Question about ASUS (GENEIRC DRW-1608P BLACK) (GENEIRCDRW1608PBLACK) DVD Drive
Cannor Read DVDs
I'm having Asus DRW-1608p3s. It's not able to read DVDs i put, it shows nothing in the drive but easily reads CDs. What is the problem!!
I have a similar issue to you, except that my dvd drive will only recognize a disc if I have booted up into windows with it in the tray...once in windows it will still think it has the first disc in no matter what disc i insert. If i boot up with no disc then it will never read it unless I follow the steps below.
A solution I found by pure frustration and trying all sorts of things is to eject the DVD tray and leave it opened, then right click on the dvd drive in 'my computer' and select the 'hardware' tab...then select the drive and click 'properties'.
A new window should open. Select 'volumes' and click 'populate'. Now close the window and insert the disc you wish to read, close the tray and repeat this process. Windows should now recognize the disc you inserted
Alot of trouble I know, but it works for me. Hope this helps.
Posted on Oct 24, 2008
DRW-1608P 3S - doesn't show on 'my PC'. On 'device manager' there's the name but with an exclamation mark over a yellow circle. My daughter was deleting old programs before, to make room for photoshop....
you need the drivers for this hardware (DVD Drive) also sometimes a firmware update is necessary in order for it work properly
asus-drw-1608p3s-u-1-24-firmware-vt1486.html">http://www.inetbridge.net/forum/driver-asus-drw-1608p3s-u-1-24-firmware-vt1486.html
this is direct link http://www.inetbridge.net/forum/download/file.php?id=1622&sid=db1912e34e9b2e8bf95cd864a78f2d2b for the drivers / firmware download
download the file, extract the content and it will do the rest. make sure to have your dvd drive connected to your computer.
Mar 09, 2011 | ASUS (GENEIRC DRW-1608P BLACK)...
The drive doesn't read cds but can read dvds!!
If you have access to the lens clean with a tissue or micro fibre cloth In circular motions gentle 10-12 swirls and then try the drive if problem persists then your drive lens have got weak need to replace drive. You have to remove the top cover of drive with 6-8 small screws. It first stops cd reading and then DVD , it's normal. Pls rate my solution if I helped.
Jul 28, 2009 | ASUS DRW 2014S1T - Disk drive - DVDRW /...
DVDs will not play on drive(DRW-1608P3S)
The reason for this issue is the lack of a codec software like Cyberlink PowerDVD or PowerCinema.These are paid versions.We could try installing a codec pack from Klite.Its free.The link is : http://www.free-codecs.com/download_soft.php?d=5075&s=775 Please let me know whether it fixed it
Mar 17, 2009 | ASUS (GENEIRC DRW-1608P BLACK)...
Does not read dvd
According to Asus there are many burned dvd formats that are not supported or simply do not work in this drive. Asus stated that most dvd-r should work but not all, and that is the only burned dvd media that works. You may want to look into buying a different drive.
Dec 17, 2008 | ASUS DRW-1608P3S DVD±RW Dual Layer Burner
Asus DRW-1814BL wont read cd-rom but able to read dvds
Have either of you flashed the latest firmware from the Asus site
it is now at v1.14 which has cured a few problems.
unkphilip
May 24, 2008 | Televison & Video
My burned media from my new DVD Burner ASUS DRW-2014L1T isn't able to be read by my DVD Player
no data dvds work on the players.
use NERO 6 OEM to write Video DVDs or CDs they will run Players
Jan 07, 2008 | ASUS (GENEIRC DRW-1608P BLACK)...
Wont work
Sounds like there may be an issue with the drive itself. I would return it or replace it. As for windows...If this problem persists after a replacement, i would re install windows.
Dec 27, 2006 | ASUS DVD_BURN |DRW-1608P3S BK W/SW R...
ASUS (GENEIRC DRW-1608P BLACK) (GENEIRCDRW1608PBLACK) DVD Drive Logo
352 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
