Wayne Jack Wallis wallisw@gmail.com
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmmm..well..can you be more clear on the issue? the word 'dull' is throwing me off a bit..
  • 3 Answers
I am showing the AC adpater specifications as:
Input Voltage Range: AC 100V - 240V
Output Voltage: DC 19.5V
Output Current: 4.62A
Power: 90 Watt
Does your adapter meet those specifications?
Although I am a proponent of Targus products, possibly purchasing an OEM adapter may solve the problem. We have successfully purchased ones available from reputible vendors on eBay at a discount.
Have you checked to always show the battery status in the system tray so that you can verify when the AC adapter is actually charging versus an intermittent connection or malfunctioning power socket?
Posted on Oct 22, 2008
Dell XPS 1530 will not start up black screen. Tried holding down the Fn, F8 & on buttons, but still wont start
Hi David,
The fact you have no screen to get into the BIOS menu, indicates a big problem, and the culprit is the car power adapter.
Never, ever, use anything but the recommended adapter to power your unit, else disaster, followed by an agonising death for your PC/Laptop.
Your cars amperage is not compatible with your units amperage, unless you are using recommended DELL adapter for the car.
I hope you have not pickled your unit, but if so, you'll know better next time.
Cheers,
Peter
Feb 20, 2013 | Dell XPS M1530, M 1530, PP28L Series...
I need DELL XPS M1530 video driver which is compatible with windows 7. Kindly provide me with the link. I have found some drivers but those are hanging my Laptop Thanks
HI, You can always go to the dell support website: you can get the video drivers for your system on the link i posted.
Thank you for using Fixya.
Jul 11, 2011 | Dell XPS M1530, M 1530, PP28L Series...
Hi My Dell XPS 1530 Screen remains black at startup
hi
if your Laptop is on and your not getting screen the you have to do two thing
1 remove RAM from the motherboard
2 remove CIMOS battery from the motherboard for 10 to 15 mints
then re fix hope fully your laptop will work
Aug 02, 2010 | Dell XPS M1530 Laptop
Dell xps 1530 will get to log on screen and go blank
try logging in safe mode first upon turning system on tap on F8 then select safe mode, once logged in safe mode to a system restore to the date before this issue happend if system restore gives an error it failes tr going back to system restore in safe mode the do a disc defragmentation click start, accessories, system tools, system restore then select restore my computer to an earlier time then select the date when everything was working fine
Jun 04, 2010 | Dell XPS M1530 Laptop
Dell XPS 1530 wont power on at all..
Troubleshooting is pretty simple.
  1. Try a different Dell 90W or larger D/E-Series AC adapter and see if the system gets power. If no known good AC adapter is available, then check output voltage of AC adapter (Should be about 19VDC or so) If you can't do either, then the AC adapter is still the cheapest item to replace for a no power issue.
  2. If system will not power on with a known good AC adapter or new one, then the motherboard is the likely failure point. Roughly $150 on Ebay
Feb 24, 2010 | Dell Computers & Internet
How do you fix your Sigmatel C-Major audio driver?
I guess you selected XPS M 1530. or for even any other dell laptop on this planet. you can install the audio drivers from the following page.
Remember: - even though if you are not using XPS computer. you can click on add and edit service tag. and enter your computer service tag. and make sure to check if the os you are installing for and then click on audio. and there would be 1 or 2 files. install the file which has driver written on it.
TO CHANGE THE COMPUTER MODEL OR ENTER A SERVICE TAG
OR DIRECTLY DOWNLOAD THE AUDIO DRIVERS FOR XPS M 1530.
CLICK HERE
Sep 22, 2009 | Dell XPS M1530 Laptop
My laptop xps 1530 battery not charging
The battery is stationary but the cord is not, so I would say it is the cord. Go top a good store that works on them and ask to try it before you buy it. A new power supply can run $60.
Jul 19, 2009 | Dell XPS M1530 Notebook
XPS 1530 won't start up property
Hi there.
While you are in safe mode perform a system restore and take the computer back at least 2 - 7 days before the problems started.
Don't worry about loosing any data as system restore does not delete files.
Please post back if you need anymore help.
Good luck and thanks for using FixYa!!
Jun 08, 2009 | Dell XPS M1530 Notebook
Drivers for windows xp of dell xps 1530
I do believe that xps 1530 is built in for vista, that only thing that i can suggest you is you can try to look for the specific driver on other xps laptops for example your chipset is intel mobile then choose xp as the operating system or just directly search in support.dell.com
Oct 18, 2008 | Dell Inspiron XPS M1710 Notebook
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
