Question about LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher
LG Diswasher model LD-14AT2
Today the dishwasher leak at the bottom and don't want to restart.the light still work. the machine did not writte errror ..can you help us . the model is only 2 years old thank you
  • Anonymous Jun 19, 2008
    not star
  • LG Master
  • 909 Answers
NEED TO SORT OUT LEAK FIRST AS THIS HAS ACTIVATED YOUR SUMP LIMIT SWITCH. THE CYCLE WILL NEVER PROCEED OTHERWISE.
Posted on Aug 23, 2007
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
E1 error, pump spinning but not pumping
Just replaced wash pump unit
Thanks anyway
Ernie
Jun 11, 2009 | LG LDF6810ST Stainless Steel Built-in...
LD model LD-14AT2 dishwasher
Are you getting an error code displayed when this was happening?
How did you fix the problem?
Aug 25, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
OE fault in Dishwasher model LD-14AT2
suggest you take the drain pump motor out and inspect. either a blockage or its defective.
Jun 15, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-14AT2 SS Dishwasher.
The door frame is bent and will need to be inspected if further damage is done.  It's possible to fix but if the dishwasher frame is bent, then it's a total loss.  The frame is not repairable or are there any parts for it.
Apr 10, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Lg dishwasher model LD - 14AT2
E1 is usually a very common fault of the wash motor not working.
The impeller breaks away from the motor shaft and doesn't spin, therefore, it doesn't pump water.
There is a sensor that activates with low pump pressure, which shuts down the machine and displays the error, E1.
The only other causes (that I'm aware of) are leaking water supply hoses, or pump blockage, but the motor fault is by far the most common.
Hope this helps.
Mar 18, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD 14at2 lg dishwasher
Does it display an error code" eg: E1
Jan 05, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-14AT2 - Error message about filter
HI, WE HAD THE SAME ERROR AND WERE ADVISED - AFTER WE CLEANED EVERYTHING - TO NOT USE A LIQUID CLEANER AND USE A TABLET.
Nov 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG dishwasher model LD-14AT2
normally means not heating check element and use less soap
Nov 25, 2007 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BS6 Stainless Steel Free-standing Dishwasher Logo
674 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
