Question about Toshiba Tecra M1 PC Laptops
Erratic cursor i got a tecra 1. my cursor sometimes is stuck at the upper and lower screen can't move it down or up. However, you can only move the cursor left to right and vice versa but not up and down. It goes normal after sometime then bang same problem. This is taking too much time, can you help is it hardware or software. The problem pop up using either the pad or the external mouse. Thanks
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    most likely the touchpad is getting a little old..it may need to be replaced soon.
  • 70 Answers
It happens with both? Sounds like it may be a driver or motherboard issue.
Check the HDD for errors with Checkdisk (Start -> Run -> cmd -> Ok -> chkdsk /f
Try redownloading the touchpad/mouse drivers from the Toshiba site
Posted on Oct 22, 2008
Integrate equations, using 0 and .123 as limits
Set Input/output to MathIO.
Press the Integrate key, to the right of CALC.
The image of integral appears with a rectangle for the function, and two small squares (one for the upper limit the other for the lower limit).
Type in the integrand (the expression you want to integrate) in the bigger (on your display) rectangle. Use appropriate parenthesis. To type in X press [ALPHA] )
Use the down arrow to move cursor to the square for the lower limit. Type in the lower limit. Use the Up arrow to move cursor to the upper limit square. enter the upper limit. Press [=] key. If you did not make mistakes, and your expression is not too complicated you should get your integral.
Note: The screen captures are not from a Casio FX991ES. But that should not matter to you.
Feb 10, 2014 | Casio FX991ES Scientific Calculator
My blue nipple mouse is screwing up Toshiba Satellite 6100 Mouse i in the middle of the keyboard works rarely but sometimes moves cursor to upper right or lower left corner of screen & then it...
Sounds like the keyboard has gone bad (the mouse and the keyboard are integrated into one unit). Replace it. Cheapest source of these parts will be eBay.
Sep 16, 2010 | Toshiba C99704 Mouse
Integral of sinx how to calculte in casio fx991 es
Configure the calculator to be in MathIO : [SHIFT][MODE][1:MathIO].
Press the Integral key, the one judt beloe the [ALPHA] key.
The template of the integral appears, with the cursor in larger rectangle. Enter the function the screen displays the integral, a small upper sqaure, and a small lower square. The left parenthesis of the function is already supplied by the calculator.
Press [ALPHA] X to enter the argument of the function.
Press the right parenthesis.
Remain the limits.
Use left arrow to move the cursor just before the s of sin and press down arrow to enter a numerical value for the lower limit.
Press the up arrow to move cursor in upper square.
Key in the numerical value of the upper limit.
Press [=].
Warning. To have meaningful result, make sure the angle unit used is conform to the problem you are trying to solve.
Hope it helps.
Nov 01, 2009 | Casio FX-300MS Calculator
Scientific notation
I found a way to show you how to enter it on your calculator. Make sure you are in Math Input Output (MathIO). To effect that press [SHIFT][MODE][1:MathIO]. Calculator clears its screen
Press [SHIFT] then [Fraction template key] the one just below [calc]. I will show an image of the template in a picture below. Then you enter 4.6x85000 in the upper square of the template. Press the [Down Arrow] to move cursor to the lower square and key in 3570x0.0843. Then use [Arrow right] to move cursor to the level of the fraction line and press [=]. Hope it helps.
Oct 06, 2009 | Casio FX-115ES Scientific Calculator
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Cursor moving erratically
Sounds like your internal mouse maybe be malfunctioning and due to the pressure on the spacebar is causing the erratic movement.
To fix this you can enter your BIOS with the F2 key at startup.
Continue through until you find some input options to disable the internal mouse.
Jan 23, 2009 | Toshiba Tecra M1 PC Laptops
Cursor jumps around
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
Aug 14, 2008 | Computers & Internet
Toshiba Tecra M1 PC Laptops Logo
156 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
