21pt2216/94 phillips 21'' audio problem
Hi, I have a 21pt2216/94 phillips 21'' flat TV, and there is no sound output. Only It shows mono in the screen , Is there any way to reset this ?
Thanks in advance
  • bala-orbit Nov 04, 2008
    Thanks a Lot man , I replaced the amplifier IC and it works fine
  • riazgsm123 Mar 03, 2009
    no sound.mono displayed....av1,av2,front new script added
Sir philips 21pt2216 set is dead 95v ok in power supply but ic po. no.7200 (tda9570)supply(3.2v)is drop. pls help.
Posted on Jun 10, 2009
    Champion:
  • 252 Answers
Your speaker maybe busted or check the amplifier IC
Posted on Oct 22, 2008
    New Friend:
No sound
Posted on Mar 15, 2013
How do I connect my flat screen tv to my Phillips MX3900 system
This is an older home theater package and only has component video out for HD and RCA or SPDIF optical out for audio. You'll need to locate the component video input on the back of your flat panel and connect it to the component output of the Phillips unit. Component cables have 3 RCA cable (Red, Blue, Green) for HD. You can use a RED/WHITE RCA cable for audio but if you have a SPDIF Optical cable you should use that for better sound. The TV should have that as an input also. You will need to go into the Menu for the TV and select component video and SPDIF optical if you went that route for audio.
Dec 03, 2014 | Philips MX3900 System
Connecting a soundbar to Phillips TV
only some model and brand has an audio output. you can hooked up at the earphone jack of the tv to get audio out.just used a mini earphone plug with output stereo rca plug.
Nov 05, 2012 | Televison & Video
Hi I havr 42inch flatscreen model 202 Phillips tv .When I turn it on it has no sound.Somedays it does have sound but most days nothing
The audio output section and the speakers to your TV should be checked. Contact any experienced service technician, as fault finding to audio output stage is a skilled work.
Jul 02, 2012 | Philips Televison & Video
I want to get a mono audio output from the TV audio sockets to combine the L&R channels to a magnetic loop amplifier. At present I only use the R channel) I want to keep the main sound as-is so that...
I assume you are taking an output from either the "Phono" or "Cinch" sockets on the TV.
There are leads available that combine left and right channels to one output. All you do is buy a Phone lead with the correct plugs on it. The lead will be a stereo lead. Cut the cable and join the screen/braided outer wired together. Connect the TV stereo inners together and you have a mono output. The TV has a buffer to ensure no damage is done to the sockets. If you want you can use a pair of 10k resistors in a "Y" configuration but as it is not a balanced amplifier input, it really doesn't matter.
Just use one of the plugs for your Induction Amplifier and you will get a mono signal on your loop that contains all of the audio information.
Hope that helps.
Nov 14, 2010 | Samsung LN26C450 26 in. TV
I have a Phillips flat screen tv that says locked when I turn it on. It won't let me do anything with the remote or on the buttons. I tried power cycling, but that didn't help.
if you connect the dvd to the tv using scart 2 on the tv it should send sound back to the dvd. if not then one of the scarts should be marked with a 2way arrow showing that is both input and output.
failing that us e phono cables (red/white) from audio out on the tv to audio in on the dvd and select the av or au on the dvd remote.
Feb 25, 2010 | Televison & Video
Phillips Eye Fi television sound not comming, momo
enter serv mode by following sequence
062596 display or menu
check option bytes , opt byte sticker is pested on crt or backcover correct the values problem will be solved
Jun 29, 2009 | Philips Televison & Video
Mono to stereo
You can't convert mono to stereo since the TV only has a single input, and not the separate right and left channel circuits needed for stereo. If you are connecting a stereo source like a DVD player, what you can do is combine the right and left channels into one and connect that to the mono input. You need an audio Y-adapter with two RCA jacks going into a single RCA plug. These are available from Radio Shack. If you are outside the US, there should be local sources such as a stereo shop where you can find the adapter. This won't give you stereo, obviously, but you will have all the sound.
Jun 22, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Akai LCT3785TA stereo vs. mono issue
Well the default is to obtain the channels signal. most channels over the world their audio output signal is mono. Rare tvs have the ability to save indivisual channel to their memmoty. Read the tv prospectus!!!
Sep 04, 2007 | Akai LCT3201AD 32 in. LCD Television
Televison & Video Logo
329 people viewed this question
Top Televison & Video Experts
