Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
AegisE5.dll was not found.
At the startup menu, I received a message saying the
following:
bcmwltry.exe - unable to locate component
This application has failed to start because AegisE5.dll was not found.
Re-installing the application may fix this problem.
What application? I searched for AegisE5.dll and found it, but when I
double clicked it, microsoft said not to open it. Every time I click the ok
button on the error, it (the error box) reappears within 3-4 seconds. I
tried reinstalling Belkin multiple times, but it had no effect; the box just
reappears This error is driving me crazy and I don't know how to fix it.
Please help.
  • Anonymous Apr 19, 2009
    I have the same problem but I don't have bcmwlt.exe in the startup tab! Help!
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    hmmm..did you do a google search on that error code? sounds a little like a adware program..
Http://www.fix-all-dll-errors.com/aegise5.dll/
You can get it from the above link.
Once you go to the above link click "Fix dll errors now" button & it will fix the problem.
Posted on Apr 05, 2011
    Genius:
  • 1,124 Answers
The file bcmwltry.exe is the tray bar process for the Broadcom Corporation Wireless Network software.
You can try eliminating the program from start up.
Click on Start >>Run, type "msconfig" (without the quotes), then click on OK.
When the System Configuration Utility loads, click on the "Start Up" tab, then scroll down to the "bcmwlt.exe" entry and UNCHECK the box next to it.
Click on Apply, then OK, and the computer will need to be restarted. Do it. Upon restart, you'll see a System Configuration Utility warning. Simply choose the option to stop it from repeatedly opening.
This will be fixing your problem
Have a great day!
Pablo :-)
Posted on Oct 22, 2008
I had the same problem after installing some drivers that a message from Dell told me I needed; I have a Dell Inspiron 1100. After trying several 'solutions' suggested, the bcmwdltry.exe message persisted. Finally, noticing that one of the installations was for a WLAN card utility (my computer doesn't have one), I found it in Add/Remove programs and removed it. That solved my problem.
Chuck Lewis, Guest
Posted on Aug 24, 2009
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Installing game
You need to install the newest direct x into your laptop.
Jul 05, 2008 | HP Compaq Presario C304NR Notebook
When I startup my computer I get the following message: hpmon06.exe. unable to locate component failed to start because hpzjrd01.dll was not found. What is required and how do I resolve this??
The hpzjrd01.dll file is associated with HP printers and is installed on your system with HP printers. i recommend you reinstall the Hp Printer drivers/ softwares
Dec 30, 2010 | HP Computers & Internet
Window itunes.exe-unable to locate component. box
hey, dll is a file in your pc, try to look for a qtcf.dll in the internet then try to download it,else try to re install your itunes, but use other installer, maybe the installer is corrupted.
Sep 30, 2009 | Audio Players & Recorders
Bcmwltry.exe error message
Hi there!
Bcmwltry.exe is most likely a process that starts during boot. It runs the Broadcom Wireless Tray icon.
Try disabling this process from your startup configuration. To do this:
Click Start>Right-click My Computer>Select Manage
Expand Services and Applications and then select Services.
Look for an entry belonging to Broadcom Wireless. If you find it, right-click on it and change the Startup type to Disabled.
Restart your machine and watch for the error. If it doesn't show and you still have a wireless connection, your problem is solved.
If you don't find an entry, try uninstalling the software associated with the wireless adapter. Then restart your machine and watch for the error once more. If the error message doesn't appear, you'll have solved the problem; however, you'll need to double-check your wireless connection and make sure it is still functional. If not, unplug the adapter, restart your machine and then plug in the adapter as if it was the first time. Maybe a reinstallation of the software will correct the issue.
I hope this helps! Feel free to reply if you have any further questions.
Aug 16, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Error message
hi,
You can go to this site ..
http://www.fix-all-dll-errors.com/ltkrn70n.dll/
as I registered few dll's from this site... pretty helpful...worked in my case :)
Jun 07, 2009 | Office Equipment & Supplies
hi,
http://www.fix-all-dll-errors.com/aegise5.dll/
u can go to this site...
as I registered few dll's from this site...worked in my case :)
Jan 03, 2009 | Televison & Video
Error message on startup
PRISMSVR.EXE is a process related to the PRISM Wireless lan hardware.. Reinstallig the lan cards software should solve it )though you might have to configure it all over again - take note of your current settings).
As for SSLEYA32.dll, if it was the spyware version of this file, it was problably deleted by your antivirus, but the registry call to startup is still there. In MSCONFIG you should be able to take care of that.
On the other hand, this file might be related to OpenSSL Toolkit from The OpenSSL Project. If you are not using this, then be glad it disappeared.
Oct 24, 2008 | Dell Dimension 4600 PC Desktop
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
3,359 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
