Question about HP Pavilion N5415 Notebook
Internal keyboard , shit key, uppercase numeric keys, don't work
I've tried just about everything to fix the keyboard. i've uninstalled and re installed drivers, updated drivers, re installed windows xp, updated bios..and still all the numeric uppercase , the shift keys do not work. i even at the suggestion of hp tech, shut down lap top , and disconnected, turned over and slapped the darn help there...
Re: internal keyboard , shit key, uppercase numeric keys, don't work - HP Pavilion N5415 Notebook PC Laptops
Don't forget to bring a towel
Posted on Oct 24, 2008
  • 29 Answers
Re: internal keyboard , shit key, uppercase numeric keys,...
Probably time for a new keyboard, there not hard to put in. before you order a new keyboard though (or take into the pc shop), besure its connected tightly,
Posted on Aug 12, 2006
0 characters
3 Points
(Still) having issues with ..... No Audio/Sound/Video on this Acer4100 travelmate PC??.. need 2 know about how 2 (un-install old drivers- @ no cost 2 me??)... been trying (Almost) everything 2 Un-install...
You can download the original drivers from Acer directly.
Driver Acer TravelMate 4100 Windows XP Acer Driver Support Centre
In order to remove unwanted drivers:
  1. Click on Start and then Run.
  2. Type the following command in the Open: text box, and then hit the Enter key or click on the OK button. devmgmt.msc Device Manager should display right away.
  3. Use Device Manager to update device drivers, view the system resources that Windows XP has assigned to your hardware devices, etc.
  • Find and double-click the category of device whose driver you wish to uninstall (for example, the graphics card would be listed under Display Adapters).
  • Right-click the device, and click Uninstall.Windows will prompt you to confirm the device's removal.
  • Click OK to remove the driver.After the uninstallation is complete, reboot your computer as soon as possible.
  • Install the appropriate driver and again reboot.
Caution: After rebooting while uninstalled a device, windows might try to install again the same driver, because it found new hardware. Press Cancel and install your new driver.
Feb 18, 2014 | Acer TravelMate 4100 Notebook
Undi fail
this is driver corrupt for keyboard , download from your manufacturer supplier , uninstall the old one, and install the update driver and fix it.
However you musT Run the anti-virus +antimalware , and update your m.window update+firewall.
God bless you
Nov 08, 2013 | Dell Inspiron 2600 Notebook
Problem with ASUS M51 Series M51Sn NoteBook Intel Core 2 Duo T8100 15.4' WXGA 3GB Memory 500GB SSD
update your bios then update the battery drivers in device manager if that doesn't work go to win 7 pro
Feb 28, 2013 | PC Laptops
Inspiron m5030 touchpad not working
Yes you probably pulled out the cable. Take your keyboard back out and look for a small flat cable that runs under the palm rest.
Oct 22, 2012 | Dell Inspiron M5030 Laptop
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
From the description you have a hardware problem possibily caused by the ipod plugged into the headphone jack of the laptop. I'am convinced the sound section on the motherboard is damaged, probably the audio output ic. But to trouble shoot the problem will require someone with a strong background in electronics, I would suggest going no further until you have estimate in hand.
Jun 26, 2012 | PC Laptops
Acer inspire 5332key board problems
Try reinstalling/updating the driver, click: start>control panel>hardware and sound>device manager. Look for keyboards and expand the menu. Right click on the keyboard adapter and click properties. The first tab (general) will tell you if the device is working properly. Click on the drivers tab, choose update driver and search automatically for updated software. You can also try to; uninstall the keyboard, reboot the machine and let windows install a new driver.
Mar 28, 2012 | Acer PC Laptops
I was in the middle of cleaning up my laptop (deleting stuff i do not want on my laptop) and when i had finished my keyboard did not work(built in keyboard) nor my built in touch mouse keypad did not...
This usually works for most device problems. Go to the device manager and scroll down to the mice and pointing devices as well as the keyboard. If the keyboard and the touchpad are listed in the device menu, then you can right click on the device and click on update driver. Windows will search update for a fresh driver. If the devices are not listed, then go to Acer support (link below) put in the model of the laptop....Aspire > 1640Z and a list of downloads will come up. Download the drivers for the keyboard and /or touchpad. After they are downloaded, run the apps, they usually self install.
If they are listed in the device manager (device manager is in the control XP, look in the system flder under the hardware tab.) and the above fix does not work, then scroll down to them and when you right click, Hit un-install, but keep the drivers. Do this one at a time and let the system reboot after each uninstall. Windows will detect the device and load the driver for it.
Oct 20, 2009 | Acer Aspire 1640Z Notebook
After win xp sp2 installation my c700 notebook pc keyboard malfunctioning
Your keyboard uses a driver(small pieces of sftware). Windows might have corrupted the driver with no intentions. You can get into safe mode by pressing F8 on some models and you can either restore just before the update or uninstall the knowledge base update that caused it.
May 17, 2009 | Compaq Presario 700 470024-192 Notebook
Mass storage controller driver
IDE controller starts to install the driver automatically as soon as you restart. The best way to get it completely removed from your comp is that in case you are using Windows XP or higher version goto Safe mode by tapping the F8 key on the keyboard on restart. goto control panel to Add/ remove programmes and uninstall the software completely. I hope I helped you out.
May 01, 2009 | PC Laptops
Keyboard probs sony Vaio vgn-a215z
well 2 things u can do either get the mtherbrd disc from any of the local store second the way long t/s search for "how to map keyboard in xp" acc to ur keybrd specs ull be able to do tht i cant help more then tht cause i need to take remote access of ur compteru
May 22, 2008 | Sony VAIO VGN-FJ270/B Notebook
HP Pavilion N5415 Notebook Logo
188 people viewed this question
Top HP PC Laptops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you a HP PC Laptop Expert? Answer questions, earn points and help others
