Question about Kobian CyberPix S-330 Digital Camera
Instalation in laptop with window 7 is giving error & not working.
I have instaled cam manager from the CD supplied with the camera in my laptop, is giving error report that camera is not connected in case of live video setting.
  • 5 more comments
  • Muhammad Shakeeb
    Muhammad Shakeeb Feb 06, 2012
    what should I do now.
  • Muhammad Shakeeb
    please help me in solving the problemb.
  • Muhammad Shakeeb
    I have submitted the problem & I am not receiving the solution.
  • thomas cochran Feb 06, 2012
    i was toying with this idea i get account this junno and vidio email soso you pick the right software we go this here and we try it thereso i you try and work it out cnet is good for retrying other more easy touse software seems you got software chioce to make error mustmeet critria get you to spec  and matches your setup ok
  • The Spaminator
    The Spaminator Oct 07, 2019
    driver for camera ?
    go into device manager
    see if camera is ok or needs driver update
    is camera built into laptop
  • Muhammad Shakeeb
    Muhammad Shakeeb Oct 08, 2019
    camera Cyberpix S-330 is not builtin in laptop. The driver supplied by company is for window xp and I have window 7 in my laptop.What to do so that the camera start working in window 7.
  • The Spaminator
    The Spaminator Oct 08, 2019
    camera is made by mercury
    not sure on file's safety http://semantic.gs/mercury_cyberpix_s_33...
    install 7zip to unzip download
    do a virus check on it !!!
    can't find a mercury support website !
Laptop can not detect web cam
What kind of Web Cam try installing driver grist
Sep 07, 2014 | MSI Computers & Internet
I have a lenovo g560 laptop with an integrated camera.but the cam has suddenly stopped working i have tried installing the drivers but of no use.cam is not being displayed in device manager whenever i try...
Sometimes it could be something really simple. I've actually had this same problem before and fixed it with this solution.
1. Go to your Device Manager. To do this, click on your Start button and right-click on My Computer (or Computer if you're running Windows 7). On XP and Vista, select the Hardware tab and then click Device Manager. On Win7, click Device Manager on the left side of the new window.
2. In the Device Manager window, find the Imaging Devices icon in the list and click the drop-down arrow.
3. You should see your camera. Right-click the camera and see if there is an option to "Enable" it. If so, problem solved! If not, try uninstalling the camera and then restarting the computer. When your computer reboots, it will scan for hardware changes and reinstall the camera with the latest drivers. If those drivers don't work, try going to the manufacturer's website and installing the latest drivers listed on their site.
Aug 25, 2011 | Computers & Internet
Inverted web cam display in asus k401j
1. Download the latest Chicony (or Suyin) driver for Windows 7. Check here: http://support.asus.com/Download.aspx?SLanguage=en&m=Camera&p=3&os=)
2. Extract contents to desktop.
3. Click the ORB button. right-click on Computer and select Properties.
4. Select Device Manager.
5. Click on Imaging Devices to show the name of the webcam.
6. Right-click on the name of the webcam and select Properties.
7. Go to the Driver tab. click on Update Driver. a new window should pop-up.
8. Click 'Browse my computer for driver software'. select 'Let me pick from a list of device drivers on my computer'.
9. On the next window, it'll give you the current driver. click 'Have Disk'. click Browse. Browse to the desktop and select lastest driver that you've downloaded. it'll be then added to the list of drivers. select the new driver and click Next. Just follow the prompts so that it'll install the new driver.
If still this does not work, try this:
Re-install the camera virtual camera using your ASUS hardware disc and follow this step.
1.Insert ASUS hardware disc and "open"
2.Click "explorer"
3.Click "software"
4.Click "camera", then choose and click chicony folder
5.Open the folder APPLICATION/installer, and re-install the ASUS virtual camera.
Once you already installed the driver, go to start menu click or type ASUS lifeframe then open it.
Jun 25, 2011 | ASUS Computers & Internet
After installing windows 7 my laptop webcom stopped working
Update your drivers on your webcam by going to their website. Depends on what kind of camera you have. They should have a download for drivers for windows 7. also make sure you have all the updates form windows 7 on your computer.
Jan 14, 2011 | Dell Inspiron 1525 Laptop Jet Black
My laptop is (HP) AMD Athlon II P320 Laptop (G62-244CA). and my web cam is HP WEBCAM 101, its not working. I have checked the device manager and it says that my web cam is working properly. But when im...
go to device manager, un-install your web cam and re-install with the drivers cd of web cam, also change the port of the cam els the cam may gone
good luck
Nov 05, 2010 | HP Computers & Internet
QuickCam Connect Personal Web Camera: i lost my cd driver..my web cam logitech n231 how ...
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
Find your camera photo and click on it
Older models on page 2 - use the link - "Still can't find your product"
May 18, 2010 | Logitech QuickCam Connect Webcam
How can i get a VEO driver for my web cam?
hi, to install the your camera..just connect the usb to the usb port then insert the cd to your cd/dvd drive then start install the software the just click next until it will finish...
regards
Mar 21, 2010 | Veo Advanced Connect Webcam
Web cam says to close other video streaming application before it can proceed but there are no applications open that I know of.
try and install the right driver for this device ...that's why it says this ...it sees all wrong ...the issue with windows 7 is that does not have drivers for cameras or elder devices....if it is a built in camera ....just try to get in touch with the manufacturer and see if there is any drivers for the camera ...also ...you can try the driver for vista on 64 ...usually works ..but this is not a rule...
if there is no other chance ..until the driver will appear on the internet ...just get another camera with driver compatible with this operating system ...or roll back to vista or xp ...cause this oS is not that great anyway ...its slow...hard t use...and strange...
Jan 14, 2010 | Dell Studio 1737 Laptop
INTEGRATED CAM NOT WORKING
Install the driver for windows Vista first,
1) Bring up the device manager. You do that by clicking on Start button and then type 'Device Manager' in the search box. Select the "Device Manager" in the list.
2) In the list of devices, you will see "Chicony USB 2.0 Camera" with yellow bang on it. You will see either code 19 or code 1 as error codes.
3) Right click on the device and then select "Uninstall".
4) In the uninstall dialog, make sure you select the option to delete the driver package from the system. This causes the driver package installed earlier to be deleted.
5) Then in the Action menu of Device manager, select Scan for Hardware changes option. This will cause the device driver to be reinstalled
Same goes for LiteOn Camera Driver.
Everything will be fine after that.
Jan 05, 2010 | Lenovo 3000 N100 Notebook
Toshiba built in web cam not working
Remove both Webcam driver and skype with a software called Vista Manager from yamicsoft.
Why a third party tools to uninstalled a software?The answer is it will remove even the files or registry key that is concern with that software.
Download the file using the link below
http://www.yamicsoft.com/vistamanager/software/vistamanager.exe
If you are with windows 7 then downalod Windows 7 Manager
Here is the link :
http://yamicsoft.com/windows7manager/software/windows7manager.exe
after unstalling reboot your system.
First installed your webcam driver and check webcam work or not. Then installed skype software.
It will work.
Note: Lastest skype version have problem with webcam synchronisation.so used a little older version.
Dec 28, 2009 | Computers & Internet
Kobian CyberPix S-330 Digital Camera Logo
Top Kobian Cameras Experts
Damen Wong
Damen Wong
Marvin
Marvin
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kobian Camera Expert? Answer questions, earn points and help others
