Question about Haier Washing Machines
Cant cold water wash - Haier Washing Machines
  • 46 Answers
try changing hoses to the hot soleniod and select hot instead of cold to see if that works if it does then it is probably the cold soleniod
cheers grant
Posted on Oct 22, 2008
My F&P WA75T65GW1 will not fill to rinse after the wash water has been pumped out. If I manually fill it, it will continue the cycle. Are you able to help? Thank you
when you wash do you set the water temp to warm or hot? it may have a broken cold water valve and may be filling with just hot water when washing instead of both, so when it gets to the rinse it cant fill with cold water, if you set it to just cold water does it fill on the wash?
Jan 31, 2017 | Washing Machines
My celcus cwm 1005 wont tack the washing powder
if the machine wont take in the powder
then the machine has no cold water supply
so this is caused by a few things
1} there is no cold water turned on to the machine
or there is a heavy pressure drop in your cold water supply too your home
2} the inlet filter is blocked solid the filter lives at the machine end of the cold water inlet hose... and you use a flat nose pliers to remove it for cleaning
3} the cold water inlet valve has failed
so it never opens so cant wash the soap from the drawer too the drum
i would get a tech too look at it
check the filter and also replace the valve if needed
Feb 08, 2015 | Washing Machines
Kenmore Elite HE3 does not work with Pure Wash system
One of the things to try is get a Y connector for the machine. Hook both ends of the Y to the washer at the hot and cold, then connect the last part to the pure wash. The HF error is HOT FLOW so it is not seeing any hot water pressure. The actual temperature should not be an issue. Also if you have too much water pressure you wont see the bubbles. If that happens just start turning down the cold water valve on the connection to the pure water unit until you see bubbles in the viewing window. I ams sceptical about these machines because you have to reduce the surface tension of water in order for it to clean, that is partly the job of heated water and laundry soap. Also if there is an ozone generator in that unit, there is a consumable part because ozone needs electrolysis to be generated. I cant help but wonder where the hydrogen goes when it is generated.
Feb 26, 2014 | Kenmore Elite Washing Machines
1 Answer washer goes through cycles and then stops at "light" . It won't go through rinse and spin. Help
Make sure your cold water tape is turned on and the screen in the water valve is not plugged up, it may be trying to fill with cold water and cant get any, try filling the washer with cold water on a "wash" cycle to confirm it it fills with "cold" then just the rince cycle ion the timer may be faulty and would need to be replaced
Aug 25, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Can u run hotpoint wmtl79-d/dg washing machine just on cold water
yes it can be used only on cold water
if what your asking is that if you only have one hose to connect to it that cant be done the water valve where the hoses attach to must be capped off on the hot side or water will leak out of it
so yes only cold be used but must cap off hot side inlet at machine
Jul 21, 2011 | Hotpoint Washing Machines
I've just moved house and my machine is not
Hello Friend, I think your machine will work properly if you add a water line splitter. You would connect to the single cold water tap and on the other end you would have two water hoses . Connect one hose to the cold water inlet of your washer and then connect the other hose to the hot water inlet. You can get these at Home Depot. Happy to help, Tim.
Jun 29, 2009 | Whirlpool Washing Machines
Cant connect the water hoses the machine
Cold fill only , designed to run efficiently on lower temperatures and with cold water powders
Blank off the hot supply line at the back of your washer before you fit it back to the wall.
Only two pipes on the machine Cold In, Waste out
Apr 23, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Not hot washing or drying
has it always been connected to cold water??? cant see how that would getanything clean designe dfor how water.
Oct 30, 2008 | Westinghouse Dishwashers
3 suggestions. 1st, make sure all of your valves are open. (some times installers forget to open them back up after the install) 2nd, fill the machine until the water gets hot. Check on the rear of the machine and make sure the hose going to the "COLD" valve is not hot (somtimes these hoses are reversed when they are installed) if those are both ok, then 3rd shut the water off and unscrew the cold side hose. (There is a screen underneath that can get covered with sediment from the house water supply and cause the water not to flow)
Jun 04, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Washing Machines Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
